Sony Str-Db 840 Completely Dead
  • coojoe_213
    • Nov 2015
    • 105
    • bulgaria
    Hi everyone. My amp is dead, no std by, no relay click. All fuses is perfect, primary on main transf. is excellent.
    On the AC Board, after diode on pin 2 (12V) i have 16v, pin 3 (P_OFF) i have 12 v, and pin 4 (P.RY)i have 0V. All diodes, fuses and resistors on AC Board are fine.
    On IC1206 (NJM2103) pin 5 i have 16v, but on 8 pin i have 0V.
    On Q1205 i don't have 6.8v/6.2v only 16v on the collector.
    My question is... in this amp, which parts /elements/ responsible for stand by voltages. I have 0.7v on stand by, but i can't see on service manual, where is a stand by supply (5v)?
  • redwire
    • 3910
    Re: Sony Str-Db 840 Completely Dead
    Q1205 should always be on and making standby voltage. IC1206 NJM2103 pin 3 turns off Q1205 when the voltage is up: When the amplifier is on, then IC1205 takes over to provide +5.6V B+.
    P_OFF is 1/2wave rectified pulsing DC.
    If Q1205-E is 0V then R1279 should turn it on. Either Q1205 has failed or IC1206 is keeping it off. I think the transistor is bad, usually Sony has no heatsink and they run hot.
    • coojoe_213
      • Nov 2015
      • 105
      • bulgaria
      I don't think Q1205 is bad. If i have 5v on pin8 ic1206 decided all is normal in proccessor, after that IC1206 switch 6.8v on pin 3
      • coojoe_213
        • Nov 2015
        • 105
        • bulgaria
        I replace q1205, but all is the same.
        • redwire
          • 3910
          First, check the power supply voltages- they are always on from the +12V.
          +3.3V IC1203 , +5V IC1204 , +5V IC1208 , +5V IC1207, +6.2V IC1205 which makes +5.6V
          I would follow the signal from power button pg. 29 CN5106 pin 7 turns on display controller AND signals IC1201 at pin 105.
            What DC V do you have on the Base of that Q1205?
            Whar RESISTANCE do get between GND and Emitter of Q1205?
            • coojoe_213
              • Nov 2015
              • 105
              • bulgaria
              I don't have any voltages on +3.3V IC1203 , +5V IC1204 , +5V IC1208 , +5V IC1207. On service manual i will have this voltages when main transofrmer work. Main transformer will work when relay RY901 ''close contacts''.
              - On the Base of Q1205 I have 1.28V, emitter 0.78V.
              Resistance between GND/Emitter Q1205=8.3Kohm
                Can you please report the Voltages on each pin of the IC1206?
                We already know that
                pin 3 is 1.28V
                PIN 8 is about 5V (that is an open Collector, I wonder if that pin did go low during reset).
                • coojoe_213
                  • Nov 2015
                  • 105
                  • bulgaria
                  pin 3 is 1.28V
                  IC1206 Voltages:
                  1 - 1.33V
                  2 - 0.25V
                  3 - 1.28V
                  4 - GND
                  5 - 16.5V
                  6 - 2.79V
                  7 - 1.26V
                  8 - 0.85V /When i press Power button, the voltages on pin 8 are again 0.85v/
                  • redwire
                    • 3910
                    I got the wire crossed reading schematic. Transformer T902 is always powered, making +12V which goes to Digital Board ripple filter Q1205, not the Vreg cluster.
                    Q1205 is a 2SD1733 Darlington, but OP is measuring only 0.5V E-B voltage, so is it the correct part or it's hFE is too low?
                    Or with pin 3 not up, I'm wondering if the ripple filter is driving a shorted load.
                    Q1205 would get hot then.
                    IC1206 is open-collector so I can't see it pulling down to 1.28V
                    • coojoe_213
                      • Nov 2015
                      • 105
                      • bulgaria
                      Q1205 is NOT Darlington
                      • redwire
                        • 3910
                        From service manual: Q1205 8-729-048-78 TRANSISTOR 2SD1733-TL-QR
                        Panasonic datasheet is Darlington TO-220
                        Rohm datasheet is BJT 80V 1A 2W hFE 82-390 DPAK
                        Does Q1205 get hot?
                        • coojoe_213
                          • Nov 2015
                          • 105
                          • bulgaria
                          2SD1733 is a NPN silicon transistor, not darlingon. You can see your web link / / is wrong. 2sd1733 is not hot, absolutly cold.
                          • redwire
                            • 3910
                            Q1205 is off (and assume it is a good part), check C1218 shorted, high value R1279, C1221 low capacitance.
                            Or... IC1206 bad and keeping Q1205 off.
                            When pin 2 is above 1.235V, pin 3 goes low which turns off Q1205.
                            The datasheet shows the comparator used as a shunt voltage regulator, which I think is what's going on here.
                            Otherwise, check the 0.1uF capacitors- but I don't expect these to fail or we have to use a scope.
                            • coojoe_213
                              • Nov 2015
                              • 105
                              • bulgaria
                              I check before 5 days c1218 and R1279, they are fine.
                              C1223/C1225/C1222/C1224 are SMD elements, and i can't check with my esr meter.
                              • redwire
                                • 3910
                                I think IC1206 is not working, if as you say Q1205 is good.
                                You could put oscilloscope on pin 3 and see if it is steady DC, or oscillating if C1221 or other capacitors are bad.
                                IC1206 maximum VDD 20V and right now you have 16V, so a mains surge might have damaged the IC.
                                Maybe budm has other ideas to try.
                                • coojoe_213
                                  • Nov 2015
                                  • 105
                                  • bulgaria
                                  I remove IC1206 to check voltages without this chip. When i remove IC1206 relay901 close contacts????
                                  Voltages on IC1206 without IC1206:
                                  1. - 0V
                                  2. - 1.67V
                                  3. - 9.07
                                  4. - GND
                                  5 - 9.36V
                                  6. - 1.82V
                                  7. - 1.51V
                                  8. - 6.85V
                                  What do you think?
                                  Do you know any equavalent on NJM2103? I my country there is no any chip NJM2103.
                                  EDIT: Now /after 20 min/ relay RY901 doesn't close contacts without njm2103
                                    I wonder why the VCC pin 5 only shows 9.36V without the IC in place. I need to look at that schematic again.
                                    'EDIT: Now /after 20 min/ relay RY901 doesn't close contacts without njm2103' Try using 100 Ohms resistor momentary between GND and the Reset pad and see what happen.
                                    • redwire
                                      • 3910
                                      Um, don't run it with the IC taken out!
                                      Q1205 will be full on and overvoltage the standby rail. So you are getting 9V, not 6.2V at Q1205 emitter. Which means B+ is 8.4V not +5.6V
                                      Vcc pin 5 sags down to 9-10V when loaded I think, and up to 16V with no load.
                                      If you cannot get a new NJM2103, I would put in TL431 or a 5.6V zener to regulate Q1205 output (emitter) at 6.2V max.
                                      Then you just need a RESET pulse circuit.
                                        You can put in 6.8v Zener of the transistor so the Base Voltage will be 6.8V, that will give you about 6.2V output at the Emitter since it is an Emitter follower circuit, output = Vzener - Vbe.
                                        • max-power
                                          Dell E6540 laptop completely dead after dssasembly
                                          by max-power
                                          Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
                                          that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
                                          After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
                                          03-24-2025, 08:49 AM
                                        • Zaprodk
                                          Sony KD-55X8507C Completely dead
                                          by Zaprodk
                                          Hi.
                                          I have a Sony KD-55X8507C on the mending table today.
                                          It appears completely dead, no status LED's lighting up. Even though it's acting completely dead, the power supply is running and the heatsinks on the main ASIC's do heat up, so it's just not starting properly.
                                          This thread has been a lot of help since someone posted an excerpt from a schematic that contains the correct LED driver chip. without that pinout, anyone's guess
                                          The power supply has two boost converters, each run 5 strings of LED's. All LED strings i tested to have a Vf of...
                                          08-07-2020, 04:06 AM
                                        • wangbreeze
                                          T480s random shutoff and then completely dead
                                          by wangbreeze
                                          Hello Gurus,
                                          I got a ThinkPad T480s. It was running fine but suddenly started random shut down. When it turned off, I had to push the reset pin to bring it back to life. But it got aggressively worse and became completely dead. No charging light, no life.
                                          I did some initial diagnostics with just the board (no battery, nothing attached, and no CMOS battery as well)
                                          Initial testing of the coil resistance seems to indicate no dead short. The only low resistance I measured was at PL701. It reads 38 ohms.
                                          charger gave - 20V - ok
                                          U101B
                                          02-03-2024, 04:57 PM
                                        • thstuff
                                          Sony OLED XR-77A80J - Initially dead, now 4 Flashes
                                          by thstuff
                                          A) TV initially dead
                                          B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
                                          C) Was able to perform a Reset from Settings menu and completed out of box configuration.
                                          D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
                                          E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
                                          12-26-2024, 09:10 PM
                                        • pavski
                                          Completely dead MSI z490 tomahawk
                                          by pavski
                                          Trying to troubleshoot MSI z490 tomahawk board and would appreciate your help. The board is completely dead and shows no activity when the power button is pressed.
                                          I have tried to look at the Superio, the PSIN signal seems to be correct (goes from 3.3V to 0 on button press) but the voltage on PSOUT pin is quite low. I
                                          t is only 0.8V which seems to be incorrect but goes to 0 when the button is pressed.
                                          Can you please let me know if this is indeed incorrect and what else should I look at next?
                                          Thanks!
                                          06-02-2024, 02:42 PM
