Beats Pill - broken USB connector
  • redwire
    • 3910
    I have a broken micro USB charger connector on a Beats Pill 2.0 Portable Bluetooth Speaker.
    Took it apart and it's crappy product. The USB connector is on a small daughterboard and the pads lifted off from torque on the connector. The PCB copper peels off if you do the slightest rework- it's a really cheap build.
    What do people suggest to fix this? I don't have much luck with micro USB repairs.
    I thought I could find a replacement connector and solder fine wires to it, glue it like crazy.... or
    I could lay out a PCB and make a new daughter board using a decent through-hole USB connector.
    The USB connector is a bit odd ball because it is through-hole at the front and SMT at the back and pins ~7.5mm apart.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Beats Pill - broken USB connector
    I repaired a tablet a couple of weeks ago, one pad left the rest had been ripped off.
    I worked out where the traces went with a multimeter, then used wire from an ide cable to replace the pads and make the connection then the micro usb socket went on top.
    I do use a stereo microscope to make things easy and I have bought a couple of bags of assorted micro usb sockets.
    • japlytic
      • Oct 2005
      • 2086
      On the daughterboard are two small diodes (D300 and D301), which are most likely for USB data bus ESD protection - if one side (most likely the anode) is connected to ground, check for a trace between the other side (most likely cathode) of the the diodes and the USB connector.
      If this is correct, the repair is viable, but it can be tricky soldering wires to the USB Micro-B connector - some desoldering wick is helpful.
        • 31044
        ebay has mini and micro usb sockets on small pcb's - i use them sometimes.
        http://www.ebay.co.uk/itm/272041590226
        http://www.ebay.co.uk/itm/142108537186
        • diif
          • Feb 2014
          • 6978
          • England
          As japlytic says, you can see the two diodes and what was left of the traces.
          It really helps being able to see the work easily. Jobs that were once slow and a struggle became so much easier with a stereo microscope but I imagine even one of those cheap magnifiers or USB microscopes would help greatly.
          Use flux and the pins will solder much easier. I soldered the wires first to the diodes as i positioned them so they lay in the bottom where the pads used to be. Wiggling the excess with tweezers to snap off the excess. The micro USB socket then went on the top and the final missing trace just bridged with a bit of solder.
          • predator0357
            • Jul 2014
            • 159
            • Israel
            Hello everybody,
            I have the same prob with the usb, but i manage to find where everything is going. I ordered from Ebay what early some1 said,
            P.S
            Will post pics:-)
            • Tomylee
              No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
              by Tomylee
              Sorry for the person who’s going to read all this !
              I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
              While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
              During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
              07-11-2025, 11:52 AM
            • JamieAFM
              Micro USB Connector identify?
              by JamieAFM
              Back again with another connector that I just can not seem to find!
              Any help would be greatly appreciated!
              It's from a Zebra RFD8500 - the connector was ripped off the board. I have a bunch of micro USB ports, but none of them fit. I can't even just change the housing on it.
              Thanks!
              03-18-2024, 05:12 AM
            • gabri2211
              Xbox Series X Console Won't Turn On - Broken Nexus Connector on Mainboard
              by gabri2211
              Inside the console there is a small circuit board (see photo) that contains the main power switch, the one on the front.
              This circuit board connects to a 10-pin flat cable called NEXUS that terminates on the motherboard.
              This NEXUS connector broke.
              Can anyone tell me, while waiting for a replacement, if it's possible to turn on the Xbox by disconnecting this circuit board and making some modifications (like adding a small power button) on the motherboard?
              The Xbox has a power supply that provides 12 volts on all outputs, so the power...
              07-28-2025, 07:13 PM
            • 5mall5nail5
              Help identifying connector for ASUS 4090 Strix RGB LED connector
              by 5mall5nail5
              Hi All -
              I had replaced my ASUS 4090 Strix cooler with a waterblock and put the stock cooler on the shelf. Was moving it and snagged my sweater on the connector and pulled the wires out of the pins on the RGB connector. I tried to get them back on but its too small so I opened the stamped pins and tried to solder but its not a good repair and the wire broke on reinstallation.
              Looking to replace the connector on the cable side and get pins to crimp onto a new cable. Bought random JST and such but nothing is correct. Can anyone help identify the connector and possibly matching...
              05-04-2025, 07:47 AM
            • bussincaps
              MacBook Pro Mid-2014 A1398 Retina LED Controller Connector [First Repair (Disaster)]
              by bussincaps
              Hello All,
              tl;dr: minimal electronics experience and my first repair, lifted 8 pads off the laptop display LED controller board when attempting a connector replacement, options are attempting pad repair or jump wiring.
              Laptop Model: MacBook Pro 15 Mid-2014 Retina, A1398 MGXA2LL/A
              eDP Display: Samsung LSN154YL01-A02, assembly sold as Apple part 661-8310
              Soldering Equipment: Hakko FX-888D w/ T-18 tips (Chisel, Conical, Bevel types)
              I needed to replace the 30-pin I-PEX Cabline connector (labeled J8300 in the Apple 820-3662 mainboard schematics),...
              08-03-2023, 12:57 PM
