Car tape deck sounds awful... Guess what? BAD CAPS!
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Surprisingly there appears to be two problems with my car tape deck.
    1. The belts are kind of tired, but it works fine when warmed up. Alas what do you expect when the tape deck is 22 years old.
    2. BAD CAPACITORS! No switch mode PSU in the radio I don't think, but the caps went dry and no wonder why it sounded horrible.
    Alas this was a stock deck, nothing to write home about, or nothing to write about in general. Swapped out 4 of the caps in it that had over 3 ohms ESR (47uF and larger), and at least the non-belt problems "sounded" like it went away.
    The caps looked like they were 1970s caps. No clear date code on them and no idea why a 1990s car has 1970s caps. Probably Chrysler got a great deal on them, or perhaps I need to look for a better possible date code.
  • bluto
    • Oct 2007
    • 560
    Re: Car tape deck sounds awful... Guess what? BAD CAPS!
    Pictures? Model Number?
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Originally posted by bluto
      pictures? Model number?
      +1
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        It's a Chrysler stock radio, not sure who actually OEMed it but it does have custom parts in it (booo). The attached picture is the caps I pulled from it (well, not the radial cap, the axial ones are the ones I pulled.) Three of them are 47uF, and one is 100uF, all 10V. I didn't have any axial caps so I just plopped in some radial caps in their place.
        • redwire
          • 3910
          Philips electrolytic caps were horrible even back to the 1970's. Those are the blue axial ones in the pic. I change them on sight.
          • dmill89
            • Dec 2011
            • 2534
            Being a Chrysler OE unit it was most likely made by either Mitsubishi or Huntsville Electronics (Chrysler's captive electronics division until they sold it in pieces from 1996-1998). The Philips parts would make me lean toward Huntsville, I doubt Mitsubishi would be using Philips components.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              After listening it for a bit, though it's significantly better than before, looks like I missed a cap or two. Before it sounded really screwey, now it's just bass that seems a bit weak and treble a bit too strong. I should have replaced the 1uF caps that were DC blocking caps on the audio signal that I thought were OK...they were also those Philips electrolytics. Oh well, I'll get to them someday.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                Actually... listening it to it again, it sounds fine when playing a regular tape. However when using a line-in to tape adapter, sometimes it sounds very tinny. Ugh. Hate proprietary car radios, hard to debug in circuit. Need to get a bunch of wiring harness so I can test on bench instead of in situ.
                • RetroComputingGrotto
                  IBM LTO 7 Tape Drive - Dust Sensors??
                  by RetroComputingGrotto
                  I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
                  I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
                  09-19-2024, 01:54 AM
                • howardc64
                  by howardc64
                  Problem
                  08-04-2024, 10:36 PM
                • pecman
                  Aiwa Z-R700 Music System has very low power when switched on, dim lighting and nothing works
                  by pecman
                  I was given an Aiwa Z-R700 from the 1990s era to look at by someone who said the twin tape deck did not work. The whole unit unit powered up ok but there was nothing from the tape deck. I had a look and found all the belts broken, I replaced the belts and then put the tape deck back into place and it still does not work. Also when I now power up the unit all the lighting on the front is very dim and the cd player and the tuner as well as the tape deck do not work. I have checked all the connections and ribbon cables again, there are no burnt or swollen capacitors. Maybe there are capacitors on...
                  08-05-2025, 10:10 AM
                • triplefour
                  LG 75UN8570AUD panel issue fixed with tape.
                  by triplefour
                  I've been seeing a lot of the new TVs (samsung and LG only i think) maybe 1-2 years old suffering from sudden panel death and have been over 50% successful bringing them at least most of the way back to functionality if not all the way, with the tape masking of the LVDS pins method.
                  add this one to the list. the issue was on the left side of the panel and i ended up blocking just 3 pins on the connector that joins the two panel boards that make up the left side of the panel (it has 4 boards total) i didnt get the picture back to 100% perfect. i spent hours fiddling with which pins to block...
                  07-17-2023, 10:22 PM
                • edugimeno
                  Help me understand this schematic Harman&Kardon tape deck (TD470)
                  by edugimeno
                  Hi there!
                  Im trying to service an old Harman&Kardon tape deck (TD470) player, which after being put away for many years, is now lacking sound randomly (first time I tried it worked, called the owner and said it wasn't working for him, tried again myself and sound was gone)
                  This intermitent issue led to to go straight to the PS & Caps...I found at least one voltage missing (sorry now I can't remember which one), and one of the 3 fuses in the PS was open (this is strange as an intermitent failure wouldn't relate to a blown fuse).
                  First thing I suspected...
                  09-27-2021, 07:27 AM
