Clarion Head Unit Problems
  • KGdio
    • Nov 2016
    • 16
    Hello everyone, I have an old Clarion Head Unit. It's a Clarion DXZ585USB.
    TLDR version: I have an old flash drive that works perfectly on my head unit, but my brand new one wont work for some reason. Both are usb 2.0 FAT32
    http://www.clarion.com/us/en/product...385079010.html
    I just got it installed a couple weeks ago and im having trouble getting some things to work and play my MP3's via the USB port. I have an old 4gb Flash Drive, and it works perfectly. Plays all my songs and it lets me navigate all the folders perfectly.(http://www.actionsportdrives.com/v2/...ull_skull.html)
    I have an MP3 player (4GB) that i've tried to load songs on and at first it wouldnt read it at all, but i realized its because i was using a USB 3.0 cable. I switched to an older cable (usb 2.0 i assume) and it detected the drive but it gave me an Error 2. Error 2 in the manual says improper format, but the songs on the mp3 player are the exact same ones that play fine on my old flash drive.
    So i decided to buy a micro SD card for the mp3 player to see if that would work, but no dice. Next, i bought a new 32GB flash drive, (https://www.amazon.com/SanDisk-Cruze.../dp/B007KFAG8Y), i assumed that would work since my other flash drive works perfect, but i get the exact same Error 2 when i try to use it. :/
    Everything is setup exactly the same on both flash drives, same mp3's same folder setup and everything. Both are formatted FAT32 and are USB 2.0.. The only difference i can see is that my old flash drive says its compatible with USB 1.1, but it says right in the Manual the head unit is compatible with both 1.1 and 2.0.
    I've tried many different things, different formats, using different folders, putting the mp3's in the main directory, adding .mp3 tags to the file names. I would really appreciate it if anyone could help me out.. I can't figure out why one flash drive would work but the next one doesn't.
  • KGdio
    • Nov 2016
    • 16
    Re: Clarion Head Unit Problems
    I just tried formatting the 32GB flash drive down to 4GB and still getting the same error.
      • 31017
      format it with this:
      http://www.ridgecrop.demon.co.uk/ind...?guiformat.htm
      • KGdio
        • Nov 2016
        • 16
        The drive was already fat32 but i tried this anyway, but still getting the same error 2. Just wanna add, ive tried renaming the drive, changing the serial number, setting the partition to active and a bunch of other things with a partition tool. No luck. Im starting to think it could be a wiring issue. I had the unit professionally installed but im starting to wonder if they maybe didnt hook up the secondary power cable that powers the USB drive. But wouldn't that make nothing work on the USB?
        • ekozeko333
          [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
          by ekozeko333
          I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
          🔥 The Problem Started After Suspected ESD/PD Fault
          I experienced a power issue or ESD event through a USB-C charger
          After that, the NX20P5090 power switch was visibly burned and was replaced
          Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
          🧠 What I’ve Done So Far
          Flashed...
          06-21-2025, 02:48 AM
        • corrize
          Nikon D800 camera - flash don’t work and capacitor don’t charge
          by corrize
          Hello, I'm stuck in troubleshooting…
          The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
          In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
          When I press the flash button, it's detected by the system, flash icon appear on LDC display....
          10-01-2022, 10:02 AM
        • zen
          PS48 Bose sub & head unit schematic / advice please.
          by zen
          PS48 is model for sub & where i suspect issue lies .
          CD head unit seems to run ok , & can take a line out signal into an amp with audio present .
          Can't seem to measure any voltages at secondary side of PSU within SUB unit ....
          07-08-2022, 07:53 AM
        • abajor
          Canon VIXIA HF S10 A read data from inernal flash memory.
          by abajor
          Hello I've had somebody bring in one of these charming little cameras to attempt retrieving data from the internal 32GB flash.
          Something is damaged inside the cameras lens assembly I can hear it clunking around and it has probably dislodged the sensor, powering up the camera gives a blank screen and the focus motor sounds like it's having a fit.
          The camera will not connect to a computer via USB in this state, I have no options no navigation, just power up and focus/zoom motor noises.
          I think my best shot is to figure out a way to read the internal flash memory outside...
          07-20-2024, 12:04 AM
        • Ihandyrepair
          4 red flash led 65X950G boot Sony and android logo but then black
          by Ihandyrepair
          HI guys
          I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
          here is the issue
          I have Sony and android logo. but then 4 led red flash lights front of the tv
          I have 3.3v ref. 12v reg then T con 12v when I press the power on button
          but then I get black screen and 4 red flash light at the front LED
          but I get 3 led flash on the LED driver board.
          I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
          so I tried...
          07-11-2024, 01:45 AM
