Philips HTL2160 soundbar NO power problem
  • DjKrish
    • Oct 2012
    • 354
    • SG
    Re: Phillips soundbar NO power problem
    Originally posted by budm
    I would change the cap to 1000V, the 22 Ohms should be higher Wattage otherwise it will probably burn up again. That snubber circuit is design for reducing the Ringing/Overshoot based on the circuit as a whole, so the only way to find out is to use the scope and a differential probe to analyzing what is going on.
    Sadly i dont have a scope But i would change the resistor to higher wattage and the cap to 1000v
      That will be a good idea. So is the unit still running?
      • DjKrish
        • Oct 2012
        • 354
        • SG
        Yes the unit running fine till now but im afraid it will blow sooner or later so i better put a higher wattage on that resistor. Should i upgrade that cap or leave it as it is?
          I would definitely upgrade the cap to higher Voltage.
          • DjKrish
            • Oct 2012
            • 354
            • SG
            Ok, CAP upgraded to 1kv. Added another one more resistor in line as that's the highest wattage the suppliers have here. That should be fine right?
              Only time will tell since you have no way of analyzing the snubber circuit to see if it is doing its job properly or not.
              • DjKrish
                • Oct 2012
                • 354
                • SG
                #27
                Hopefully . Been running for few hours now. So far so good. Fingers crossed
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • PantherDave
                  by PantherDave
                  Hi all!
                  05-29-2024, 02:01 PM
                • GLISIT
                  by GLISIT
                  01-16-2025, 02:29 PM
                  03-31-2024, 02:12 PM
                • StasNep
                  Philips HTL6140B/12 SoundBar no power
                  by StasNep
                  Hello
                  I have got a defective Philips HTL6140B/12 SoundBar, no power from button or remote.
                  The power supply is external and working correctly, even tried another one.
                  Checked caps with esr meter and all seems ok.
                  Checked various resistors and smd capacitors and they seems ok.
                  Please help to diagnose this SoundBar.
                  Thanks ...
                  02-20-2022, 10:37 AM
