Placing magnet near microphone (bad idea ?)
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. Would it have a negative impact on audio quality if I placed a magnet near a mic ? Let me explain, since the question is not what you'd expect. We're not talking about pro audio gear here: I got myself one of those small spy recorders disguised as a USB flash drive and the audio quality is pretty impressive and so is the battery life, but when it comes to "deploying" it where I need it, I'm planning on snapping it under the edge of a table and have two options: velcro or attaching a magnet to the flash drive which would then attach to a screw head conveniently located where I need it. Either option would be just as easy to pull off, but the magnet would make it more versatile and would enable me to use it in other places as well, whereas with the velcro, I'd first have to stick a piece of soft material that the velcro can stick to where I need it. Mind you, we'll leave any details about the WHY part of this project out of the discussion for now
    Long story short: magnet near microphone ? Will it do ANYTHING to the audio ? I believe, and I'm not an audio expert so please don't quote me on this, that it uses an electret microphone. I didn't take it apart to know exactly, but from what I've read electret microphones seem to be more common so I'm going to ASSUME it's one of those.
    Wattevah...
    • 31305
    Re: Placing magnet near microphone (bad idea ?)
    there are many mic;s
    moving coil - bad
    crystal - wont give a shit
    electrostatic / electret - not sure.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8716
      It's probably electret indeed, and likely the distance from the magnet and the strength of the magnet won't affect recording. Worst case is that your sound will get slightly muddled.
      I think I'm more interested in why now. I hate spies.
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        • Romania
        Well TBH it's my own private space, so it's not like I'm doing anything illegal
        Wattevah...
        • Khron
          • Sep 2006
          • 1350
          • Finland
          If it's only a recorder, and with no switchmode circuitry on the power side, there should be no issues.
          If it was (also) a radio transmitter, that'd be a different story
          Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
            Philips F9217L-50R speakers – build quality impressions and DIY surround repair
            by momaka
            More Lo-Fi speakers and another DIY surround repair. The patient this time: a pair of Philips F9217L-50R speakers from a budget Philips rack/component system from the '80's. The system belongs to my brother in-law… or actually his parents. However, they didn't want it when they moved houses and he liked it anyways, so he ended up keeping it. It's a pretty cool-looking vintage system with a wood/veneer cabinet and shelves for records and cassettes. Unfortunately, I didn't get a chance to take a picture of it or get the model #'s (but maybe next time I visit, if anyone is curious?)
            02-15-2022, 12:43 AM
          • 3lmosldetumama
            Acer A315-53G C5V01 LA-E891P Rev:2A backlight error
            by 3lmosldetumama
            Hi, i have this Acer that when is power on with adapter is working fine, but if you disconect it, the backlight doesnt work, and if you turn it on with an adapter and then disconects it, the voltaje on pin 1 2 3 od edp lows to 8v, if i pass a magnet simulating the lid close it tries to start the backlight but cant, the 3.3v is ok on the lid and when magnet is on it goes normal to 0v, so is not that, and went you are in this state of only battery and then conects the adapter it doesnt recover untill i close and open the lid so, is like when you are in battery mode it goes to s3 mode but it happens...
            11-19-2025, 08:24 PM
          • BOSCHNJAK
            by BOSCHNJAK
            ABOUT ME INTRODUCTION FILE
            2
            024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
            2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
            2022 BEV, PROJECT ?
            2021 BEV, PROJECT ?
            2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
            2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
            12-28-2023, 02:09 PM
          • yaso143
            acer an515 la-191pr1a
            by yaso143
            Hello if anyone can help im currently working on a acer nitro 5 no display but the capslock responds when you turn on the device
            here is my measurement
            +INVPWR_B+ 19v
            PCH_BKL_PWM 0v
            EC_BKOFF# 0v
            EDP_HPD_R 2.4v
            +LCDVDD 3.3v
            PANEL_OD_EN .754v
            I also checked the lid sw# it works just fine the voltage with out the magnet is 3.3v and drops down to 0 when magnet is engaged
            Ialso used a known good lcd but still no display
            07-17-2025, 12:38 AM
