Onkyo TX-SR309 - clicks on volume change.
  • Zykki
    • Jul 2023
    • Slovensko
    Re: Onkyo TX-SR309 - clicks on volume change.
    I'll try to revive this thread. Did you manage to solve the problem? What helped?
    I currently have the same problem with the TX-NR525. When I turn the volume wheel, I hear a pop in the right and left speakers. Other speakers are fine.
    • FrancescoV
      Onkyo HT-R390 no sound output, video output ok
      by FrancescoV
      Good morning everyone,
      I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
      The firmware reported is the following:
      M:1.00/11107BLP
      D:?.??/????????
      O:1.00/11107AL
      The DSP firmware given the question marks seems corrupt.
      On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
      05-11-2025, 02:59 AM
    • BigOof
      Marantz SR5007 popping on volume change and mute in Direct Mode
      by BigOof
      I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
      12-12-2024, 06:15 AM
    • ClockChip
      Advice sought - Selector switch knob repair
      by ClockChip
      Hello Everyone,
      I am seeking to repair a knob on an old (circa 1971) Panasonic clock radio (a model RC-6900). The good news is that I have the small, easily lost knob. The bad news is that the knob has come off a slotted post and I need to re-attach it in such a way that I won't have to worry about it coming loose again.
      Here is a picture of the bare slotted post (if I have the term right) the knob should be attached to:
      As you can see, this is an Old School selector switch, which means it's pretty stiff. Put another way: the knob has to fit...
      07-20-2024, 04:52 PM
    • karthur
      Vizio D65x-G4 Volume changes on its own
      by karthur
      On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
      It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
      06-05-2025, 08:13 AM
    • freethink
      Kenwood KR-A70 Receiver Balance changes with volume controls?
      by freethink
      I have a Kenwood KR-A70 Receiver on the bench, and the digital volume control is acting very funky. When I adjust the volume, the balance also changes. Volume Up = balance goes Left, Volume Down = balance goes right. Has anybody ran into this issue, or know what the problem might be?
      11-23-2025, 07:53 PM
