Philips HTL2160 soundbar NO power problem
  • DjKrish
    • Oct 2012
    • 354
    • SG
    Re: Phillips soundbar NO power problem
    Originally posted by budm
    I would change the cap to 1000V, the 22 Ohms should be higher Wattage otherwise it will probably burn up again. That snubber circuit is design for reducing the Ringing/Overshoot based on the circuit as a whole, so the only way to find out is to use the scope and a differential probe to analyzing what is going on.
    Sadly i dont have a scope But i would change the resistor to higher wattage and the cap to 1000v
      That will be a good idea. So is the unit still running?
      • DjKrish
        • Oct 2012
        • 354
        • SG
        Yes the unit running fine till now but im afraid it will blow sooner or later so i better put a higher wattage on that resistor. Should i upgrade that cap or leave it as it is?
          I would definitely upgrade the cap to higher Voltage.
          • DjKrish
            • Oct 2012
            • 354
            • SG
            Ok, CAP upgraded to 1kv. Added another one more resistor in line as that's the highest wattage the suppliers have here. That should be fine right?
              Only time will tell since you have no way of analyzing the snubber circuit to see if it is doing its job properly or not.
              • DjKrish
                • Oct 2012
                • 354
                • SG
                #27
                Hopefully . Been running for few hours now. So far so good. Fingers crossed
                • PantherDave
                  by PantherDave
                  Hi all!
                  05-29-2024, 02:01 PM
                • GLISIT
                  by GLISIT
                  01-16-2025, 02:29 PM
                • _AcE_
                  JBL Soundbar 2.1 Deep Bass PSU No DC Power Output (Detailed, w/ Schematics)
                  by _AcE_
                  I have two of these soundbars, both with the exact same issue. The soundbars were hit by lightning and no longer power on. The PSU does not output any voltage on the DC side. When plugged into mains, the DC output is a stone-cold 0.0 volts. The AC side of the PSU seems to be functioning correctly (as far as I can tell). When checking the plugged-in PSU with my thermal camera, the OB5269CP PWM controller (U1) and the two resistors (R12 and R13) pulse on and off. These run to the positive DC side of the bridge rectifier (among other components along the way).
                  There's no physical damage...
                  08-10-2025, 09:27 AM
                  by sam_sam_sam
                  03-31-2024, 02:12 PM
