Cambridge Soundworks Basscube 12S
  • Logistics
    • Apr 2007
    • 721
    So I have a Basscube 12S with the usual problems--burned up around some power resistors, capacitors and diodes. I've seen several examples of this online. I don't recall anyone actually, coming up with an explanation for why it happens, other than poor component quality/placement/etc. So I'm all for reworking this thing as it's pretty simple, but I want to get your opinions on what to change, what to replace. I'm not keen on identifying diodes although, elsewhere on the net they are referred to as 15V Zener diodes.
    Matthew
    Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
    Re: Cambridge Soundworks Basscube 12S
    1) Bad brown glues need to be removed and then inspect the component's legs and copper traces to see if they are corroded, you can see corrosion on those tow 15V Zeners already.
    2) Using resistors to drop 35 ~ 40VDC down to 15V is not good idea, the heat on the resistors has to be managed properly but since the boards are in enclosed cabinet so there is no ventilation to help remove the heat + bad parts placement in the hot areas. They could have used another low Voltage winding on the transformer to produce +/-15V instead.
    3) So what Voltage measurement have you done so far?
    • CapLeaker
      Leaking Member
      • 8178
      I see a couple of leaking caps.
      • Logistics
        • Apr 2007
        • 721
        Your suggestions for inspection and cleanup is what I'm gonna do. Someone cut the power cord off the unit so I can't power it up, yet. The way this unit was designed, the plate amp detaches from the back, and there is a large, plastic cup that sits around the perimeter of the plate amp, and the subwoofers' wires come through that cup, and are glued shut so the airspace is sealed. But because of this, I could space the plate amp out with spacers, and add a fan for longevity. Once I get to the point of replacing components, can you give me any tips on positioning? I mean the way some resistors are suspended far from the PCB, while others are not, the way the zener diodes are raised far from the PCB, and that large, white, cement resistor, could it be replaced with a comparable wirewound to improve matters?
        Matthew
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          I suggest just getting two linear 15-20V power adapters (the ones with actual line transformers in them) and connecting them to feed power into the +/-15V rail regulator inputs. You may even be able to get away with a 12V linear adapter, if the current draw is low enough. Most 15-16V adapters should output about 16-20V DC unloaded and go down with load closer towards 15V. That should be enough to feed the +/-15V regulator circuits.
          An alternative to the above would be to use two 20V laptop adapters in series (with their grounds disconnected/isolated from each other and the wall). This will also give a nice supply for the +/-15V rails input regulators.
          Either way, both of these would be a much more efficient design and result in less heat on the board. As budm pointed out, dropping 40V to produce 15V is a bit ridiculous. I've seen other amps do it too, and the PCB always looks cooked. This guarantees that any small caps (especially from crap brands) will get cooked and likely fail after the warranty has passed.
          • caspian
            What Zener Diodes on a Linear Power Supply
            by caspian
            Dear members,
            I have a linear variable power supply with unknown brand name that I used for voltage injection.
            Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
            In addition, I discovered that its zener diodes are defective.
            I can replace the burned transistors.
            But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
            Therefore, I cannot replace the zener diodes.
            I do not want to test the zener diodes in a test circuit to discover their model or value.
            no schematics are available...
            05-26-2025, 12:38 PM
          • TinkerTron
            Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
            by TinkerTron
            Hey everyone,
            I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
            Instead, here's what's been bugging me so far:
            The schematic...
            03-06-2025, 02:03 PM
          • smurtz
            Cambridge Audio Stream Magic 6 - Power Supply
            by smurtz
            I have here a Cambbridge Audio Stream Magic 6 which does not power on.
            When opening the case the PSU appears to be faulty:
            IC1 (ICE3BR0665J), D2, the rectifier bridge, C15,C16 are dead and T2 is fried:
            I found the schematics of the PSU in the cambridge Audio CXN Service guide which uses the same:
            My problem is that I cannot find any info on T2 (SG01323) which seems to be a choke. Anyone knows how I can find a replacement & the value of that choke ?
            Thanks very much in advance...
            12-20-2024, 02:40 PM
          • maxeringade
            KRK VXT8 / 6 missing resistors / diodes
            by maxeringade
            I bought a pair of krk VXT8 for cheap and one is untouched while the other has a "mod"...
            Both work flawlessly and both sounds good, but theres a detail that i would like to investigate a little further just to be sure nothing is wrong....
            The "modded" one is hard wired to 230 volts as show in the pics and is missing 2 resistors (R65 & R66) where jumpers are in place and 2 diodes (D10 & D11) nearby missing as well as shown....
            Some of you guys have an idea of the what role these components play in the circuit and if its safe...
            12-26-2022, 11:51 AM
          • brightest_z
            Hot Air Blew Away Resistors Near Bios
            by brightest_z
            Hi All - I'm in the midst or reprogramming the bios on my gen1 Surface Laptop Studio and I accidentally blew away 2 resistors nearby the bios. I don't have another board to measure values of the missing resistors and schematics aren't available, bbut the bios is a 6x5mm Winbond WSON8, W25R256JWPQ model. The traces are conductive to Pins 3 and 7 (IO2 & IO3 respectively) so I have reason to believe they are 10k pull up resistors since IO2&3 pins are used for Quad SPI instructions.
            Does anyone with more knowledge, and experience than I, know if this is the case?
            12-11-2024, 08:34 PM
