Harman Kardon PM655vxi problem
  • tmho
    • Jun 2016
    • 39
    I got a Harman Kardon PM655vxi integrated amplifier from a friend. The sound from it is very good. But the right channel stops working intermittently.
    I have tested it with a headphone and so it is not be the problem of the right speaker or the source. I have done the DC balance adjustment and idling current adjustment. I have tried several times cleaning the switches with MG Super Contact Cleaner (https://www.be-electronics.com/product_p/801b-125g.htm). But the problem still exists.
    When the right channel is not working and the "mono mode" switch is turned on, the right channel will have sound again.
    Could someone please kindly advise how I can try to fix the problem?
  • tmho
    • Jun 2016
    • 39
    Re: Harman Kardon PM655vxi problem
    I just found that the problem is sometime the right channel is not working and sometime the left channel is not working.
    • CapLeaker
      Leaking Member
      • 8331
      did you check it for cold solder joints? Next time it acts up take something non metal, like an old toothbrush or wooden spoon an press a little around on these boards? Can you upload some high resolution, straight shot pictures here?
      • tmho
        • Jun 2016
        • 39
        Thanks for your suggestion.
        Actually, I had checked cold solder joints on the PCB which connect to the inputs. I don't have much experience on this. I found just a few suspected joints. I had resoldered them and the neighbouring ones but no luck.
        Recently, somebody also suggested this to me and gave me a link (http://www.berlin-repariert.de/harma...f-empfindlich/). The link is in German which I cannot understand. But I can see that they were resoldering the joints on the main PCD. I will follow that. But before that I will take some photos and show here.
        • CapLeaker
          Leaking Member
          • 8331
          I did read that thread you posted above (I can understand German). Basically he cleaned these boards and then resoldered cold solder joints. There were 2 boards he worked on, pic 3 and 7. Sometimes you need a magnifier to see the bad solder joints.
          • tmho
            • Jun 2016
            • 39
            Did he get the same problem I am having?
            • madan1
              • Nov 2016
              • 722
              • Bulgaria
              If you have signal on the headphones, then check the output relays ( if this amp has such ). Those relays are between the power amplifiers and the speaker terminals. They switch on few seconds after the power supply and also are used to route the signal to different terminal configurations ( sp.A, spB, sp A+B, bridged, etc.. ). They also experience mechanical stress and tend to get cold solder joints. The symptoms are what you have described - signal interruptions to one or more speakers.
              Another easy way to check if the signal is interrupted before or after the power amplifier is to measure the dc V on the speaker terminals. If there is no V then most likely the path is interrupted after the power amp.
              • tmho
                • Jun 2016
                • 39
                • madan1
                  • Nov 2016
                  • 722
                  • Bulgaria
                  Bad link, but if the amp is like this one
                  then the relays seem to be substituted with that rotary selector connected via the metal rod to the front panel.
                  • tmho
                    • Jun 2016
                    • 39
                    I have taken some photos of the PCBs. On those suspected cold joints, I have marked them with red circles.
                    • madan1
                      • Nov 2016
                      • 722
                      • Bulgaria
                      Leave that board for now.
                      If you can start the amp, see if there is any V on the output terminals when the channel(s) is experiencing the problem.
                      • tmho
                        • Jun 2016
                        • 39
                        Thanks for your reply.
                        I was told by someone that there is no output relays.
                        Will check the dc V on the speaker terminals later when I find it not working.
                        The picture you posted is the one I have.
                        • tmho
                          • Jun 2016
                          • 39
                          I have just opened up it. Will check that later when it has the problem.
                          • madan1
                            • Nov 2016
                            • 722
                            • Bulgaria
                            Check this board for bad solder joints and clean the rotary selector
                            p.s. just checked the schematics - the headphone signal comes from the same power amp that drives the speakers. This means that if you have good signal on the headphones, the problem occurs between the power amp and the speaker terminals (the outlined board on the picture).
                            • tmho
                              • Jun 2016
                              • 39
                              Thanks for the suggestion.
                              I have already done some resoldering on the above suspected cold solder joints. Now the amp has been closed and hooked up again. I will follow your suggestion when the problem happens again.
                              • tmho
                                • Jun 2016
                                • 39
                                After about 10 days with no problem on the left or right channel, today I found the left channel with problem again. I was listening to songs using the AUX input while doing something on the computer. Suddenly, I found that it seemed no sound from the left speaker. I went to the left speaker and confirmed that there was no sound. Then I took out my multimeter and found the DC voltage at the left speaker was -36mV. But after less than a minute, sound was coming back from the left speaker.
                                Next time when I have time, I will open it up and check on the board suggested by madan1.
                                • madan1
                                  • Nov 2016
                                  • 722
                                  • Bulgaria
                                  I guess you will find similar mV on other channel, which basically means that the connection between the speaker outputs terminals and the power amplifier is fine. This also means that you should experience the same problem on the headphones.
                                  Next time when the problem occur, plug in the headphones and see if they work.
                                  • PowellSkier
                                    Harman/Kardon AVR 645 returning to stand-by after a few seconds.
                                    by PowellSkier
                                    A Harman/Kardon AVR 645 repair has been a hobby of mine for the past several years. My latest attempt involved the purchase of a DOA unit for part swapping and testing. The original AVR would power up then shut down after a few seconds. I completely tore down both units, found a couple of bad components and reassembled one of them. Same issue, no speakers connected. After extensive research I found a repair document from Harman/Kardon that explains the protection circuit in fantastic detail and provides specific test points for each fault (power, DC detection, overload & power) and the voltage...
                                    06-17-2024, 11:43 AM
                                  • dicky96
                                    Hitachi V19B01922 Channel Tune problem
                                    by dicky96
                                    Hi Guys
                                    I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
                                    He also has an LG TV, so three screens in the bar
                                    I installed three Satlink ST-6503 DVB-T Modulators
                                    This model https://www.aliexpress.com/item/32916553905.html
                                    These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
                                    02-09-2023, 09:20 AM
                                  • funky2x
                                    Harman kardon onyx studio 7 Smd code
                                    by funky2x
                                    Cant find what smd code Y0DVA.
                                    sitting in Harman kardon onyx studio 7. Appreciate any help.
                                    05-29-2025, 03:44 PM
                                  • eccerr0r
                                    old X58 triple channel board... memtest86 memory speed?
                                    by eccerr0r
                                    Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                                    Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                                    Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                                    06-28-2025, 09:06 AM
                                  • PowellSkier
                                    Cement resistor swap in Harman Kardon AVR
                                    by PowellSkier
                                    Would I be able to swap a 0.27 Ohm Kx2 5W resistor for a 0.22 Ohm Jx2 5W resistor in a Harman/Kardon AVR? Cement type.
                                    06-04-2024, 06:41 PM
