Magnat Phantom Mono-block car amp
    • 31137
    Re: Magnat Phantom Mono-block car amp
    got a frequency counter?
    the amp has a switching psu that steps up the voltage, you could be hearing that because of a bad cap.
    • jansiu
      • Aug 2015
      • 14
      • Finland
      No, I dont have frequency counter..
      Is it some of those "RAIL-side" 1000 uF / 100V?
      Or some of those whitch are in power input side (2200 uF / 25V)?
      Any suggestions?
        • 31137
        the 1000uf 100v are the main smoothers, i dont want to think those are all bad.
        that then feeds a 15v regulator that feeds the op-amps.
        maybe that could be checked first.
        lower right section of page2, c83,84 100uf 63v and c93,94 100uf 25v
        what make and series are the 1000/100 and the other 4 caps?
        because they should be low esr to handle the psu frequency or they wont last!
        and check those 4 double-diodes d51,52,53,54
          • 31137
          btw, test it from a battery, not a mains supply - just to eliminate external noise.
          • jansiu
            • Aug 2015
            • 14
            • Finland
            I have already checked all of those diodes- they are OK.
            I check those caps tomorrow. I have fluke with cap-testing function at work.
            And also I post info about those 1000/100 caps...
            • CapLeaker
              Leaking Member
              • 8285
              Take IC14 out and see if the noise is gone. Do you have an oscilloscope?
              • jansiu
                • Aug 2015
                • 14
                • Finland
                #27
                I replace those caps. (C83,84,93,94)
                And remove IC14 -> no hum or other "extra" sounds anymore.
                Should I replace IC14?
                All caps are made by HZC.
                No other info..
                • jansiu
                  • Aug 2015
                  • 14
                  • Finland
                  #28
                  I replaced both IC13 and IC14.
                  No hum noise anymore.
                  When audio input (or even cable, with or without anything on other end) is connected to phonos, it makes "blip" or "bliiip" noises randomly. It is very annoying.
                  If there is no audio input or even phono cables connected, it is silent.
                  • CapLeaker
                    Leaking Member
                    • 8285
                    So when you had IC14 out, there was absolute silence, correct? That was to prove the noises are coming from the sub sonic filter. I figured that there may be IC13 bad too. But its good to change them all. I think that the blip blip crap is still coming from the input circuit. I'd change out caps C107, C207, C103, C203 and C105 and see if there is a change. If it isn't than the problem is after C105, around the sub sonic filter, I think. Kinda hard trouble shooting without a scope. Does this blip crap change in volume if you turn the amp gain knob?
                    • jansiu
                      • Aug 2015
                      • 14
                      • Finland
                      #30
                      When I have IC14 out, there was absolute silence.
                      I earlier changed caps C107 and C207.
                      Now I have changed caps C103, C203 and C105.
                      I think it is working right now.
                      I need to put it back together and test it in my car... someday..
                      I inform you, if there is still some problems.
                      Thanks for everybody who helped me!
                      • CapLeaker
                        Leaking Member
                        • 8285
                        Good to hear!
                        • Francesc V.
                          Tele-master AS-20 amplifier. No output sound, just noise
                          by Francesc V.
                          Hi:
                          I bought this amplifier from the 70s to try to repair it. So far it has no output sound, just noise. You can volume it up and down.
                          I've checked fuses and all are ok.
                          I've continued with capacitors:
                          • The main black one should have 4700uF, but it has lost half of its capacity during these years.
                          • The ones that I've numbered have still a really low ESR and the full capacity after ¿40 years?
                          The 4 transitors are perfect. Desoldered and tested individually.
                          There are also components which I don't know exactly what they are....
                          02-16-2023, 07:55 AM
                          MSI Gaming GS43VR 7RE(Phantom Pro)-058NE Notebook GS Specification for Upgrade or Repair
                          This specification for the MSI Gaming GS43VR 7RE(Phantom Pro)-058NE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GS43VR 7RE(Phantom Pro)-058NE boardview and GS43VR 7RE(Phantom Pro)-058NE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                          09-06-2024, 05:33 AM
                        • tony359
                          by tony359
                          11-28-2023, 05:18 AM
                        • MegaZAC
                          Onkyo TX-SR805 noise in one channel
                          by MegaZAC
                          Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                          Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                          There's some logic behind it. As soon as I select an input I get only left...
                          04-23-2025, 10:09 PM
                        • courtcircuit
                          Philips HTS8000 home cinema noise problem
                          by courtcircuit
                          Hello
                          I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                          Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                          Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                          I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                          Removed each of tyhe boards
                          02-08-2025, 08:22 AM
