Need help, fixing onkyo tx sr507, bad channel, blown fuse.
  • cwolford
    • Mar 2017
    • 46
    onkyo tx sr507:
    Had it a long while, been through a lot and dont have funds for new one.
    Found a nice schematic. All tho I am not the best at reading it.
    I don't know all my components or how to test them. I do have a nice soldering setup and a alright DMM. could make a make shift bench top psu if need be.
    Short of it:
    It went in to protect mode aka blinking light. I turned it back on, smoke came up from PSU area. Fuses blown.
    Was it the fuses that smoked?
    looked it over, got new fuses. they went bad too.
    IT POWERS ON, IT HAS VIDEO OUT THE HDMI. NO SOUND.
    don't recall how to check transistors, but I know they should not be shorted.
    based off schematic Q6060, q6050 are the ones shorted. seem to be front left.
    I know I need to replace them. what else do i need to check?
    Until i get parts can I rob the parts from zone 2 aka not the 5.1 but the extra set. I dont use them, if i understand right the 4 transistors on the left in schematic are for zone 2 they seem to be the same stuff, numbers and all.
    The day it went bad:
    there was a lot of power surges, looked out side and there was 2 street lines arcing.
    IT had just been re hooked back up from its hiding spot, as i was out of town.
    no other equipment on my surge bar took damage.
    thanks for your time and help.
    p.s. will get photo up soon, but pdf is nice.
    edit: i only use front left, front right, center, and sub out via LFE.
    would like to test all them (dont know wher LFE , may know where rest is, would love to be told on all tho.), was going to finally get my last 2 speakers for 5.1 then this happens
  • tibimakai
    • Jan 2012
    • 3680
    Re: Need help, fixing onkyo tx sr507, bad channel, blown fuse.
    I don't have experience with those receivers, only with the newer ones, but I would check all the components at that channel.
    On the newer ones, the pre-amp section is on a vertical board, if yours is the same way, I would remove that board and go through all the components at that channel. Do the same thing on the main board, at that channel only.
    You could just cut the legs of the final transistor legs, and see if everything start working.
    • dobrykamil
      • Jun 2013
      • 63
      Based on my experience with Onkyo receivers, every single unit with blown final transistors has also had shorted Qs like Q6030,6040.Check emiter resistor R6100 and base resistors R6080, R6090, R6020, R6040. Look for dry joints in pre-amp part too. In many cases, I've seen blown C6040 capacitor - I always replace it as a precaution. Basically, if you don't replace all dodgy components in pre-amp, your final transistors will go pop again.
      • Babbar
        by Babbar
        04-12-2024, 01:12 AM
      • drscoot
        HP X360 convertible battery blown fuse error, not charging
        by drscoot
        HP Modelnumber: 14-dh0061nb​
        This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
        The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
        I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
        And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
        All these 3 batteries are charging...
        12-15-2023, 05:54 AM
      • beetle1303
        Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
        by beetle1303
        I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
        On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
        01-13-2025, 08:49 PM
      • jesterace
        Samsung UE46ES8000 Blown fuse but no other signs of short
        by jesterace
        Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
        09-11-2024, 03:14 PM
      • MegaZAC
        Onkyo TX-SR805 noise in one channel
        by MegaZAC
        Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
        Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
        There's some logic behind it. As soon as I select an input I get only left...
        04-23-2025, 10:09 PM
