Clarion Head Unit Problems
  • KGdio
    • Nov 2016
    • 16
    Hello everyone, I have an old Clarion Head Unit. It's a Clarion DXZ585USB.
    TLDR version: I have an old flash drive that works perfectly on my head unit, but my brand new one wont work for some reason. Both are usb 2.0 FAT32
    http://www.clarion.com/us/en/product...385079010.html
    I just got it installed a couple weeks ago and im having trouble getting some things to work and play my MP3's via the USB port. I have an old 4gb Flash Drive, and it works perfectly. Plays all my songs and it lets me navigate all the folders perfectly.(http://www.actionsportdrives.com/v2/...ull_skull.html)
    I have an MP3 player (4GB) that i've tried to load songs on and at first it wouldnt read it at all, but i realized its because i was using a USB 3.0 cable. I switched to an older cable (usb 2.0 i assume) and it detected the drive but it gave me an Error 2. Error 2 in the manual says improper format, but the songs on the mp3 player are the exact same ones that play fine on my old flash drive.
    So i decided to buy a micro SD card for the mp3 player to see if that would work, but no dice. Next, i bought a new 32GB flash drive, (https://www.amazon.com/SanDisk-Cruze.../dp/B007KFAG8Y), i assumed that would work since my other flash drive works perfect, but i get the exact same Error 2 when i try to use it. :/
    Everything is setup exactly the same on both flash drives, same mp3's same folder setup and everything. Both are formatted FAT32 and are USB 2.0.. The only difference i can see is that my old flash drive says its compatible with USB 1.1, but it says right in the Manual the head unit is compatible with both 1.1 and 2.0.
    I've tried many different things, different formats, using different folders, putting the mp3's in the main directory, adding .mp3 tags to the file names. I would really appreciate it if anyone could help me out.. I can't figure out why one flash drive would work but the next one doesn't.
  • KGdio
    • Nov 2016
    • 16
    Re: Clarion Head Unit Problems
    I just tried formatting the 32GB flash drive down to 4GB and still getting the same error.
      • 31219
      format it with this:
      http://www.ridgecrop.demon.co.uk/ind...?guiformat.htm
      • KGdio
        • Nov 2016
        • 16
        The drive was already fat32 but i tried this anyway, but still getting the same error 2. Just wanna add, ive tried renaming the drive, changing the serial number, setting the partition to active and a bunch of other things with a partition tool. No luck. Im starting to think it could be a wiring issue. I had the unit professionally installed but im starting to wonder if they maybe didnt hook up the secondary power cable that powers the USB drive. But wouldn't that make nothing work on the USB?
        • ekozeko333
          by ekozeko333
          🧠 What I’ve Done So Far
          Flashed...
          06-21-2025, 02:48 AM
        • corrize
          Nikon D800 camera - flash don’t work and capacitor don’t charge
          by corrize
          Hello, I'm stuck in troubleshooting…
          The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
          In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
          When I press the flash button, it's detected by the system, flash icon appear on LDC display....
          10-01-2022, 10:02 AM
        • zen
          PS48 Bose sub & head unit schematic / advice please.
          by zen
          PS48 is model for sub & where i suspect issue lies .
          CD head unit seems to run ok , & can take a line out signal into an amp with audio present .
          Can't seem to measure any voltages at secondary side of PSU within SUB unit ....
          07-08-2022, 07:53 AM
        • spmetroil
          Request: SPI Flash BIOS Dump (Winbond 25Q128) for Dahua NVR4216-4KS2
          by spmetroil
          I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
          The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
          I have a CH341A programmer and I already attempted the following steps:
          1. Identified the correct chip (W25Q128, 3.3V SPI flash).
          2. Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: “Chip with the contents are in disagreement.”
          3. Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
          08-19-2025, 09:23 AM
        • abajor
          Canon VIXIA HF S10 A read data from inernal flash memory.
          by abajor
          Hello I've had somebody bring in one of these charming little cameras to attempt retrieving data from the internal 32GB flash.
          Something is damaged inside the cameras lens assembly I can hear it clunking around and it has probably dislodged the sensor, powering up the camera gives a blank screen and the focus motor sounds like it's having a fit.
          The camera will not connect to a computer via USB in this state, I have no options no navigation, just power up and focus/zoom motor noises.
          I think my best shot is to figure out a way to read the internal flash memory outside...
          07-20-2024, 12:04 AM
