Onkyo TX-SR307 Turns on and then immediately off (protect mode)
  • FrozenHaxor
    • Jun 2015
    • 260
    • Poland
    Hey, I have a problem with the Onkyo amplifier, as soon as I turn it on, it waits a second then a bunch of relays click and it switches off completely, then the standby LED is blinking, indicating it went into protect mode. Did anybody have that problem with this amplifier? I checked all fuses, they read okay. When I take out fuse F6901 and F6902 out, the amplifier will turn on and stay on, and I can operate it normally except obviously no sound comes out of it. Initial measurements show no shorts across output channels, no bad emitter resistors, nothing obvious. Measuring output of bridge rectifier D6901 when switchin on shows 45V, then a relay clicks and it goes to 91V, and then another relay clicks and everything shuts down and goes into protection mode. If I put a fuse in while it's working, it sparks a little bit then goes into protect mode again in a second or so. It does not blow those 8A fuses though, and I was unable to measure any significant current across the fuse holder with multimeter, showed max 0.1A
    I have worked on amplifiers before with success, but this one has two of some sort of hybrid output modules (marked STK442-530 and a bigger one STK443-530) I assume for speaker set A and set B, and I haven't got a slightest idea how to check for bad output stage on this thing, has like 18 legs. Any help? Attached service manual.
  • Stephen
    MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
    by Stephen
    MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
    03-15-2024, 09:37 AM
  • www
    LG L192WS-BN backlight turns off after 1 second
    by www
    I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
    I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
    03-24-2024, 05:26 PM
  • redbaron1007
    Onkyo HT-R510 turns on and then immediatly off
    by redbaron1007
    I picked up an Onkyo HT-R510 that when I plug it in and press the power button will turn on and then a couple of seconds later turn itself off. When it turns on you can hear the relay click and then immediately click again and shut the power to the system off. I spent about 5 hours today trying to troubleshoot it and I did make some progress that may not actually tell me anything. It's still not really working and I'm not quite sure where to go next.
    Here's everything I've done so far.
    The first thing I did was open it up and check for any burn marks exploded parts...
    11-14-2021, 09:55 PM
  • zklgfs
    Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
    by zklgfs
    I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
    08-11-2025, 02:14 PM
  • andrhouseolly
    Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
    by andrhouseolly
    Hi.
    I kindly ask you to help me solve the problem.
    Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
    The board turns on, there is no image.
    Read more. When the power supply is connected, the front panel indicators light up briefly.
    When you press the power button, the button indicator lights up. The board works
    there is no image, there is no matrix initialization, there is no image on HDMI.
    When turned on, the fans do not spin, but when they warm up they start spinning.
    When you turn off the button, the fans spin up to full speed for a short...
    05-11-2024, 03:14 PM
