Rotel RMB-1075 blows left front fuse
    Re: Rotel RMB-1075 blows left front fuse
    The schematic has the value, its 33 ohms, and looking at the size its a .5 watt this should work digikey PPC33BCT-ND
      Thank you RJ. I didn't initially see the value on the schematic.
      You Can't Succeed Until You're Willing to Fail
        Correct me if I'm wrong.
        By reading service manual, you should check Q210 to Q217 since F401/402 are for this channel because of K11A.
          Looks like the diagram is wrong and K9a & K11a are reversed. The fuse's 401 & 402 connect to N4 & P4 of S4B which connect to the Left front amp where the blown parts are located
          The right front amp is working (according to O/P) where q210-q217 are located
            Replaced the bad output transistors and R425. Didn't see any other issues during testing. Unit powered up fine and passed all tests. Once it warmed up, I let it run about 60-70% for 45 mins with no issue. Customer is thrilled. Thank you everyone for the help!
              It's usually a good idea to check and adjust the bias after replaceing parts in the outputs. Its easy to do (page 4 of the manual). if the bias is off one way or the other it could cause distortion or excess heat, even if it seems to sound ok.
                Thanks for the tip RJ. But I beat you to it didn't really need but a hair of adjustment
                  Where did you get those "sanken" devices?
                  That old Japanese stuff is often faked, knockoffs usually have "shiny" tabs:
                  http://sound.westhost.com/fake/counterfeit-p2.htm
                  http://sound.westhost.com/counterfeit.htm
                  If you didn't run it up to full output into a dummy load, which would've "exposed" counterfeit parts, you've not finished the repair/troubleshooting.
                  "pokemon go... to hell!"
                  EOL it...
                  All style and no substance.
                  guilty,guilty,guilty,guilty!
                  guilty of being cheap-made!
                    I have. And I don't think that anyone here would question ti the quality or validity of Digikey components.
                      What about thermal compound? I don't see any oozing from the micas.
                      EOL it...
