Micro USB Connector identify?
  • JamieAFM
    • 11
    Back again with another connector that I just can not seem to find!
    Any help would be greatly appreciated!
    It's from a Zebra RFD8500 - the connector was ripped off the board. I have a bunch of micro USB ports, but none of them fit. I can't even just change the housing on it.
    Thanks!
    • 31262
    you didnt look on aliexpress did you?
    • JamieAFM
      • 11
      I have done yes, just can't see any that look the same. It's like the housing is the opposite orientation.
      • rogfanther
        • Jul 2006
        • 458
        • Brazil
        Usb connectors are a pain to find. You need to look at AliExpress, and compare the pictures. Of a lot of sellers.
        • petehall347
          • Jan 2015
          • 4447
          right click pic and search google image .
          https://lens.google.com/search?ep=cc...RmZDcxNmEiXV1d
          • lotas
            • Jan 2016
            • 4808
            • Russia
            https://aliexpress.com/item/1005004769942349.html
            https://aliexpress.com/item/32829288761.html
            https://aliexpress.com/item/32740501910.html
            • JamieAFM
              • 11
              Thanks for the responses, appreciate that. I've got some on order now, so will give them a try when they arrive 🤞
              • reformatt
                LCD Connector identify or source
                by reformatt
                Trying to identify where to source the LCD connectors on the motherboard side for a HP 14-cf2051la. This one came in with liquid damage to the connector and the flex cable. It appeared to clean up ok, however customer says that display blanks out intermittently. It's a 30 pin EDP flat ribbon cable on motherboard side. Believe it to be a HEDWIG-6050A3155301-MB-A01 motherboard.
                I've stolen the connector from another HP motherboard which matches up but it's not the best since it's been kicking around my donor pile for a while. This connector is different to most flip type ones I have...
                03-25-2024, 08:29 PM
              • Tomylee
                No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
                by Tomylee
                Sorry for the person who’s going to read all this !
                I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
                While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
                During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
                07-11-2025, 11:52 AM
              • k-krzych
                Identify board to board connector
                by k-krzych
                Hello, can you help me with an id of this board to board connector, or the the tiny silicon flat wires for replacement? It is found on GPS unit and connects main board with pushbotton small board....
                07-08-2025, 12:32 PM
              • JamieAFM
                USB-C Connector Identify ?
                by JamieAFM
                Would appreciate any assistance in finding a replacement compatible USB-C connector for this.
                It was from a Dell Latitude 3320. Code on the connector is; 13XHK.
                I'm struggling to locate a replacement with the same footprint.
                Thanks. (Sorry if this is posted in the wrong section)...
                03-11-2024, 06:40 AM
              • SrMrPixel
                need help to identify a failure on DIY guitar pedal (MXR Micro Amp)
                by SrMrPixel
                I'm building this pedal for the second time and it has the same failure. Voltage divider not working as it should. Before the 10M resistor it works, 4.5v, but after it the voltage drops depending on the value of the resistor I put on. 10M=0.45v 2M=1.9V and so on. It should not do that, that resistor is just for biasing the input signal.
                Any idea?
                07-24-2025, 12:42 AM
