JBL CSMA1120 amplifier
  • Bterrier
    • Apr 2018
    • 72
    I recently picked up a jbl csma1120. Seems to work well, however the bass and trebles knobs are missing. I wouldn't mind if there were still a way to adjust the bass and treble, but there is nothing to turn, just printed circuit board behind the holes.
    Is this repairable? How to these knobs work and install. I was expecting to see a shaft of a potentiometer where the knobs are missing.
  • petehall347
    • Jan 2015
    • 4426
    • United Kingdom
    Re: JBL CSMA1120 amplifier
    pictures please .
    is there a remote ?
    • Bterrier
      • Apr 2018
      • 72
      No remote. It is more of a commercial amp. It can run 4 or 8 ohm loads as well as 70v and 100v systems.
      I will upload a few pics later tonight.
      https://jblcommercialproducts.com/en.../csma-180-1120
      • R_J
        • 9535
        Looks like they are/were screwdriver adjustments, no knobs, so they are either pushed in or broken
        • Bterrier
          • Apr 2018
          • 72
          Yes, the plastic piece/knob that you would turn with a screwdriver is missing. Im tryng to find a solution. If I can get those pieces from JBL, how would they be installed. Im confused how they work
          • Bterrier
            • Apr 2018
            • 72
            Photo attached. Printed circuit board within the holes. It actually looks like the head of a screw, and the lighting wasnt so good in my work area, I actually tried to use a screwdriver to turn it.
            There are also 2 pads/contacts above the screw print, I'll try to get a better photo when I can
            • R_J
              • 9535
              It looks like the controls are still intact and could be adjusted with a small screwdriver if needed, getting those little extentions from jbl???, good luck
              if not this pdf might help
              • Bterrier
                • Apr 2018
                • 72
                No, it can't be adjusted with a screwdriver. This is my issue.
                I know it looks like a Philip's screwdriver would work, but that is only an image of a Philip's screw head which is printed on the circuit board. There are no moving parts.
                • R_J
                  • 9535
                  Those are APC brand pots (apc spain), just like in the picture I provided (3rd pot), the blue is the pot, the white with the cross is the part that turns, and the black is what is left of the broken knob. You don't use a philips, you use a small flat blade, like a jewelers screwdriver.
                  Whats left of the black knob might be able to be pushed out, It depends on how the pot is mounted.
                  The pdf I provided has shafts that should work if you can not get the originals from JBL
                  If it is a CA6 size pot Page 4 number 6031 looks similar, If its a CA9 page 12 has the shafts
                  • Bterrier
                    • Apr 2018
                    • 72
                    Thanks for the info. After further inspection, it appears you are correct. It seems as the plastic extension is broken off flush with the pot. How would I go about attempting to remove the broken piece?
                    If I am unsuccessful, I will replace the pots but I am trying to avoid that if possible because everything seems to be functional.
                    • R_J
                      • 9535
                      Just use a small screwdriver that fits the slot, that black plastic should just push out the back of the pot. It should take very little force so no hammer
                      • Bterrier
                        • Apr 2018
                        • 72
                        Thanks I didnt realize the back was open. All set now, just need the extensions.
                        • Doyle1
                          BMW OEM Amplifier 9 264 953 – Help Identifying Missing SMD Component
                          by Doyle1
                          I'm currently working on a BMW OEM amplifier, part number 9 264 953, taken from a 2011 BMW F10 535i.
                          There's visible PCB damage near the NXP 74HCT193 chip, where a small SMD component is missing or burned. Based on shape and size, it's most likely a ceramic capacitor or resistor in 0603 package.
                          I recovered the loose component (appears unmarked, like a ceramic cap) and have detailed photos:
                          – PCB with missing part
                          – Close-up of recovered component
                          – Full view of the board
                          I'm looking for:
                          - The correct part...
                          05-31-2025, 12:09 PM
                          RCA WHP141 wireless headphones wired up
                          by momaka
                          OK, this one dates back to 2015! I thought I had posted this, but realized I didn’t when I posted a picture of something else. So here it goes…
                          Back in 2015, I bought a pair of RCA WHP141 wireless headphones at Micro Center for $2. I even mentioned it in the best cheap/free scores thread right here. Just forgot to follow up with that.
                          As mentioned back then, these are (were) 900 MHz FM wireless headphones. No modern day Blutooth or anything like that. I knew they wouldn’t be great headphones or even that good… but the price was right! So let’s take...
                          02-22-2023, 06:28 PM
                        • eduaqa
                          Amplifier - bad sound when loud sound on bass
                          by eduaqa
                          I'n trying to fix a M&S SYSTEM DMC-1which have following problem:
                          I'm using FM station to do this fix, I works perfect if volume below around 8 or if bass is set to zero, the sound can go to 20 without problem, but if I set bass to maximum and try to go over 10 the sound comes distorted ... I saw a video on YouTube the person saying about the main capacitors on the power portion, but I disconnect the main transformer and inject direct to the capacitors PINs my bench power supply -23v 0v +23v, but still distorted so I think the problem is not the capacitor neither the transformer...
                          08-06-2022, 11:28 AM
                        • ein_individuum
                          Missing Capacitator Intel I9-12900KF CPU
                          by ein_individuum
                          I bought a use Intel I9-12900KF CPU and i received it damaged. But it looks like only one component one the backside is missing. But the solder pads looks fine.
                          I already "googled" it and compare the backside picture of other LGA1700 12th Gen CPU. They look all the same, no matter if its an I9 or an I3, even the Pentium. And at that spot should be a capacitor.
                          Does anyone have a schematics or assembly diagramm of the alder-lake cpu-backside? Or just know what size and value i need to replace the missing capacitator.
                          08-06-2025, 01:36 AM
                        • ugamazing
                          820-02020 PPBUS_AON missing
                          by ugamazing
                          Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                          Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                          02-05-2025, 04:21 PM
