Samson Auro D1800
  • diydidi
    • Sep 2012
    • 17
    • South Africa
    Samson Auro D1800
    Hi
    I'm in need of a schematic for this sub woofer. Replaced two output Fets and the driver IC, IR2092S.
    No luck. Anyone?
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: Samson Auro D1800
    Symptoms?
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
    • diydidi
      • Sep 2012
      • 17
      • South Africa
      Dc on output
      • Khron
        • Sep 2006
        • 1350
        • Finland
        Are the power supplies ok?
        • osrex
          LED DRIVER KEEPS DYING
          by osrex
          Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
          i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
          i have no datasheet at all for the LED lights, all i have is its length.
          long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
          as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
          05-05-2025, 03:36 PM
        • charif
          Audio Driver for Thomson P14C4BK128
          by charif
          Need Audio Driver for Thomson P14C4BK128 (Windows 10/11)
          I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
          The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
          Here are the details:
          • Model: Thomson P14C4BK128
          • Operating System: Windows 10 64-bit
          If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
          Thanks in advance for your help!
          04-30-2025, 05:41 PM
        • bohaboha
          how to install gl usb2.0 uvc camera device driver on windows 10
          by bohaboha
          Hello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encou​ntered an error.
          but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
          any help?
          01-26-2025, 08:33 PM
          Boston Acoustics HD8 – build quality impressions & DIY woofer surround repair
          by momaka
          Boston Acoustics fans, this thread might not be for you.
          A few years back (~2018 time frame), I picked up a set of free JVC speakers from someone on Craigslist that no one seemed to be interested in. The guy also had a single Boston Acoustics HD8 speaker – yes, just one cabinet. He said he had no idea where he got this one from or why it's only by itself. But like the JVC speakers, it was going to get tossed at the end of that week… so I came to collect, as usual. And that's all I know about this HD8. After all, I figured why not take it and see what's inside… show it to the...
          01-30-2022, 11:57 PM
        • Daveleone
          UN55D6900 BN44-00428B partial led driver circuit failure
          by Daveleone
          Hello TV experts! I have a UN55D6900. The successfully TV turns on, and the backlights light up, and I get a picture, but there is a section that is dim. I took it apart and 1 out of 4 segments of backlight LEDs are not lighting on both sides of the TV (in other words, the same segment is out on both LED strips).
          I tested the LED strips with my LED tester and all of the LEDs light properly, so I believe the problem is with the PSU/LED driver board (BN44-00428B). The voltages at CNM810 (between PSU and main board) look ok to me. The voltages at CNL801A and CNL801B look off for one...
          07-23-2021, 06:31 PM
