No Front channel
  • bogart219
    • May 2009
    • 195
    • usa
    No Front channel
    Yellow again,
    Man its been a bad last couple of weeks. Everything is breaking down.
    Anywho, I have a Sony STR-D911 Stero receiver. I use it with my large screen.
    Its the dolby surround. Problem, no output from front speakers. Center and rear channels working ok. Switched front speakers to the rear jacks and they worked. Seems to be in the receiver. Should you be able to read a dc voltage at the speaker jacks on the back of the unit? Any suggestions on what to check? Thanks!
  • Krankshaft
    • Jan 2007
    • 2328
    Re: No Front channel
    Speakers operate on AC the only way I trace out amp problems is with my scope.
    Check the output transistors for the front channel.
    • Krankshaft
      • Jan 2007
      • 2328
      Crap I thought I had the schematic but they cut out the actual schematic out of the PDF. It was more like a disassembly manual.
      DC on an amp output is never a good thing sounds like a shorted output transistor.
      • bogart219
        • May 2009
        • 195
        • usa
        Hey Krank, I wasn't clear. I didn't measure dc voltage on those speaker terminals. I just assume being there was a + and - for the speaker wires that it would be a dc voltage. So its ac. I believe the front channel is rated at 100 watts. What do you think the ac voltage should be roughly? I should note that the wires from the small front speakers go to the big woofer first then from there up to the receiver. This was a cheap KLH woofer with two front speakers.
        Its work fine for fifteen years however. My center channel speaker is a good one though.I'm going to tear it apart tomorrow. Too bad about that schematic.
        thanks!
        • Toasty
          • Jul 2007
          • 4171
          Probably an STK type chip amp. Left & right in one SIC.
          Do check the speaker conns for a DC voltage. I don't know if yours has speaker protection relays. Does the unit make a "click" before sound comes on? Some are very audible, other are not. Compare the front outputs DC voltage to the other working channels. Usually a DC voltage indicates a blown chip (or transistor).
          Toast
          veritas odium parit
          • bogart219
            • May 2009
            • 195
            • usa
            Toast
            Yes, unit does make click right before sound comes on. Upon more testing, I found that its not the speaker jacks but the Left (white) audio input jacks that has the problem. If I unplug (rca phono jacks), the left one, I get full sound from the right (red) one.
            With both plugged in you can hardly hear anything, real faint. I tried it on video 1,2 and 3 with my dvr and dvd player, same problem. The stero radio plays fine. I seen what looked like that stk chip there, a 16 pin. Do you know of any test I can make to clarify this? Its almost like the left audio in jacks are getting shorted out or something. Thanks for any info!
            • Toasty
              • Jul 2007
              • 4171
              Has anything changed recently? A new or different player of some type perhaps?
              If the stereo radio plays fine, then it's those input jacks, not the audio output. Check for cold solder joints or a broken or stuck piece on the jacks. Are these jacks something that you plug and unplug from often? Could be a problem in the audio jack input circuitry.
              Does the stereo still play okay if the player(s) are connected?
              Toast
              veritas odium parit
              • bogart219
                • May 2009
                • 195
                • usa
                Toast
                Toast, nothing has changed. With those audio jacks from the dvr & dvd players
                plugged in, the stereo works fine, full volume and both right & left channels. These audio jacks are not something I plug & unplug often. I will check for bad solder joints and see what else I can determine and get back with you!
                Thanks!
                • Toasty
                  • Jul 2007
                  • 4171
                  Ummm... bad cable(s)?? Plug the left in right, right in left, or just use the good channel cable to check each input.
                  Toast
                  veritas odium parit
                  • bogart219
                    • May 2009
                    • 195
                    • usa
                    Toast
                    Hey Toast,
                    If I put my ohm meter probes inside the left & right rca jacks for video 1 or 2, I read about 9 megaohms. If I do this on the video 3 jacks (located on the front of the unit), I read about 90K ohms. I disconnected video 3 from the main board then tried it. It appears to work now, however it would cut out now and then. I suspect like you said it could be the cables. Maybe I had two problems. Will put back together and see what happens!
                    • bogart219
                      • May 2009
                      • 195
                      • usa
                      Just a follow up. I left the video 3 input disconnected and put on different cables. Both my dvr and dvd players sound are working good now. Once more thanks for the support!
                      • eccerr0r
                        old X58 triple channel board... memtest86 memory speed?
                        by eccerr0r
                        Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                        Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                        Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                        06-28-2025, 09:06 AM
                      • ChaosLegionnaire
                        by ChaosLegionnaire
                        09-13-2022, 09:02 AM
                      • spleenharvester
                        Reverse engineering of 18650 4-channel tester
                        by spleenharvester
                        Hi friends
                        I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                        05-04-2025, 02:43 AM
                      • fytonv
                        7 channel NAD receiver,Need help identifying a suitable cap replacement
                        by fytonv
                        My 7 channel NAD receiver has audio quality and volume issues on 2 of the channels. Sometimes they work and sometimes they don't. Sometimes they're at about half the dB level of the left channels, and then they cut out entirely. Powering off and on the receiver fixes it for a bit.
                        Without much experience to really know for certain, they only apparent issue I can see is with these electrolytic capacitors on the power supply. Bulging = bad, correct? I'm looking for replacements but I'm unsure what leeway I have with the temp ratings. Are there any other specifications I need to worry...
                        09-08-2022, 09:52 PM
                      • CDNBrewer
                        Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                        by CDNBrewer
                        Hello Everyone,
                        I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                        Symptoms:
                        • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                        • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                        • I swapped the Left and Right surround
                        08-05-2025, 09:29 PM
