Logitech Z5500 - distorted digital audio
  • seanc
    • Nov 2008
    • 1319
    I've been given a Logitech Z5500 set and reported that it sometimes had distorted/garbled digital audio and also that the slow-blow fuse in the amp blows once in a while.
    I've opened up the controller and most things look fine, although I'm suspicious of a few solder joints.
    I was going to re-cap, but after a quick PM with Th3_uN1Qu3 he suggested that might not be worthwhile.
    Rather than bombard him with PMs, I thought I'd start a thread. He suggested some resistors might be out of tolerance, but I'm not sure where to start.
    Attached front & back photos of the control pod, if they're not good enough, let me know.
    Thanks,
    Sean.
  • seanc
    • Nov 2008
    • 1319
    Re: Logitech Z5500 - distorted digital audio
    Bump, anyone have any thoughts or worked on one of these?
    • seanc
      • Nov 2008
      • 1319
      So I've had chance to explore this more.
      I mistakenly referenced resistors in my original post, rather than diodes...
      For a while I couldn't get the set to power on at all, so I managed to pick up another control pod from eBay with a faulty cable (with the wrong PID, so it doesn't support surround sound). This seemed to wake the set up, once i went back to the original control pod, it was working, mostly.
      The original control pod started out by only playing sound at very specific volume setting and the settings menu text was just displaying strange characters.
      The next time I went to test it, it was all dead again, fiddling around with the eBay control pod seemed to bring it back to life again.
      So it seems I have a power issue somewhere... I suspect it's the original control pod.
      In another thread a user was going to replace the diodes with BAV103, I can see no markings or way to work out what the values of the original are. Are the BAV103 a good choice?
      Thanks,
      Sean.
        https://www.badcaps.net/forum/attach...4&d=1501103871
        May be the two diodes that Th3_uN1Qu3 talks about are D700, D701? May be you should verify that with him.
        • seanc
          • Nov 2008
          • 1319
          OK, so to finish this one off....
          In the absence of knowing what the specs of the diodes D700 & D701 were, I swapped them from the known good control pod to the bad one, no change in issue.
          When I had the second control pod apart, I noticed the ST LM317D2 transistors were much bigger than the puny looking LM317 in the broken control pod. So being that these seemed to be part of the power circuit, I swapped them out of the working unit into the broken one. Problem solved!
          One (or all) of the older transistors must have been failing, I wonder if Logitech changed to the larger LM317D2 in later designs because of superior reliability. They do seem to get quite toasty.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            Glad you got it fixed in the meantime. The LM317 is not a transistor but a voltage regulator, and indeed, it is put under a lot of stress in this circuit. The very reason those diodes are there is to limit the dissipation of the LM317 by dropping some voltage. A resistor would have been a better idea.
            A working TV? How boring!
            • seanc
              • Nov 2008
              • 1319
              Ah yes, voltage regulator - I should know that, my mistake. Transistor was the first word I could think of.
              Either way, thank you for your help, without you I'd be nowhere. Hopefully the "thicker" LM317 will hold up. I'll keep the butchered control pod for parts or fix it at a later date if I come across another broken set.
              • seanc
                • Nov 2008
                • 1319
                I thought I was done with these.
                Flipped on the sub woofer today and the pod was dead.
                Did it again and the LED came on dim, a few more times and it came to life....
                Starting to wonder if I might really need to look in the sub.
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  Or the whole circuit itself and rebuild/re-engineer whatever looks dodgy.
                  Seems like these turn-of-the-millennium woofer systems are just built like crap. I just finished working on a JBL S412PII amp myself and some of the design stupidities I saw in it were mind-boggling.
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    • Romania
                    The control pod is being fed 8V from the sub, which is then brought down to 5V by those diodes and the LM317. I have repaired one with issues on the 8V rail, it was cold solder joints after someone else had been inside and replaced the bridge rectifier for that rail, but did not solder it properly. Take the board out of the subwoofer and have us some pictures.
                    • seanc
                      • Nov 2008
                      • 1319
                      Will do!
                      I've only been in there to have a look, not done any work.
                      Interestingly, I powered it all on again, pod came to life OK and then the sub started making popping noises. Also noticed a 50hz hum from the sub on when on the 'direct' input from the side of the pod.
                      • seanc
                        • Nov 2008
                        • 1319
                        An update.
                        Original control pod (PID 52x) I could not get out of its coma. It persisted with dim red led or other strange things if it did turn on.
                        Butchered control pod (PID 8xx) i put back the lm317 and it continued to function fine all the time, but missing features since it's not in a compatible range.
                        3rd control pod, purchased dead but another PID 52x. Prodded around and found D701 had no continuity in circuit. Took it out and replaced with the diode from the original control pod, working!
                        Just got to fix the hum on direct input now, other things I've read suggest checking the caps/soldering in the sub which I'll have to do.
                        Thanks for the advice everyone who has participated. Maybe I'll solve the original control pod another day.
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          • Romania
                          Those diodes really are under a lot of stress. Sadly, larger packages will not fit that footprint as the circuit is squeezed together quite tight there.
                          • Exotics
                            Logitech Z5500 problem need help fixing
                            by Exotics
                            Here's a video I uploaded to show the problem.
                            https://youtu.be/MbaZQ7aYMMY?feature=shared
                            Quality isn't 1080p yet because I just uploaded it. YouTube takes a while to process videos to maximum quality.
                            I have a multimeter and basically no electrical fixing knowledge.
                            I came across a post on here describing the same issue if it helps y'all help me. -> https://www.badcaps.net/forum/troubl...500-done-today
                            please help me diagnose and...
                            10-04-2024, 06:17 AM
                            LENOVO ThinkCentre ThinkSmart Edition Tiny M920q for Logitech ThinkCentre M i5-9600T Specification for Upgrade or Repair
                            This specification for the LENOVO ThinkCentre ThinkSmart Edition Tiny M920q for Logitech can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre ThinkSmart Edition Tiny M920q for Logitech boardview and ThinkCentre ThinkSmart Edition Tiny M920q for Logitech schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
                            09-12-2024, 01:58 PM
                          • Dannyx
                            Logitech Z5500 No Sound (Bad control pod help)
                            by Dannyx
                            Good day folks. A former colleague of mine asked me to have a look at his prized Z5500 system which he's very fond of. He said it suddenly stopped working. He brought the sub and the console to our old shop where we use to hang out and the issue seems to be the console/pod. It turns on, the display works fine, the volume adjusts up and down, everything looks perfect but there's no sound at all on any of the channels, including the subwoofer. There IS sound coming out of the headphone jack though, so sound is making its way into the pod, but not into the sub where the amps are. The easiest way...
                            01-07-2020, 12:07 PM
                          • Yanleb
                            LG 60PK550 Logic Control Board EBR63450301
                            by Yanleb
                            Hi all, I just want to share the repair of my 60PK550-UA TV set.
                            The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                            But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                            All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                            C57: 3.30V
                            C61:...
                            07-20-2023, 12:38 AM
                          • ivtec
                            Logitech harmony 900 old remote control help.
                            by ivtec
                            Hi guys hope you all are all ok and over come covid19 in good heath,
                            i was given an Logitech harmony 900 old remote control that belonged to a already deceased person, you guys do you know what can i do with it ,if i can do factory default and start knew to use it to program tvs ,i have the manual but i'm confused, it asks me for blasters that i don't have,i only have the remote and charger dock , any help would be appreciated
                            https://cdn.badcaps-static.com/pdfs/...30eef8baa4.pdf
                            03-15-2021, 11:10 AM
