Digitech GNX3 Guitar Effect
  • mike123333
    • Oct 2011
    • 196
    Hello everyone, I am trying to repair a friends Digitech GNX3 Guitar Effect, that started with taking a long time to boot up. I found several bad caps that I replaced and still the problem was there. As I was probing voltages I accidentally slipped and either hit the 12 volt input from the voltage regulator to 3.3V output or hit the 3.3V output to ground. either case the LED light lit up and then when I powered down then back up, there was nothing the unit was completely dead. at that point in time I thought maybe that the microcontroller (U5) has been corrupted. The MNFR suggested downloading the software program and trying to update the firmware. The also supplied me with the schematics of the unit. I went thru the voltages and found nothing bad. I was unable to communicate with the micro controller the program would just time out.
    I purchased a scope for testing, as I was probing the midi in and out I noticed that the midi in was not sending any data bits, so I replaced the opto coupler 6N138 which gave me the data bits being sent tot he unit Micro controller. But nothing coming back from the unit Midi out. Probing with the scope showed nothing no data being sent out TX line. The midi usb cable I have is fully functional as I have tested it on my musical keyboards so it does send and receive.
    Thinking it may be a bad micro controller I replaced it with an Atmel which is comparable to the the Winbond micro controller ( I also replaced the caps for the crystal from 15 pF to 5pF), they note that using a higher crystal frequency one needs to replace the one capacitor with a 4-5M ohms resistors which I have not done yet I am not sure whether this would do anything as I probed the crystal and it is running at 24 Mhz. After replacing I do have several LEDs come on but nothing else, still no output from the controller TX and the software still times out and no signs of data bits from the micro controller using the scope. I am at a lost here and can't seem to get much help from Digitech.
    If anyone can help out here that would be great. Maybe a way of programming the microcontroller, which I am not sure whether the firmware resides in the chip or external to it. I have attached TDS and SM.
  • mike123333
    • Oct 2011
    • 196
    Re: Digitech GNX3 Guitar Effect
    Does anyone know whether the Atmel micro controller can be programmed in circuit after being installed or does it need to be programmed ahead of installation?
    • CapLeaker
      Leaking Member
      • 8146
      depends on if there is a programming port available, like serial interface, jtag etc. I've flashed them either or before. The Atmel comes empty so one would have to flash it, otherwise it wont do anything at all. Usually with something like a first initialize.bin and then the what ever program.bin. Of course you can do that with a out of circuit programmer too.
      • mike123333
        • Oct 2011
        • 196
        Thanks for the response, I did do more research and found that there is an ISP software for reading and flashing. I am in the process of building a parallel interface to communicate with the microcontroler. I have an older computer with XP in hwhich the software will talk with otherwise current OS are out of the question. I am not familiar with understanding bin folder and programming so my knowledge is very limited. here is the firmware zip file in text that needs to be flashed to the microcontroller. do You think this will cover everything that it needs to work? I also included the interface schematics.
        • mike123333
          • Oct 2011
          • 196
          Is there a standard initialize bin available or is that something unique for each device?
          • CapLeaker
            Leaking Member
            • 8146
            I am not sure if the firmware will take or not without the initialize.bin. For the Atmel's I use I have a initialize.bin and a firmware.bin and they are used in controllers. Try flashing the Atmel with the firmware only a couple of times back to back. Sometimes the flash will not take correctly the first time and it has to be done again.
            • SrMrPixel
              need help to identify a failure on DIY guitar pedal (MXR Micro Amp)
              by SrMrPixel
              I'm building this pedal for the second time and it has the same failure. Voltage divider not working as it should. Before the 10M resistor it works, 4.5v, but after it the voltage drops depending on the value of the resistor I put on. 10M=0.45v 2M=1.9V and so on. It should not do that, that resistor is just for biasing the input signal.
              Any idea?
              07-24-2025, 12:42 AM
            • Taurus12
              Optiplex 3050 micro 2 blinks followed by 3 blinks issue
              by Taurus12
              Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
              I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
              i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
              Any recommendation on what I have to do next? Thanks in advance
              06-10-2025, 05:05 PM
            • zombie.guitarist
              Reading Serial Midi data with an oscilloscope
              by zombie.guitarist
              Hey all, I have one last thing I'm looking to fix with my Synthaxe. This time, the schematics I have are actually the same as the PCBs I have.
              The Synthaxe, works as its a guitar midi controller hooked up to a floor pedal. Thats the most basic way of using it, and it has a midi output. You also can connect a console to it, that stores your tunings and other things. The console has 8 midi outs, as well as a midi in and midi thru.
              When I first got the unit, I thought I was using it wrong, but it turns out its just broken. The 8 midi ports on the console don't output...
              07-05-2023, 09:29 AM
            • Isabella91
              Possible to convert eMMC Socket to a micro SD Card socket?
              by Isabella91
              I have seen many posts where the eMMC can be read via a SD card reader, however can the opposite be achieved?
              Read/Write a Micro SD Card from an eMMC Socket.
              I have a Motherboard with a Kingston BGA153 ball socket, using HS400 bus mode, which is 8bit, as Micro SD is usually 1bit or 4bit mode, I accept that a loss of speed in read/write will occur, but I would sill like to convert.
              Theoretically speaking, Im thinking if I hard solder DAT0-3 from eMMC to SD Card Reader, this should force 4-bit mode, or only DAT0 to force 1-bit mode.
              Not to remove...
              01-14-2024, 05:10 PM
            • Altemon Moura
              Optiplex 3000 micro
              by Altemon Moura
              Unfortunately, when removing the chip
              (GIGADEVICE 25R256EYIG)
              It broke in the hot air.
              Will I be able to buy this same model?
              (GD25R256EYIG)
              "Can I burn the Bios?"
              motherboard
              DELL Optplex 3000 - 202040-1 D10NK$HA
              Optiplex 3000 micro
              Service tag: C7CG7T3
              SERVICE CODE: 26565563271​
              05-20-2025, 06:35 AM
