ONKYO TX-SR604 No HDMI output on some sources
    I bought an ONKYO TX-SR604 second hand.
    Everything works fine when I connect a Fetch TV set top box and a Beyonwiz PVR to it. But it seems to reject some sources like PS3 super slim and CC1 when I connect them using the exact same setup. There is no audio, no video whatsoever. All I see is the no signal display on the television.
    Is this normal?
    I have already tried changing the 100uF capacitors on the HDMI board, but no change.
    Re: ONKYO TX-SR604 No HDMI output on some sources
    What've you changed those capacitors with?
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
      Same value capacitors but higher voltage rating.
        Brands / series?
          I doubt the capacitors are the cause of this
