denon mc6000 dj mixer blowing fuse
  • benwrong
    • Jan 2017
    • 17
    • scotland
    Hi, the board keeps blowing the 2.5 amp fuse f700. when I remove the capacitor c773 it doesn't.
    I have replaced c773 with a new 2200uf 16v but different package size, thinner and longer, but still blows fuse. I also tested three different capacitors inc. the one I removed and all behave exactly the same removed from circuit on a diode test.
    I then removed q700, q701 and ic704.
    Replaced and tested r711,c726, c727.
    With all these components removed and the three others replaced, I have the exact same behaviour, blows fuse with capacitor and powers to correct area without. I have also checked for short circuits in the traces between points, with diode check, all clear....... Any help greatly appreciated! please find image of schematic attached
  • CapLeaker
    Leaking Member
    • 8163
    Re: denon mc6000 dj mixer blowing fuse
    could you upload the whole schematic? what about IC705?
    • benwrong
      • Jan 2017
      • 17
      • scotland
      sorry for slow response, I didn't think ic705 would be 'in play' so to speak since I had other components disconnected...I had a quick look just now (magnified) and nothing obv. ....thanks for your help, unfortunately pdf schematic is too big for page limit, even compressed is still over so have the link to download... thanks ...... https://www.manualslib.com/manual/10...Dn-Mc6000.html
      • madan1
        • Nov 2016
        • 682
        • Bulgaria
        By the way, have you checked the power supply?
        Also, If I read it right, there is a branch of the power supply line from SW700 ( SW12V ) which I'm not sure where it is going... it could be page 43 near IC101.. anyway, just be sure to know the position of SW700 when testing.
        • benwrong
          • Jan 2017
          • 17
          • scotland
          yeah power supply all good, been testing in off position and still blowing. Tested without capacitor, power to correct points on board with switch on or off (with the components listed above removed).. thanks
          • benwrong
            • Jan 2017
            • 17
            • scotland
            cheers madan, do you mean the line going from standby on ic704? can see it on schematic, just checking circuit around d703 and q708, thanks!
            • petehall347
              • Jan 2015
              • 4426
              • United Kingdom
              first make sure the power supply is correctly polarised and correct voltage .
              then be sure c773 is correct way round .
              then check q701 for being shorted .
              it is most likely your power supply is wrong .
              theory is c773 seeing reversed voltage will act shorted and blow the fuse .
              • benwrong
                • Jan 2017
                • 17
                • scotland
                supply is fine, double checked voltage and polarity. As with c773, checked then double checked. q701 and q700 (which i think seperates it from rest of circuit?) are currently removed and still blowing fuse. Also no short to ground on this line
                • benwrong
                  • Jan 2017
                  • 17
                  • scotland
                  ps is it possible a board would rely on earths created from being bolted onto its outer casing?
                  • madan1
                    • Nov 2016
                    • 682
                    • Bulgaria
                    Measure the current without the capacitor.
                    Also if you have scope check the waveform of the power supply.
                    "ps is it possible a board would rely on earths created from being bolted onto its outer casing?" - yes it is possible. I have an Onkyo receiver which does not want to power up ( just erratically switching the power relay ) without proper ground from the backplate.
                      When Q700 is removed then any loads on the Drain are no longer present, so the only connection left after the main fuse are the loads after the power switch if the switch is ON, but you said the fuse is still blown even the switch is in the OFF position. Something is not making any sense.
                      • petehall347
                        • Jan 2015
                        • 4426
                        • United Kingdom
                        does it blow fuse with power switch off ?
                        • petehall347
                          • Jan 2015
                          • 4426
                          • United Kingdom
                          ok stop wasting fuses .. take your meter and set to low ohms .maybe 200 .. look for the short with it .
                          also test the power supply using a dc blocking capacitor to see how much ac is passing if any . .01uf or something like that in series with a meter lead . i dont think ac is the problem though so disregard that bit for now . useful to know anyway .
                          • CapLeaker
                            Leaking Member
                            • 8163
                            The switch is off, Q700 and Q701 are out and it is still blowing fuses, without there being a low resistance reading to GND?
                              Are you using the original power supply that comes with unit? Switch is off the main switched power MOSFET is removed and still blowing fuse, something is fishy to me.
                              • benwrong
                                • Jan 2017
                                • 17
                                • scotland
                                Hi Everyone, thanks for all the advice! Sorry for late reply, I've had a ridiculously busy few days but am now back. It is original power supply, blows with fuse on or off but only when c773 is connected.
                                I will go over, check all things recommended. will also try another of my 2200 uf 16v c773 replacements, slightly longer and thinner in package. Will also check traces around c773. checked at 200 ohms resistance test and no short to ground. On diode test (to gnd, from power line) w/c773 connected, starts low and charges capacitor.
                                I have been a mechanic most of my life, started doing boards about two years ago and for about the last nine months have done nothing but study and practice electronics. I'd say I have a decent idea but being self taught does leave you open to missing basic things.
                                I have also cross ref. my multimeter, which is fine... I seem to be missing
                                something... thanks again!
                                • benwrong
                                  • Jan 2017
                                  • 17
                                  • scotland
                                  Also have just discovered that c792 does not make earth whilst board is out of its casing, hopefully that would cause it to behave this way. Poss clutching at straws, think it would be mentioned in service manual if so. will wire it to earth and test ;-)
                                  • CapLeaker
                                    Leaking Member
                                    • 8163
                                    Yeah that's another reasons why pictures are important
                                    • benwrong
                                      • Jan 2017
                                      • 17
                                      • scotland
                                      new capacitor, earth trace from c792... same result... the schematic says 2.5a 32V chip fuse. I got 2.5 amp, 32v ac 63v dc??? is this wrong? also it blew the original so was a problem before i started replacing fuses.... still to check with dc blocker and don't have a scope
                                      • petehall347
                                        • Jan 2015
                                        • 4426
                                        • United Kingdom
                                        fuse is fine ..voltage is before it might flash-over . so higher the better .
                                        pull that cap out again that seems to stop it blowing fuses then measure the DC and AC voltages right across where the cap came from .
                                        then check voltages at the power supply plug and unloaded .
                                        • Francesc V.
                                          Help me to identify this Thermal fuse from my sister's mixer
                                          by Francesc V.
                                          Hi everyone:
                                          This is the second time I have my sister's mixer on the bench. First time I identified a blown tiristor......this time I guess it's the thermal fuse (reads open).
                                          My understanding is that it should be (NC) normally closed and open at 85C?????
                                          Could you help me to identify/get a good one? How many amps? I was about to buy a NC 10A, 85 celcius in Aliexpress. (ceramic one)......but I guess is too much.
                                          Wording in the back......... "limitor 16", "T160".
                                          Thanks in advance,
                                          Francesc....
                                          03-18-2025, 05:48 AM
                                        • Dannyx
                                          UC3842 Power Adapter Blowing Fuse
                                          by Dannyx
                                          Good day folks......wow this new layout is weird. It's like I woke up one day and I'm no longer on Planet Earth or something
                                          Anyway....got this here power brick from a USB to SATA adapter which keeps blowing the fuse after I almost repaired it. The reason I even bother to fix a power brick (wall wart, whatever) in the first place is because this thing was really convenient to use: I'd just plug it and that's it. It's a dual output supply, for both 12v and 5v, which although I COULD easily obtain with a DC-DC converter from a standard 12v adapter, I thought I should crack open the...
                                          12-05-2023, 12:06 PM
                                        • Tips
                                          Samsung PD27AOQ (BN44-00506B) constantly blowing internal fuse.
                                          by Tips
                                          Looking for some assistance please.
                                          Trying to repair a PD27AOQ samsung power board.
                                          Initially had the typical problem of cm806 capacitor blown, additionally thermistor NT801s blown.
                                          Replaced the ceramic capacitor, str60252s, bridge rectifier, thermistor and fuse.
                                          Testing it the fuse blows immediately power is turned on.
                                          diodes dm852 and dm853 test as shorted when in the board but fine when removed.
                                          any assistance, guidance would be appreciated.
                                          04-11-2024, 11:24 AM
                                        • RogerH58
                                          Samsung 46" TV LE46B530 blowing fuse
                                          by RogerH58
                                          I am a newbie and not very experienced so bear with me if i struggle sometimes with technical language - but I'll do my best. I searched "Samsung" and the model number on the forum but didn't find anything I could understand!
                                          I'm not an electronics guy - just picked up stuff over the years through my flight-simming hobby.
                                          I have the above mentioned 46" tv as the monitor for my flight-sim setup. Recently it went "crack" and stopped working. No standdby light and no response. I assumed a fuse had blown and after investigation...
                                          06-10-2023, 10:27 AM
                                        • corrize
                                          A funny fuse story – Lumix LX100 II
                                          by corrize
                                          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                          10-19-2023, 09:58 AM
