Help attaching tinsel leads
  • mikay786
    • Aug 2014
    • 765
    Working on this Sunfire HRS-8 subwoofer with a dead woofer driver.
    I assumed it was the voice coil as was reading open on the terminals. But after looking at it a bit more closely it could possible be a broken tinsel lead on the negative side.
    Struggling to see how i can get to it without causing damage or creating a bigger job.
    I removed the dust cap as assumed tinsel leads would start from there but nope looks to start from the side. Making it harder is they seemed to be covered in glue. The glue BTW looks to be also separating from the spider inside where it attaches to the cone?
    Any ideas or suggestions? was hoping to get someone / a company to deal with it but cant seem to find anyone in the UK who does this sort of work.
    • 31015
    Re: Help attaching tinsel leads
    look on ebay for "conductive glue" or "wire glue"
    i'v not tried it yet - but it looks interesting.
    • mikay786
      • Aug 2014
      • 765
      I've managed to chip away at the glue and expose both winding ends and am now getting a resistance reading.
      Both tinsel leads were broken inside the glue, with slight charring at the break. Connected a 9v battery to the exposed leads and speaker thuds. Thats a good sign right?
      If replacing tinsel leads can they be left to hang freely or do i need to weave them as they are in the pics above. Also should i also redo the glue i have removed that was covering the solder points from tinsel to windings?
      • Khron
        • Sep 2006
        • 1350
        • Finland
        You shouldn't need to weave them through.
        I remember a few years ago i bought a pair of Alesis M1mk2's with one dead woofer - turned out that the tinsel lead had broken off the end of the voice-coil wire.
        Don't ask me how, but i managed to keyhole-surgery-solder the two back together, and after it cooled down, drenched the joint in superglue / cyanoacrylate, in the attempt to mechanically reinforce it.
        I ended up selling that pair to one of two friends, can't remember which. But what i do know for sure is that neither has complained about any problem with them, to this day
        Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
        • mikay786
          • Aug 2014
          • 765
          Luckily ive got just short of a cm of exposed voice coil wire to play with. Measured tinsel and is 1.4mm so ordered some of that on eBay along with some gorilla epoxy for the spider and some black silicone adhesive to put the dust cap back on.
          Think it may be best to epoxy the solder joint as it original was and leave the tinsel free floating from there which should keep it free from fatigue.
            master hoarder
            • May 2008
            • 12170
            • Bulgaria
            Meh. Tinsel leads are overrated. You could just use regular 20-18 AWG PVC-coated wire and put regular silicone on both ends after soldering it (to prevent fatigue near the ends).
            No need for special black silicone for the dust cap either (though it will certainly look better). Depending on the cone material, you may be able to use other types of glues. For paper cones and dust caps, I use wood glue. It dries to a near-transparent finish, so it looks alright. It's also easier to apply and thus not as messy as silicone.
            • mikay786
              • Aug 2014
              • 765
              Glad to say got this up and running, was a pain soldering, only about 6mm to solder to and because its attached to the coil was absorbing the heat. But got a solid joint on it and all glued up can't even tell. Powerful little beast!
              • Khron
                • Sep 2006
                • 1350
                • Finland
                A whole 6mm? Pfff... That's easy street, you could do that with your eyes closed
                I barely had maaaaybe 2mm of visible wire end on that Alesis woofer... :P But glad to hear you got it sorted
                • kndm17
                  • Jan 2019
                  • 14
                  • United Arab Emirates
                  hi all.
                  can you also give me the value of resistor in AMP Section. this the Reference R107.
                  Thanks.
                  • mitsu2k
                    The Real Dangers of conductive glue.
                    by mitsu2k
                    I know many folks on this forum warn against conductive glue and suggest removing it immediately upon site. I'm here to vouch and say these people know what they are talking about. To be more accurate, the glue isn't intended to be and doesn't actually start out conductive. It gets conductive as it is heated by components that get hot. The glue starts out to be a light tan color but as it is exposed to heat, it gets darker and darker until it is a dark brown. I have found that it becomes conductive at the point that it reaches a light brown color on darker.
                    Here is an experience I...
                    04-16-2023, 06:29 PM
                  • acedogblast
                    by acedogblast
                    11-02-2024, 05:13 PM
                  • digtalhd
                    Remove IC glue
                    by digtalhd
                    Hi!
                    Anybody help me. Remove IC glue on mainboard.
                    Thank you....
                    11-08-2024, 02:25 AM
                  • tantr13
                    Lenovo Ideapad 5 14ITL05 not powering on
                    by tantr13
                    This is my first post so I'm hoping to get some help on this awesome forum. As a preface, I'm an amateur at electronics, especially troubleshooting complicated devices like laptops. However, I'm trying to develop a skill for it so I can learn how these devices work and how to repair them without continuing the wasteful tradition of throwing them away and buying new. 🤮
                    I've had a Lenovo Ideapad 5 14ITL05 for a few years now, with motherboard LA-K321P. I would never leave it plugged in unless I was using it, and always turned it off after I was done, but last week...
                    06-28-2024, 06:28 PM
                  • dreamlayers
                    Weird clipping on Logitech Z-10 speakers
                    by dreamlayers
                    I bought used Logitech Z-10 computer speakers. They can act as a USB audio device or accept line input, and they have a headphone output jack. Some music didn't sound right, so I played a frequency sweep and heard other frequencies and beat frequencies between them and the sweep. I uploaded a spectrogram of a frequency sweep. From the very start, some but not all odd harmonics are visible, indicating symmetric distortion. Then at higher frequencies there are descending images of those harmonics, indicating non-linearity and constant higher frequency noise mixing with the harmonics. The image of...
                    05-22-2025, 11:41 AM
