Re: Polk Audio PSW350 No Balls
Dual OP-AMP C358C on the power amp board, the signal from Preamp board is fed to R13 which goes to pin 6 of the C358C Dual-op amp. You can use audio probe (PC powered speaker with 1K resistor and DC blocking cap on the input to the to PC powered speaker) to check the signal on the leg of R13 to goes to the connector (cannot see the designator) of the power amp that goes to the preamp board.
Please see the spec of the IC:
C358C DUAL OP AMP, it is used for driving the output section of the amplifier.
HA17324 Quad op-amp
I would check Voltages of the IC power supply pins (V+/-).
You can use audio probe to trace the audio signal at output pin of the Op amp.
In that case grab some new and/or known good electrolytic caps and try measuring those. If you get iffy readings, then you know something isn't right.
Checking caps with a DMM is mostly pointless. I only do it occasionally to check for suspect electrolytic caps that may possibly be short-circuited... but that's very rare.
1000 uF low is just a hair below the 20% lower end of spec for those caps, so they definitely look suspect if the readings from your meter are to be trusted.
Also, what ESR did they show? This is far more important than the capacitance.
As for the DMM test... again, it's mostly pointless. But if you do want to do it "right", then you have to short the capacitor's (+) and (-) terminals every time before attempting to check them.
Report back what you find on the main caps above with some numbers (ESR and capacitance) - that is, after at least verifying your meter with some known good caps.
If the main filter caps seem alright, then I think the next thing to do is to isolate the audio between the output amp and pre-amp. That is, you'd be inserting an audio signal directly at the amp output IC / output stage to see if the distorted signal is there. If not, then the distorted audio is more likely originating from the pre-amp section. To verify that as well, you can insert an audio signal into the sub the regular way and see if the audio (or at least bass) comes out properly from the pre-amp section or if it's distorted.Last edited by momaka; 04-09-2019, 10:14 PM.Leave a comment:
Anyone ? Could use some help with this one...Leave a comment:
Where can I take some measurements to troubleshoot this ?Leave a comment:
Ya I changed the smaller ones and same result. Maybe this sub is just for shit ?
Seems I can't trust the readings on my esr meter. At least not the capacitance readings, some read grossly under spec but read ok with my DMM. The main filter caps read about 1000uf low on my esr meter but they won't measure at all on my DMM so not sure about their health...Leave a comment:
Yes.
Did you check those too, by the way?
They rarely fail, but when they do, that's exactly what you get - "garbled" bass (similar effect to when you grossly clip an amplifier output.)
If they are 5 x 11 mm cans or smaller, they still might be "within tolerance". But at those measurements, I'd say they are getting closer to their EOL. It also depends on their series - i.e. if these caps are low ESR series, then 5 to 7 Ohms is more than likely too high / out of spec (check their datasheet to confirm, if it's a low ESR series.) If they are just general purpose series... eh, just change them anyways, if you have spare replacements. Above 5 Ohms is getting a bit lousy for a cap.I pulled C8 and C9 the two CapXon 22uf/50v caps between the large filter caps. One read 22uf 5.5ohm esr and the other read 18uf 7ohm esr.
Some esr tables indicate they should be about an ohm or less and others tables say these are fine. I suppose it depends some on the application so are these toast or still ok ?
Hard to tell if the highs and mids are ok since by definition a subwoofer rolls them off rather quickly. But your point about instantaneous current may have merit. Are the bulk smoothing caps the large main filter caps ?Leave a comment:
what the hell is "muddy" ??
if you have no bass punch - but highs and mids are o.k. then it's a lack of instantanious current caused by weak bulk smoothing caps.Leave a comment:
I had to put the caps back in. I read 0mv on the speaker terminals that doesn't seem right but then that was without input (it's still mostly apart)
I do not have a history on the unit it was given in trade for a few other things. It was supposed to be working and sat for some time before I tried it.
The speaker measures at 3.2ohms on my meter and was functioning previously just not with any power or thump. Much lower volume than I would expect even with the gain turned up.
Pics you requested in next post.Leave a comment:
This unit has linear power supply and linear amplifier.
What DC Voltage do you have on the speaker terminal?
Can I see good high res pix of the bottom side of the power supply/Power amp board?
What is the P/N of the IC U1 on the power supply/Amp board?
Can I see pictures of the Audio input board?
What is the history of the unit?
The speaker is good?Leave a comment:
Some esr tables indicate they should be about an ohm or less and others tables say these are fine. I suppose it depends some on the application so are these toast or still ok ?Leave a comment:
I do have an esr meter and have tested the smaller caps in circuit with it and the readings lead me to take your advice and pull them for further testing.
Will report the readings back when done.
And yes it's a linear transformer.Leave a comment:
Does this sub use a linear transformer? Looks like it to me with that bridge rectifier next to the two big caps.
Muddy audio could be from the small caps on the "amp" board. But it could also be if one of the main (big) caps is bad or starting to fail. Do you have an ESR meter? If yes, now would be a good time to pull some caps and measure them. That said, take precaution around the big caps - they could still be charged even long after you disconnected the amp. Moreover, even if they are not fully charged, more than 5V could still damage your ESR meter if it's one of those eBay/AliExpress kits. So beware of that.Leave a comment:
Alrighty then...
From some of the other subwoofer threads I think I have all voltages present ?
Is it good practice to just replace the electrolytics on the board first ?Leave a comment:
This thing has no guts and a really muddy sound. I took the backplate/amp off and have these measurements on the eight pin connector J6 which goes from the amp to the input board.
Pin1 0v
Pin2 -13.97v
Pin3 0v
Pin4 0v
Pin5 +51.7v
Pin6 -51.8v
Pin7 +14.54v
Pin8 -14.58v
Do these look good or... ?Tags: None
The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
The player processes the audio signal using two different reference frequencies. The "R"...2 Photos -
Hi
I have this Lantec PULSE 386 subwoofer I got a while back laying around awating repair for quite some time. Sadly it's missing it's original speakers which it came with.
After plugging in the mains, the LED on the volume controller lights up. When I plug in the 3.5" jack cable to my soundcard (confirmed to work), I get no audio on the subwoofer (nor the speaker jack at the back).
The PCB is quite simple. There is a UTC4558 amp and two D6282 audio amps. When I put my finger on the UTC4558 I can see and hear the speaker "fart". Although, the left...-
11-29-2025, 04:15 AM -
by i_am_patchHi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
04-30-2024, 08:20 PM -
My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...-
by silver60618Im working on a 2023 Macbook Pro M3 A2991, that had a liquid spill, has no sound. Corrosion found near Speaker Audio Amp IC. Chip ID SN012776B0,
I did find a SN012776B0 on A2442 model, but the sub and replaced it, no go. Anyone know if these audio amp IC's are cross compatible between 2021-2023 models?... - Loading...
