Yamaha RX-V675, No sound
  • srt1
    • Aug 2013
    • 177
    • india
    I got yamaha rx v675, it have no sound , i already done factory reset but still no change. i checked zone 2 line output ., there i am getting sound ,
  • srt1
    • Aug 2013
    • 177
    • india
    Re: Yamaha RX-V675, No sound
    ANYBODY CAN help me for this
    • srt1
      • Aug 2013
      • 177
      • india
      i am geting sound in pure direct mode only
      • srt1
        • Aug 2013
        • 177
        • india
        Originally posted by srt1
        i got yamaha rx v675, it have no sound , i already done factory reset but still no change. I checked zone 2 line output ., there i am getting sound ,
        help please
        • AsRock
          • Mar 2016
          • 21
          • US
          You tried going though the diagnostic options and see if that picks any thing up ?.
          I would check the front panel for dry joints, would all so check if analog and digital are effected though different rear ports too.
          I cannot really help you but thought i would try at least.
          • srt1
            • Aug 2013
            • 177
            • india
            I tried everything.. i am getting sound only when i am connecting analog signal in pure direct mode.. in any dsp mode no sound coming.. also i tried rest, after that i tried to upgrade firmware but its always failing..
            • mmartell
              • Oct 2013
              • 3189
              DSP/DTS IC has failed many times in Onkyo, Harman etc maybe the case here.
              • srt1
                • Aug 2013
                • 177
                • india
                But how i confirm dts chip already failed.if it failed i want replce it
                • AsRock
                  • Mar 2016
                  • 21
                  • US
                  Yes that would not surprise me, seems to be a common issue with AV HDMI devices and typically due to heat.
                  In some cases people have heated up the DTS chip to get it working, replacing it will not be any fun at all.
                  • srt1
                    • Aug 2013
                    • 177
                    • india
                    DTS chip number is D80YK113CPTP4 . is this ic also premature failing as in onkyo?
                    • srt1
                      • Aug 2013
                      • 177
                      • india
                      Hii i replced the dsp chip but still no sound ,when i am updating firmware its failing and showing error code 0010 also i check in daignostic menu its showing dsp bus NG ,same as before..what will be the couse
                      • srt1
                        • Aug 2013
                        • 177
                        • india
                        Any one can help me , what i do next?
                        • Sojke
                          • Apr 2017
                          • 131
                          • Serbia
                          Any follow up on this?
                          • XgN
                            • Apr 2019
                            • 7
                            • Lithuania
                            Would like to revive this topic.
                            Currently working on my Yamaha RX-V673 which also has infamous D80YK113CPTP4 DSP IC. When PCBA is bent or small portion of heat applied (e.g. hot air) to the IC, DSP is OK (viewing via Service Mode, C category, DSP1 BUS: OK/NG) and NG when cooled.
                            Has anyone tried replacing to a new D revision chip from aliexpress? Not quite sure whether DSP IC is bad itself or cracks in tracks/vias.
                            • repairguyone
                              • Oct 2020
                              I had a problem when loading firmware had error 0010, heated the chip firmware installed OK but when chip cooled no sound.
                              I was thinking of changing DSP IC don't know if it has to be pre programmed.
                              • jjne
                                Yamaha RX V675 sound issues
                                by jjne
                                I have an old Yamaha RX V675 receiver which is starting to develop issues with the sound, although it doesn't quite match up with what folk normally report with these.
                                From cold, the sound cuts in and out. When this happens the amp is losing sync with the optical input (speaker graphic disappears from the front panel). But this is not resolved by putting the unit into pure direct mode. After a couple of minutes this resolves, although there are occasional clicks from the speakers after that.
                                At first I thought it was either a speaker relay or the DSP, but I don't think...
                                Yesterday, 07:01 AM
                              • masterm
                                JVC LT-43C888 (manufactured by Vestel) does not start after trying factory reset, details below
                                by masterm
                                TV: JVC LT-43C888 (purchased in 2018). This is a smart TV with Netflix, Youtube, Freeview and other applications via 'Viewd' app store
                                Problem with TV:
                                - Netflix stopped working so i tried to do factory reset from the TV menu.
                                - I confirmed on-screen but the factory reset did not happen even. It did not take me to 'first-time installation' screen as mentioned in the manual.
                                - After waiting for some time, the TV went into a boot loop.
                                - JVC logo comes on the screen and LED light flashes for some seconds, then it reboots again and the same thing happens
                                04-30-2024, 03:03 AM
                              • AlexVG
                                YAMAHA CLP-550 without of sound
                                by AlexVG
                                Hi.
                                I have an old YAMAHA CLP-550 without sound. (Some times I can get some kind of noise or distorted sound)
                                I have replaced all green marked elements, but it gave me nothing.
                                The IC12 chip LC9116A-105 (red marked) remains under suspicion yet.
                                But it is custom YAMAHA's chip, and I can't find any information about it.
                                Maybe somebody came across with the same issue?
                                Any information will be very useful. I will be very appreciated.
                                Thank you....
                                06-08-2025, 09:29 AM
                              • ChaosLegionnaire
                                by ChaosLegionnaire
                                09-13-2022, 09:02 AM
                              • maleksa
                                Yamaha MOX8 boot freeze and distorted sound
                                by maleksa
                                My Yamaha MOX8 synthesizer recently developed two issues.
                                Firstly, after booting up, it operates as normal. However, after about 5 minutes, the sound starts to get distorted (broken up screeching sound) almost like putting it through a guitar distortion pedal. After a while, the distorted sounds will go away for a while and comes back. At times, the synthesizer will also freeze I need to power off and on again.
                                Secondly, when powering off and on again, there will be times where the synthesizer will freeze during the boot sequence (freezes at the MOX8 Opening Screen),...
                                11-07-2024, 03:28 AM
