Help with Onkyo TX-NR646
  • mmartell
    • Oct 2013
    • 3189
    Re: Help with Onkyo TX-NR646
    Ya I put the board back in and plugged into mains and got the standby light and then got a normal start after turning it on.
    The ic is a Toshiba TC7WBL3305CFK which is some sort of Digital Bus Switch ic. Any idea what common electronic device I might find one of these in ?
    • R_J
      • 9567
      No not really, it would probably have hdmi with Consumer Electronic Control, and then other makes probably do it differently with different parts
      • mmartell
        • Oct 2013
        • 3189
        Hmmm... I have a few junk tv mainboards which may have that feature. Like you say they may have a different hardware implementation but worth a look. Thanks
        • mmartell
          • Oct 2013
          • 3189
          Found one but wouldn't substitute as per the data sheet. Ordered a couple from Digikey.
          • mmartell
            • Oct 2013
            • 3189
            I tested the receiver with speakers and there was no sound. So I hooked up a tv to it and there was no video either !
            Do you think the missing CEC function creates a "broken link" in the HDMI output stream which would explain what I'm seeing here ?
            • R_J
              • 9567
              I would'nt think so, but I guess anything is possible, It should only be there to route the remote control signal so you can control the receiver with the tv remote. Are you using hdmi input or rca to test it. Try doing a reset on the receiver
              check if you disconected anything during troubleshooting
              It seems a bit odd that the cec chip went bad, Its posible what ever took it out (hdmi source) did other damage
              • mmartell
                • Oct 2013
                • 3189
                I looked up the hdmi pinout and CEC is on its own pin so not likely to be causing no sound/no pic.
                Will double check my reinstallation but don't believe I missed anything.
                Using hdmi to a tv to test for pic/menu but nada. Sound source was Tuner. Headphones work fine. Did several resets - no change.
                Your probably right about other damage. I have a scope but not real familar with it. Will check for waveforms as listed in the SM at least for starters.
                • R_J
                  • 9567
                  You say the headphones work fine, they get the audio from front left & right amp outputs but before RL6600 relay, so the relay is not getting switched in for the speakers to work
                  SPRFK (relay switching) is controlled by the micro, HPDET (headphone detect) is controlled by the micro, I guess you could see if there is a firmware update?? but things seem to lead back to that hdmi board
                  • mmartell
                    • Oct 2013
                    • 3189
                    Did an update this morning but no change. Seems like something simple - at least something common to video as well as audio, unless those problems happen to be separate of course.
                    Will have a closer look at the schematic and RL6600. I think there is a debug that can be run on it but some of those commands either are not written correctly in the SM or they have changed their implementation.
                    • mmartell
                      • Oct 2013
                      • 3189
                      Well this puts me in the running for Imbecile of the Year.
                      I had the speakers hooked into Zone2
                      LMFAO!
                      Audio works
                      • mmartell
                        • Oct 2013
                        • 3189
                        I replaced the Toshiba ic and no change. Will have a look at the voltages at the hdmi switch ic.
                        • tibimakai
                          • Jan 2012
                          • 3680
                          You have sound, but no video?
                          • R_J
                            • 9567
                            If the tv is cec compatable the tv should see the amp when it is connected via the hdmi cable. Since that ic was shorted I don't think it was the only part damaged.
                            • mmartell
                              • Oct 2013
                              • 3189
                              It did recognize my Sony tv and switch to the TV input. However it did not see a sat receiver on the Aux hdmi input. Didn't try the other inputs - I will try the others as according to the SM there are two separate hdmi switches.
                              • mmartell
                                • Oct 2013
                                • 3189
                                The radio outputs to the speakers but is Analog, no ? I think the digital section is dead.
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  I have just worked on a Pioneer, which had one of the HDMI ICs shorted(surge/lightning victim?!). After replacing it, I had sound on all of the HDMIs, but I still had no video.
                                  • mmartell
                                    • Oct 2013
                                    • 3189
                                    I can't say for sure atm but I think I have no more shorts but I may be still missing a critical voltage or two. Was the shorted IC heating up much ?
                                    • R_J
                                      • 9567
                                      There are a bunch of regulators on the hdmi board on page 53 of the manual, on page 54 there is Q8300 & q8307, check the supplies like +5SBVCC, 3.3DVDD & +1.3AVDD and on page 55 Q8034 supplies 1.1VHD (777_VDD11)
                                      Q8000 requires 1.1 (777_VDD11) and 3.3 (777_VDD33)
                                      • calvin299699
                                        • Jun 2023
                                        • Taiwan
                                        #39
                                        感謝您
                                        • Thierry Wolffenbuttel
                                          Ps5 with bad standby voltages
                                          by Thierry Wolffenbuttel
                                          I have a few standby voltages that are 0, as seen in the picture. Is the Panasonic chip broken? In the picture I have all my voltages.
                                          04-08-2024, 08:04 AM
                                        • Francesc V.
                                          Onkyo A8200 - Not the right voltages in some transistors
                                          by Francesc V.
                                          Hi:
                                          I am trying to repair this amplifier that I've bought as faulty. I've found some transistors damaged, the ones where I am drawing a red circle.
                                          With the final transistors not yet installed (the expensive ones), I've started to measure some voltages:
                                          Where I am supposed to have 1.12V (base Q524/Q523) I am reading -42V..................both channels don't seem ok.
                                          Where I am supposed to have -1.12V (base Q526/Q525) I am reading -44V..................both channels don't seem ok.
                                          I removed and tested Q514,Q516 & Q513,Q515 but the analyzer...
                                          04-19-2025, 07:17 AM
                                        • Crystaleyes
                                          iMac A1224 PSU, 614-0421 - no standby voltages
                                          by Crystaleyes
                                          Hi chaps.
                                          Having recently picking up two dead 2008 iMacs, one is now working, however there is still one to repair.
                                          I was told that they both had failed power supplies, and seeing how I intend to crack SMPS repairs, it was a challenge not to ignored.
                                          Anyway, this PSU in question had already had someone having a pop at soldering.
                                          The current problem is (at the very least) in the primary side.
                                          Fuse is ok
                                          MOV is ok
                                          NTC is ok
                                          Bridge rectifier is ok (~380vDC)
                                          Fat filter cap is ok
                                          10-11-2021, 05:07 PM
                                        • frankusb
                                          Onkyo TX-NR708 standby light
                                          by frankusb
                                          My Onkyo TX-NR708 when plugged in the standby light turns on very briefly than goes out.
                                          I measured relative to GNDMPU
                                          1-MPOWER - 0.0002V
                                          2-+12VDG1+SUB - 11.7V
                                          3-GNDMPU
                                          4-+12RL - 0.318V
                                          5-/POFF - 10.49V
                                          I found that C922 was out of spec and replaced it with a used replacement but no change. I feel like +12RL should be driven by T902 always under normal operation. Is that correct?...
                                          07-16-2023, 11:00 AM
                                        • Capacitorial
                                          Powersupply has all the voltages - Monitor still no power
                                          by Capacitorial
                                          Hello guys,
                                          I have a Philips 240B7QPJEB. The monitor seems completely dead.
                                          I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                                          On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                                          The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                                          The weird thing is, that the Power LED is powered over the TCON board.
                                          On The TCON...
                                          12-28-2024, 02:12 PM
