Ideal caps for crossover?
  • mikay786
    • Aug 2014
    • 765
    HI, Ive got a speaker hear that sounds different than the other identicle speakers. It sounds muddy in comparison. Had a look all all tweeters and drivers seem to be functioning fine, so thinking maybe the crossover.
    There is residue all over the board which I assumed was electrolytic from one of the caps. Have removed and tested them all and all are testing ok but cant think of anything else and wouldn't be the first time a cap tested ok but wasn't so might aswell just change them as there are only 5 of them.
    Speaker is a Jamo L7 Sur
    Caps are all NP caps
    3 x M.D.L. 6.8uf 50v NP
    1 x M.D.L. 10uf 50v NP
    1 x M.D.L. 72uf 50v NP
    Not really sure what to replace with?
  • R_J
    • 9535
    Re: Ideal caps for crossover?
    Why not swap the crossover with the one in the working speaker to see if is indeed the problem.
      • 31012
      good crossovers generally use plastic caps, not electrolytics
      • rhomanski
        nowhere man
        • 5157
        • U S of A
        I had the same thing with my Sansui's. Old capacitors sounded muddy and smeared. I replaced them with Solen from here http://www.parts-express.com/cat/met...capacitors/294 .
        sigpicThe Sky Is Falling
        • mikay786
          • Aug 2014
          • 765
          Bit too much work, although I could dip over driver easily and test
          Any idea what the ones in mine are? Anyway I can check
          Was looking at these caps
          http://www.ebay.co.uk/itm/261803815766?redirect=mobile
          • rhomanski
            nowhere man
            • 5157
            • U S of A
            Do yourself a favor and go with polypropylene. Jantzen, Solen should be available since they're made in Europe. This would be good for the 6.8 uF. http://www.parts-express.com/jantzen...citor--027-928 . This would replace the 72 uF. http://www.parts-express.com/cat/met...28%29%2Frecord[endeca%3Amatches%28.%2C%22P_PortalID%22%2C%221%22%29+and+endeca%3Amatches%28.%2C%22P_Searchable%22%2C%221%22%29]&PortalID=1&showMoreIds=21640 . Try to find them at Farnell or something.
            • mikay786
              • Aug 2014
              • 765
              Ta, being so much higher voltage ok? and NP?
                • 31012
                NP = non-polarised electrolytic
                junk, but MUCH cheaper than film caps
                • mikay786
                  • Aug 2014
                  • 765
                  Yea the films caps are a bit too pricy for value of speaker. Ive gone for some jentzen non polarized electrolytic caps. See how it goes.
                  • rhomanski
                    nowhere man
                    • 5157
                    • U S of A
                    You ask for ideal caps and then reject it. Whatever.
                    • mikay786
                      • Aug 2014
                      • 765
                      You are right, perhaps I should have said suitable caps. These are to go into speakers that i'm going to sell, not keep, so not worth sinking £20+ in caps for when the speaker itself is worth that much.
                      Your recommendation isn't wasted however as I need to sort some of my own aging speakers shortly and will use those your recommended!
                        • 31012
                        everybody makes bipolar electrolytics, you could have used panasonics
                        • mikay786
                          • Aug 2014
                          • 765
                          http://www.hificollective.co.uk/comp...apacitors.html
                          Images of the caps looked to be the same ones as the ones that need replacing, so maybe a better match. Are jentzen the same company as mdl?
                          • rhomanski
                            nowhere man
                            • 5157
                            • U S of A
                            I don't know but they are from Denmark. http://www.jantzen-audio.com/ .
                            • mikay786
                              • Aug 2014
                              • 765
                              Speakers are made in Denmark too.
                              • rhomanski
                                nowhere man
                                • 5157
                                • U S of A
                                You can see from the price why manufacturers use electrolytics except in high end speakers. The Pioneer HPM 100 used poly film from the factory. I've rebuilt three pairs for personal use and replaced the original with modern replacements.
                                I first started with my Sansui SP-L700. I was using 2 pair and recapped one pair. I then put the receiver to mono and sat in front of all four. The recapped speakers sounded so much clearer, the instruments could be picked out individually. The original speakers were terrible in comparison. I immediately took the other two out and recapped them with film. I've done it to every speaker since, even a Pioneer set from 1990 that didn't impress me much. I gave them to a friend.
                                • japlytic
                                  • Oct 2005
                                  • 2086
                                  I agree with this, and I have also recommend replacing bipolar electrolytic capacitors with plastic units for Horizontal deflection in 12V (sometimes 24V as well) TV sets.
                                  Another project I am working on (a boombox TV) involves replacing certain electrolytic capacitors for reliability, including the tweeter coupling capacitors being changed from bipolar electrolytic to plastic units.
                                  • mikay786
                                    • Aug 2014
                                    • 765
                                    New caps here and the are m.d.l. Branded so thanks for the jentzen tip rhomanski.
                                    So jentzen make these caps
                                    • mikay786
                                      • Aug 2014
                                      • 765
                                      Definitely sorted it, its like a veil has been lifted from the speaker, sounds like the others now.
                                      • rhomanski
                                        nowhere man
                                        • 5157
                                        • U S of A
                                        Sweet, they'll probably bring more money now.
                                          by momaka
                                          03-12-2025, 03:42 PM
                                        • eryjus
                                          by eryjus
                                          05-10-2023, 11:21 AM
                                        • Paxman_Swede
                                          by Paxman_Swede
                                          Hello!
                                          01-14-2025, 09:51 AM
                                        • captain150
                                          by captain150
                                          03-16-2025, 07:34 PM
                                        • budwich
                                          Polk csi40 center ch speaker crossover caps replacement
                                          by budwich
                                          Did a "gross" impedance measurement of the inputs on my polk csi40 center channel speaker. It showed about 4ohms. Seemed kind of low. There are two midrange drivers and one twitter ... 2 way system.
                                          All measurements at the drivers seem ok in the 4 - 6 ohm range (the two mid range are in series).
                                          Anyway, in the crossover on the tweeter side, there are two caps in parallel basically leaving an inductor .... "nice simple setup", especially when no schematics around. The question is finding a replacement. One is a TI .47uf met 100vdc while other is a 9.1uf...
                                          05-05-2023, 10:16 AM
