Onkyo SKW-591 subwoofer is dead
  • tibimakai
    • Jan 2012
    • 3680
    Somebody gave me the whole system for free. Receiver's HDMI IC is getting extremely hot, course, there is no HDMI in/output and this sub is dead.
    HDMI IC was replaced already by previous owner.
    But this thread, is about the subwoofer.
    I have found the final dual FET transistor Q502, shorted across +/- power supply(pin 1 & 5) and Q952 FET, at the power supply shorted as well.
    I have just replaced them, but at the speaker output, I'm measuring over -7V DC. Q951/Q952 are starting to heat up really fast.
    D515 and D516 are good.
    There is not much time to start measuring.
    What should I start measuring?
    Any help would be appreciated.
    Here it is the SM:
    elektrotanya.com/onkyo_htp-591_skw-591_sm.pdf/download.html
    Read more: http://repairalmostanything.com/thre...#ixzz5mDm0XNkL
  • tibimakai
    • Jan 2012
    • 3680
    Re: Onkyo SKW-591 subwoofer is dead
    I have went over all the components, at the final amp section and I have found, three 33 Ohm resistors that were bad(high value). R505, R511 and R513 are the blown values.
    Unfortunately, after I have replaced these resistors and I have turned it on, heard a whistle like sound and than a slight pop-pop-pop sound and I knew that Q502 was shorted again.
    And it was. I have only seconds, until it blows.
    The voltage, at the speaker output it was still -7.xxV.
    How should I proceed repairing this amp?
    I still have another final amp IC.
    I shouldn't solder it in, and try the power supplies first, if they have the proper voltages?
    • R_J
      • Jun 2012
      • 9547
      If R511 & R513 were damage It is very likely Q501 IC is bad, If R505 was open I would suspect C501 could be damaged also.
      You might be able to work on it without Q502 installed I would also check the value of all the resistors/diodes in the output circuit. If one of the resistors is open it can effect the offset voltage and blow the output
      Check R528, it should supply +12 volts to the ic
      • tibimakai
        • Jan 2012
        • 3680
        I will place an order for a new IC & capacitor, and I will check that capacitor, but if I remember correctly, it wasn't shorted.
        • R_J
          • Jun 2012
          • 9547
          there was enough current flowing through c501 to open R505, download the pdf for the irs2092, it has internal fets and you should be able to check them and give some idea of what is going on. IE: if fet across VB & HO is shorted etc.
          • tibimakai
            • Jan 2012
            • 3680
            At pin #12, where it should be 12V, I measured -39V(!). GND I took it, from pin #2.
            I have removed Q901(7812 regulator) and -40V it was still there.
            I have went through all the parts in the amp section and only the three 33 Ohm resistors were bad, which I have replaced already.
            Just for good measure, I have replaced the 470uF capacitor. It was showing 4.3 Ohm ESR.
            • R_J
              • Jun 2012
              • 9547
              I looked at the schematic again and the +12 VB volt uses -39 volt supply as ground, to check the 12 volts use COM (Pin10) on the ic or measure across C503
              The amp ic is used in bi-amp mode, It uses the -39v supply for the 12 volt regulator's ground, not chassis ground
              Were you able to check the ic's internal fets to see if any are shorted?
              • tibimakai
                • Jan 2012
                • 3680
                There is 0V with 7812 installed and IC removed.
                It seems like, between pin #15 and 14 there is a short, and between 12 and 11, there is another short. So the upper FETs, at both channels.
                • R_J
                  • Jun 2012
                  • 9547
                  I would check for around +15 volts across C905, it needs to be there before you will have the +12 volts from the regulator, Q902 needs to be turned on by Q903.
                  The IRS2092's VCC is turned on and off by that circuit
                  • tibimakai
                    • Jan 2012
                    • 3680
                    Across C905, I measure 26V.
                    • R_J
                      • Jun 2012
                      • 9547
                      Thats likely what it should be, When the sub turns on Q902 supplies Q901 regulator and that 12 volt regulator is what supplies the vcc voltage to turn on the amp ic
                      Earlier when you replaced the resistors and Q502 had you also replaced the Q501 ic or only the resistors and q502?
                      • tibimakai
                        • Jan 2012
                        • 3680
                        Only the Q502 and resistor. I did not know that Q501 was bad.
                        I need to order some.
                        • tibimakai
                          • Jan 2012
                          • 3680
                          I have replaced both ICs in the amp section, and there is still an issue.
                          DC voltage is 2.3V.
                          I have noticed that the schematic on elektrotanya, is not the right one.
                          There are no 7805 or 7905 ICs, on the board. There is only a 7812. 12V is there.
                          It seems like the amp +/- voltages seem a bit off. One side is like 2V higher than the other and slowly increases. The DC voltage at the speaker output is slowly increases as well.
                          I have measured all the components in the amp section, and they all look OK.
                          • R_J
                            • Jun 2012
                            • 9547
                            DC voltage is 2.3V.
                            where? across the speaker? what is in place of the regulators? anything? is Q433(C) connected to VAA
                            I can't see +/- being off a couple volts being an issue unless the filters C901/902 are bad. Also are the ic's getting hot? Make sure R525 is ok as it takes the offset voltage and feeds it back to the input for compensation.
                            If the schematic is not the same I'm not sure how I can help.
                            • tibimakai
                              • Jan 2012
                              • 3680
                              Across the speakers.
                              Everything installed, except the speaker.
                              The final IC is not getting hot, I haven't checked Q501.
                              R525 is OK.
                              • R_J
                                • Jun 2012
                                • 9547
                                I would see what the voltage is with the speaker connected and if you have any hum. It could be that the 2.3v is due to the lack of a load
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  It has a loud brrrrr.
                                  • R_J
                                    • Jun 2012
                                    • 9547
                                    If this sub used a regular 60hz power supply that would sounds like a bad main filter cap, but this uses a switching power supply so that should'nt sound like that if the caps were bad
                                    This sub does use the switching power supply correct? (q951/952,Q953) or is that part also different?
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      I know for sure that Q951/952 is there, because one of them it was shorted and I have replaced it. Most likely, Q953 is there as well. I will check it, when I get home.
                                      The +/-40V and 12V is there.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        I have tried with the speaker. It just pops ones as I plug it in, the cone extended and stays there.
                                        The brrrr, seems like it's gone.
                                        The first time did not make anything, I had to touch the input and that started the popping as a I plugged it in and the cone extended.
                                        • redbaron1007
                                          Onkyo SKW-791 subwoofer
                                          by redbaron1007
                                          I've got an Onkyo SKW-791 subwoofer in right now that isn't powering on. Or at least the indicator light isn't coming on and the system it goes to can't detect/connect to it. It's drawing 0.7W from the wall when plugged in according to my kill a watt. It has a hissing noise constantly whenever it's plugged in, but the hiss isn't coming from the speakers this is when the board is pulled out of the housing and sitting on my bench. The hissing nose is still present even when the speaker is plugged in, but nothing comes out of the speaker.
                                          The first thing I did was replace the audio...
                                          12-20-2022, 08:08 PM
                                        • rustinjust
                                          Please help, subwoofer connected to tv, read description below
                                          by rustinjust
                                          I've got a subwoofer that I've had for nearly 20 years, it did come with a basic remote which I've lost. It's a generic make of subwoofer, I can't see a brand sticker on it. It comes with 2 speakers.
                                          Question recently I've connected it up to my tv which has greatly improved the sound on my tv, however I'd like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                                          Is there a way of...
                                          10-28-2023, 07:09 AM
                                        • rustinjust
                                          Please help, where can I get a remote for my subwoofer?
                                          by rustinjust
                                          I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
                                          Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                                          Is there...
                                          10-28-2023, 03:43 AM
                                        • Fripacks
                                          Onkyo model SKW780 Subwoofer
                                          by Fripacks
                                          Hi guys, I have a subwoofer Onkyo model SKW780, one zener diode is short, I don't know the value, the location is D920 in the Power Supply Board, someone know the value of this zener?
                                          12-21-2021, 03:19 PM
                                        • double_DD
                                          How can I be sure that my EC chip is dead?
                                          by double_DD
                                          As the title suggests, how can I be sure that my EC chip is really dead?
                                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                          03-12-2025, 07:47 AM
