ONKYO TX-SR604 No HDMI output on some sources
  • syaoran123
    • Jun 2014
    • 178
    I bought an ONKYO TX-SR604 second hand.
    Everything works fine when I connect a Fetch TV set top box and a Beyonwiz PVR to it. But it seems to reject some sources like PS3 super slim and CC1 when I connect them using the exact same setup. There is no audio, no video whatsoever. All I see is the no signal display on the television.
    Is this normal?
    I have already tried changing the 100uF capacitors on the HDMI board, but no change.
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: ONKYO TX-SR604 No HDMI output on some sources
    What've you changed those capacitors with?
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
    • syaoran123
      • Jun 2014
      • 178
      Same value capacitors but higher voltage rating.
      • Khron
        • Sep 2006
        • 1350
        • Finland
        Brands / series?
        • syaoran123
          • Jun 2014
          • 178
          I doubt the capacitors are the cause of this
          • budwich
            ESD Diode on HDMI output of Yamaha a1050 RCVR
            by budwich
            I lost one of the two hdmi outputs on a yamaha rx-a1050 receiver. Of course, it is the hdmi1 which has the arc capability which was useful. The second output hdmi works OK.
            I got an hdmi breakout board which gave me access to the "little guys" in the hdmi. I did some gross DC voltage measurements to ground and found that the Data1 pair (4 and 6) had a lower voltage than the working hdmi.... 1.1v versus 2.9. All others pins seem to be OK. Further when plugged into a display, there is no video but a message on the screen which I assume is the display's status for the...
            09-11-2023, 12:21 PM
          • FrancescoV
            Onkyo HT-R390 no sound output, video output ok
            by FrancescoV
            Good morning everyone,
            I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
            The firmware reported is the following:
            M:1.00/11107BLP
            D:?.??/????????
            O:1.00/11107AL
            The DSP firmware given the question marks seems corrupt.
            On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
            05-11-2025, 02:59 AM
          • amigo744
            ps5 cfi-1016a hdmi output graphics glitches ???
            by amigo744
            i have a ps5 here, which only produces graphic artefacts on the screen when the console shuts down.
            no graphic artefacts visible in ps4 and ps5 games.
            when the console is started, no artefacts can be seen in the main menu!
            It's all very strange and I don't know what to do next
            I swapped the hdmi port, no change.
            could it be the hdmi encoder or the components near the hdmi ports?
            how are the hdmi filters checked for functionality?
            https://youtu.be/cOCapeDOMZk
            Have anybody here same problem with hdmi...
            08-11-2023, 05:42 AM
          • Prosatanosz
            Asus B85M-GAMER no hdmi output and random restarts
            by Prosatanosz
            Hi!
            Asus B85M-GAMER absolute no hdmi output (not at start, not at Windows), and random restarts. Everything work, except hdmi and random restarts after 0.1-3 min. Restarts even in bios. On VGA Windows boots up fast, games and apps starts ok. Mem, psu, cpu changed, no luck. I need shematic, because i think the restarts caused by the hdmi failure.
            10-19-2024, 05:27 AM
          • Jayanta
            Acer Nitro 5 AN515-55 no HDMI output.
            by Jayanta
            Hello, forum people.
            I have an Acer Nitro 5
            Model Number: AN515-55 Part Number: NH.Q7NSI.001
            Motherboard: Compal GH51M LA-K861P Rev 1A with 1650 Ti graphics.
            My laptop was working fine until I made a grave mistake of changing the thermal pad and paste because my laptop was getting old and pretty hot. After changing and successfully testing temperatures, I was shocked when I tried to connect my external display, a 1440p 75Hz monitor, to it. My display never showed up; it always said 'no signal.' I tried swapping the HDMI cable, using both source 1 and 2 on...
            06-17-2024, 02:49 AM
