Seismic Audio Baby Tremor PW (15" powered SUBWOOFER) lights up but no sound
  • triplefour
    • May 2014
    • 1747
    A DJ friend of mine bought this subwoofer not that long ago:
    https://www.amazon.com/Seismic-Audio.../dp/B00CPSR13E
    and at some point, sound just stopped coming out of the speaker. the unit powers up and all the lights come on.
    basically all the guts of the thing are on one plate that has the boards on one side and the inputs, switches and lights on the other.
    he heard i can fix things, so he took out the guts and handed it off to me. the speaker and box are just too much to deal with.
    ive only ever fixed tv's and its mostly been easy stuff. i have no idea about audio equipment. but i do have all the tools, and patience.
    my first noob question is this: what speaker can i hook up to the now disconnected leads to troubleshoot this thing? does it have to be the same size, or ohms as the original speaker, or can i just use any old speaker to test with?
    next step i guess, would be to find the service manual or schematic, which i did search for but havent found...
    in the picture you can see the black and white wires going off the screen to the right. those are the speaker output wires. labeled OUT+ and GND
    Don't fear the repair...
  • madan1
    • Nov 2016
    • 722
    Re: Seismic Audio Baby Tremor PW (15" powered SUBWOOFER) lights up but no sound
    You can use any speaker/driver rated 4+ ohms, but keep the volume low.
    Check first the relay next to where the speakers cables are soldered - bad solder joints, does it operate when the unit is turned on, etc..
    Also some better pics on both sides of the pcbs will be rally useful;
    • triplefour
      • May 2014
      • 1747
      well so it turned out, i plugged in an 8ohm speaker i had lying around and it all just worked. so he brought his original speaker and tried to hook it up and sure enough, nothing at all. how could his speaker have fried like that? it doesnt look damaged in any way...
      • Khron
        • Sep 2006
        • 1350
        • Finland
        How, you ask? Well, an active 15" PA subwoofer for under 300$ - there's your answer.
        Read: cheap stuff.
        If you also consider that the retailer, manufacturer, and however many other middle-men need to make some profit out of that, you're left with... what, 50$, maaaaaaybe 100$(?) worth of materials employed. Out of that, there's the electronics and the enclosure itself, so the speaker itself is (optimistically) 30-40$ perhaps? And there's only so much wire you can fit into that sort of cost envelope. That won't even get you a decent-brand affordable-range 1" compression driver...
        Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
          • 31218
          a good 15" bass driver cost over $100 last time i got any - and that was over 20 years ago!
          speakers arent cheap!
          • triplefour
            • May 2014
            • 1747
            yeah that makes sense. it is pretty cheap. so what if he gets a "expensive" replacement speaker? will the cheap guts still make it suck, or is it worth it?
              15" woofer:
              https://www.parts-express.com/Search...itesearch=true
              • madan1
                • Nov 2016
                • 722
                Well... you can send the driver for repair.
                You can also buy a new cheap driver.. I do not see any point in buying an expensive driver for this particular amp.
                The boxes/cabinets are made for specific driver in mind ( usually ), so a new driver ( cheap or expensive ) might sound worse than the old one.
                A good thing to start with will be to calculate the inner volume of the box and then search the net which driver will sound good in that volume.
                • Khron
                  • Sep 2006
                  • 1350
                  • Finland
                  ... And with whatever port cross-section & length the box already has.
                  • Khron
                    • Sep 2006
                    • 1350
                    • Finland
                    Case in point: https://youtu.be/jXxO09JE6YY?t=32
                    • rustinjust
                      Please help, subwoofer connected to tv, read description below
                      by rustinjust
                      I've got a subwoofer that I've had for nearly 20 years, it did come with a basic remote which I've lost. It's a generic make of subwoofer, I can't see a brand sticker on it. It comes with 2 speakers.
                      Question recently I've connected it up to my tv which has greatly improved the sound on my tv, however I'd like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                      Is there a way of...
                      10-28-2023, 07:09 AM
                    • rustinjust
                      Please help, where can I get a remote for my subwoofer?
                      by rustinjust
                      I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
                      Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                      Is there...
                      10-28-2023, 03:43 AM
                    • LEECH666
                      Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                      by LEECH666
                      Good day ladies and gentleman!
                      I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                      This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                      I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                      01-19-2024, 05:46 PM
                    • Delicieuxz
                      I replaced all electrolytics in subwoofer, still get a hum in speakers - audio clip
                      by Delicieuxz
                      I get a faint, low hum through my PC speakers, which connect to the subwoofer in a 2.1 speaker system. The hum drives me crazy and makes me stressed. When I turn off the subwoofer, everything is quiet and I start to relax, lol.
                      Here's an audio clip of the sound coming from my speakers:
                      https://vocaroo.com/16HaryHwTx78
                      I recorded with my phone's mic right next to the speaker, and the mic picked up a lot of speaker noise over top of the hum. But I don't hear that noise in the room, I just hear the lower-pitched hum that's buried beneath all the other...
                      11-15-2023, 09:50 PM
                    • Xan03
                      Klipsch Promedia 2.1 rhythmic subwoofer "pulsing" during standby
                      by Xan03
                      I have this 2.1 Klipsch set where the subwoofer emits a constant whine in standby, in addition to a constant rhythmic pulsing/thumping. Only way to make it stop is to cut power. I think this thread mentions the same issue, though my set is not a BT one: https://community.klipsch.com/index....-bt-subwoofer/
                      I think all this Klipsch gear is using crappy capacitors. Is it worth trying to replace the caps in the subwoofer amp to make this go away?
                      11-17-2024, 06:54 AM
