Re: Harman/Kardon Onyx Bluetooth Speaker - No Power
Please tell me what is the resistor the fuse in place С701 (burnt, most damaged). In a parallel module U600 it is not (only 3 capacitors), I can't determine its type.
С711, С712, С713, С714 - everything is clear, but with this С701 is a mystery.
Just remove ONE of those cap as suggested earlier and check the capacitance.Leave a comment:
Could you find the specification sheet about burnt capasitors' and resistors' types ? Thank you.Once we get the P/N of that IC the we can find the specification sheet for the IC to find out what those caps connected to pin 2 are for then we can go further, I am sure that they are just filter caps connected in parallel.
And when you clean up the board to inspect the traces then we will know how bad the damage is.Leave a comment:
we can only guess what really happened to the speaker, I bought it already brokenBurnt component seems to be L701, which would imply a short circuit somewhere.
I also notice C633 (Big electrolytic, bottom right) is bulging.
U700 is a TPS54331, of which the burnt inductor would have been feeding Pin 2. Pin 2 is the input, so the U700 has probably shorted to ground and caused the burnt L701.
My theory then is that either:
1) Unit was connected to too high a voltage (at least 30v), Which blew C633 and also U700 - did you connect it to a 30v or higher supply?
2) C633 failed by itself, causing a supply voltage drop which meant U700 overworked and overheated, then shorted.
The burnt section of board will probably be conductive. You will likely have to scrape it out.
The burnt section of board will probably be conductive. You will likely have to scrape it out.Leave a comment:
U700 number 54331 TI 3134 ZC 83 G4Once we get the P/N of that IC the we can find the specification sheet for the IC to find out what those caps connected to pin 2 are for then we can go further, I am sure that they are just filter caps connected in parallel.
U600 - the same
I've cleaned up the board, please see attached file.
thanks in advanceLeave a comment:
Thanks a lot for your willing to help, I really appreciate it, only tomorrow will be able to write everything in details. Another problem is swollen capacitor p1352 (blue barrel to the right and "down"), it would have to change. Special tools i have not yet, I want to get information about the type of the burnt capacitors and replace it with a new (by soldering).Leave a comment:
P\N printed on main board (may be the white paper label?) or on the case?We need the P/N as printed on top of that IC U700
https://www.badcaps.net/forum/attach...1&d=1490356626Leave a comment:
If you can give us the P/N as printed on that IC 700 then we can look at the spec sheet to see what pin 2 of that IC is for. From the look of it those caps (C7013, 712, 711, 714, 701) are filter caps connected in parallel, MLCC (Multi Layer Ceramic Capacitor, they fail in shorted out condition mode) type, C 712, 711, 714, 701 should be the same value, the C713 is probably <1 uF.
You can remove the one that is not damaged c712 and measure the capacitance.
You should also clean up the board so we can see the traces better.
IC 600 looks to be the same setup.
if I understand correctly the question
S\N FC0005-0188023
IC 6132A-ONYXSTLeave a comment:
IC 600 looks to be the same setup.Last edited by budm; 03-24-2017, 10:00 AM.Leave a comment:
Please help with the repair Harman Kardon Onyx Studio. On the main board burned out capacitors. To replace them i need to know the type and capacity. My speaker works but is not charging. If someone has good advice how to restore the speaker (and what type of capacitors inside) I would be very grateful. ThanksLeave a comment:
https://www.5giay.vn/threads/chuyen-...tudio.8273931/Leave a comment:
Harman Kardon Onyx Studio 1 has been die (can't power on)
Could you help me to resolve it?Leave a comment:
I ask prices Harman Kardon Onyx Studio 3 speakers how many? I bought it purchased?
http://viendongshop.vn/harman-kardon-onyx-studio-3.htmlLeave a comment:
thank you. I changed my portable battery 19,5v (using rectifier diodes ) to 18,9v , considering the load. So is working well , it is 5 hours of autonomy with the high volume !Leave a comment:
I have no ideea if it's normal (maybe it's normal, it has no distorsions). I have it from a friend, and I received it broken.
I can make an audio record and post it if it would help, but no sooner than monday because I'm out of town now.
Thanks!Leave a comment:
Is the sound you hear the normal sound it would make without input, or is it abnormal?Everything is OK with the voltage rails. I have power on the IC amps, I have power on the BT module; the unit starts then shuts down.
I've checked the IC apms, and no shorts on them; also, in that second when it's on, I can hear some fsssssss on both channels.
What else can I check?Leave a comment:
by funky2xCant find what smd code Y0DVA.
sitting in Harman kardon onyx studio 7. Appreciate any help.1 Photo-
by dorfmanWorking on an early 2000s dell / harman kardon computer speakers.
Suddenly only the right speaker works. No sound is coming out of the left. Also, the right is much louder than when both speakers were working. The minimum volume setting sounds much louder than where I previously set it (half way). And the loudness difference between minimum and maximum position on the knob is small compared to when both were working.
I checked the signal wire for continuity from the board to the jack. Both channels and the ground are continuous with low resistance and not shorted...-
by magnehHi
Long story short, Harman Kardon Aura Studio 2 speaker, no power.
Disassembled, found burned IC, maybe the 5V regulator? not sure
No schematics
IC marking: 225S2 (see pic)
Board ref: 40-KS320U-PSK2G
Thanks for any help!...-
by motormayhemLaptop Question
I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when... -
by PowellSkierWould I be able to swap a 0.27 Ohm Kx2 5W resistor for a 0.22 Ohm Jx2 5W resistor in a Harman/Kardon AVR? Cement type.
- Loading...
