Behringer Eurolive B812NEO cutting in and out repair
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8330
    Got this Behringer Eurolive B812NEO in for repair.
    Complaint: It keeps cutting in and out all the time.
    After opening the speaker, I saw a little spark on the AC input. Aaand? The porblem is a broken thermistor leg (R53) SCK252R0. Fixed it and she is rolling again. Same Decon caps crap in this Behringer unit.
    The schematic is for a B912NEO, but it's close enough for this one.
  • petehall347
    • Jan 2015
    • 4440
    Re: Behringer Eurolive B812NEO cutting in and out repair
    well done .. not got round to looking at Behringer broken ones i have been gifted yet . at least 2 mixers that i remember ..
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8330
      I just fixed an older Peavey powered speaker that was clipping, low volume and the heatsink got hot. The output was shorted to GND. Right now I just finished the to-do pile.
      A little note to that B812NEO. There are actually two thermistors in series. Got me a bit head scratching in why one would do that?
      • petehall347
        • Jan 2015
        • 4440
        weakest link .
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8330
          Yeah... usually one thermistor or one resistor as inrush current limiter. But why 2 in series? Specifically those dumb SCK252R0 that's hard to find with power ratings like that.
            master hoarder
            • May 2008
            • 12175
            I'm not 100% sure, but if I had to guess, they probably did this to get a higher "cold" resistance - i.e. less inrush current at cold startup.
            Now the real question is: does the circuit really need/benefit from using the two series thermistors, or can you just cram in something bigger with higher current spec and lower cold/On resistance without compromising the rest of the circuit?
            *EDIT*
            I see the input bulk filter/storage caps for the PSU in this amp are 2x 200/250V 2200 uF in series. That's quite a bit of capacitance there, so the inrush current would indeed be very high. What they should have really done with the design is use a 5 Watt or 10 Watt resistor in place of the two thermistors, and a relay coil to bypass it once the caps charge to a certain level. Of course, this would NOT have been the cheaper option, so I can imagine why Behringer didn't do it.
            Yeah, I got an EPQ 1200 amp unit in the closet with those craps. They are still okay and the amp is working. But who knows for how long.
            Then again, what can you expect when you see something is "Designed" in Germany but Made in China?
            • magneh
              Behringer Eurolive B205D repair - help identifying transistor
              by magneh
              Hello
              Got this speaker from a friend , defective. Power led comes on and off , in a loop.
              Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
              After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
              I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
              Still, I need to replace this transistor....
              06-18-2025, 02:34 AM
            • markks
              Behringer Eurolive B115D strange high voltage
              by markks
              Friend gave eurolive b115d PA speaker that wouldn't power on. I replaced a cap and it powered on. However once the metal cage that encloses the power supply board was screwed back to the control/faceplate the lights pulse on and off and no sound.
              Works fine when not screwed back together.
              I probed between metal cage and control/faceplate and I am getting a high voltage of 75v ac.
              Any thought always appreciated!
              03-31-2023, 04:28 AM
            • GerryT
              Behringer Eurolive 115W Schematic needed
              by GerryT
              Trying to repair SMPS issues with two of these units.
              10-12-2023, 10:08 PM
            • Storyteller12
              Cutting new light diffuser question
              by Storyteller12
              I have a Samsung 40” NU series tv with the melted cracked diffuser I’m fixing. I replaced the backlights and I’m planning on cutting a new diffuser out of a 55” diffuser that just melted but didn’t crack.
              Question is do I have to keep the top edge factory for the diffusing to work properly or does it matter?
              only get one shot at cutting it so wanted to make sure....
              03-30-2024, 07:54 AM
            • Longon
              Behringer Pro Mixer DJX-750
              by Longon
              Hi all....I have been using my Behringer mixer quite comfortably for a number of years now and generally it's been trouble free apart from a replacement crossfader. Recently input three channel fader began to bleed a little and causing the mixer to light up like a Christmas tree! I realise the unit is ageing now and although I'd put some hours on it over the years it's not been abused. Following the issue I planned on replacing the faders and ordered the necessary parts. In the meantime whilst awaiting the replacements I continued to use the mixer up until the channel fader started to give feedback...
              08-11-2025, 02:17 PM
