pioneer vsx 2021 no sound
  • GUSI
    • Mar 2024
    • españa
    #61
    Originally posted by andyb1712
    Re: pioneer vsx 2021 no sound
    ## Attached - DSP firmware dump from Pioneer VSX-LX55 ##
    Tested and working in both VSX-LX55 and VSX-2021.
    Circuit location is: IC9004, device is: MX25L1606E.
    Version is 119 from Pioneer firmware AVR_1_204087119093
    I loaded this into my VSX-2021 IC9004 although the rest of the receiver was still running an older firmware version. It then started up and ran fine. I was able to perform a full update via USB to the rest of latest version detailed above.
    Hello, Thank you very much, same problem and solved by copying the.bin file to the eeprom. Before this I thought the problem was with the Chinese chip, but no... it's the corrupt software. Thank you!!!!
    • andyb1712
      • Oct 2018
      • 41
      #62
      Good news on your successful repair. You are lucky your Chinese chip works because they are mostly fakes. Did you buy the D revision or B revision one? Can you upload a photo of it?
      I stopped buying them from Aliexpress and eBay because none of them worked and the markings on the chip had clearly been altered so there was no way to know which version you had bought.
      • GUSI
        • Mar 2024
        • españa
        #63
        Here I leave the data:
        https://es.aliexpress.com/item/10050...yAdapt=glo2esp
        It welded perfectly at 300º
        This one really looks original, a while ago I bought another one for a vsx1021 that has the same problem and that one seemed like a bad copy to me, yesterday I tried to upload the 2021 file to the 1021 eeprom but it didn't work....it would be possible to extract from the file provided by pioneer.MEM the .BIN to load it into the eeprom???...
        Luckily 2021 is working perfectly now...I'm very happy.
        Sorry for the English, it's from the translator...
        • creamridge
          • Mar 2022
          i got a used VSX 53 as well, with no sound tried heat gun with flux and did not fix the issue ,guessing dsp needs replaced. can someone help if i send the board as i am not comfortable with Bga etc.
          • andyb1712
            • Oct 2018
            • 41
            #65
            GUSI
            Thanks for the photo and link of the chips you used. The one fitted to your board looks 100% fake to me, so I wouldn't bother trying to make this one work
            The one you show next to it looks genuine but if it's from Aliexpress it will be a used one at best and at worst an old B revision marked with a D.
            It's a big gamble buying these from eBay or Aliexpress because NONE of them are "100% brand "new as they claim. They are ALL lying because these chips were never available to the public, only OEMs like Pioneer and Onkyo because of the DTS/Dolby copyright.
            I don't know how to extract the DSP data from the Pioneer firmware installation .mem files but the file I uploaded is tested and good. If your replacement DSP chip is working, the file should restore the audio.
            • Zicsal
              • Apr 2025
              • Russia
              #66
              Please, anyone can share or post last firmware for Pioneer VSX-LX55?
              Regards​
              • andyb1712
                • Oct 2018
                • 41
                #67
                Do you require the full Pioneer firmware to install from USB or the DSP file dump to repair a corrupted flash memory?
                • Zicsal
                  • Apr 2025
                  • Russia
                  #68
                  Full Pioneer firmware to install from USB
                  • andyb1712
                    • Oct 2018
                    • 41
                    #69
                    The LX55 is the same as the VSX2021 and VSX53.
                    You can download the latest firmware here:
                    https://www.touslesdrivers.com/index...70&v_langue=en
                    • Zicsal
                      • Apr 2025
                      • Russia
                      #70
                      Thank you
                      • eccerr0r
                        old X58 triple channel board... memtest86 memory speed?
                        by eccerr0r
                        Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                        Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                        Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                        06-28-2025, 09:06 AM
                      • Jaxxon0121
                        Pioneer PDP 436 SXE Strange Sound
                        by Jaxxon0121
                        Hi all, im new here and a complete novice with electronic repair so please bear with me. The problem i have is with my Pioneer PDP 436 SXE TV 43' plasma tv. Its recently started making a strange clicking/popping/electrical sound that is very loud and annoying. The tv works fine other than that. The sound doesnt happen straight away. After around 10 minuets of use, usually when the screen turns black on a tv program or if i exit a youtube video and the scrren goes black for a split second, that is when the sound begins and then doesnt stop at all until the tv is unplugged. The sound is coming from...
                        04-30-2021, 08:47 AM
                      • LEECH666
                        Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                        by LEECH666
                        Good day ladies and gentleman!
                        I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                        This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                        I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                        01-19-2024, 05:46 PM
                      • spleenharvester
                        Reverse engineering of 18650 4-channel tester
                        by spleenharvester
                        Hi friends
                        I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                        05-04-2025, 02:43 AM
                        LG GRAM 16 2021 (16Z90P-G.AA65Y) - CZARNY Ultrabook Specification for Upgrade or Repair
                        This specification for the LG GRAM 16 2021 (16Z90P-G.AA65Y) - CZARNY Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GRAM 16 2021 (16Z90P-G.AA65Y) - CZARNY boardview and GRAM 16 2021 (16Z90P-G.AA65Y) - CZARNY schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                        09-07-2024, 04:10 AM
