Magnat Phantom Mono-block car amp
  • jansiu
    • Aug 2015
    • 14
    • Finland
    Any help with Magnat Phantom Car amplifier?
    I bought broken amp. Somebody has shortcutted subwoofer output.
    Now I have checked all the mosfets, transistors and diodes. Them are OK.
    (Tested with simple mosfet tester circuit, that I found from Google)
    When I put the amp on, I hear popping noise from speaker.
    And if I turn GAIN (volume) knob, I can hear crakling noise from speaker.
    Sound comes out _only_ if I connect some audio device to amplifier RCA output, not when it is connected to amplifier RCA input. That is little bit weird.
    What I should check next?
    Thanks already!
    P.S. Sorry for bad english.
    I attach PDF service manual.
    • 31137
    Re: Magnat Phantom Mono-block car amp
    that makes no sense unless the schematic is wrong or maybe the 4.7uf capacitors c107/c207 have gone open-circuit.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8285
      or IC11 on the Line Out is bad.
      • jansiu
        • Aug 2015
        • 14
        • Finland
        Schematics are right ones, checked multiple times.
        I already changed those capacitors.
        Now I ordered all of those ICs (4x NJM4558D).
        When I get and change those ICs, I will let you know what happened...
        • kaboom
          "Oh, Grouchy!"
          • Jan 2011
          • 2507
          Do you have both +/- 15V opamp/bias supplies?
          What are the +/- rail voltages, and are they more-or-less symmetrical?
          "pokemon go... to hell!"
          EOL it...
          All style and no substance.
          guilty,guilty,guilty,guilty!
          guilty of being cheap-made!
          • Longbow
            • Jun 2011
            • 623
            First things first - what are the power supply voltages?
            Would you mind putting up the complete schematics? Where are the FET's???
            Is it plugged in?
              • 31137
              he did put up the schems.
              it's an input op-amp problem.
              • kaboom
                "Oh, Grouchy!"
                • Jan 2011
                • 2507
                He's able to backfeed the line-outs, and pass a signal to the input bus, which isn't possible unless IC11 is also bad.
                I'd be breaking the path at SW1B, and isolating the input stage/filter/EQ from the PA, in order to properly isolate and troubleshoot. Loss of +/- 15 will make the PA act strange, since those voltages also bias the PA's input section.
                Jansiu, you won't have that crackling when moving the gain pot unless the pot has DC across it. That's a direct-coupled AC opamp circuit; at least when/if proper supply voltages are present and the opamps are good.
                All signal pins on those input/filer opamps should be at zero volts DC.
                EOL it...
                • jansiu
                  • Aug 2015
                  • 14
                  • Finland
                  +/- 15V is OK. (measured 14.9VDC)
                  RAIL voltages are both +/- 54VDC. They are identical.
                  IC's voltages measured. Negative probe in pin 4 and positive in pins 2,3,5,6.
                  IC11
                  2= 1.4VDC
                  3= 1.4VDC
                  5= 1.5VDC
                  6= 1.5VDC
                  IC12
                  2= 0.0VDC
                  3= 0.0VDC
                  5= 0.0VDC
                  6= 0.0VDC
                  IC13
                  2= 14.8VDC
                  3= 14.8VDC (1.0 to 14.8VDC changes if I turn volume knob)
                  5= 15.5VDC
                  6= 15.5VDC
                  IC14
                  2= 15.3VDC
                  3= 15.3VDC
                  5= 15.3VDC
                  6= 15.3VDC
                  I checked those pins from NJM4558D datasheet.
                    • 31137
                    ic12 looks um... suspect!
                    remove ic11 for now, and use it to replace ic12
                    • jansiu
                      • Aug 2015
                      • 14
                      • Finland
                      I changed them and measured voltages.
                      IC12
                      2,5,6 = 30VDC
                      3 = 0VDC
                      IC11
                      All pins 0VDC
                        • 31137
                        so the fault moved?
                        • jansiu
                          • Aug 2015
                          • 14
                          • Finland
                          Yep. Maybe I get next week all of those IC's, that I ordered.
                          Should I change all of them or just only the IC11?
                          And should I check some other components or only replace the IC's?
                            • 31137
                            no idea.
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              Replace the opamps and coupling capacitors between them. Should work fine then.
                              A working TV? How boring!
                              • CapLeaker
                                Leaking Member
                                • Dec 2014
                                • 8285
                                Since you have plenty of them coming, I would change at least IC11 and IC12.
                                I wouldn't want to open that thing again in 2 weeks only to find out that the other one is now toasted too. Some amps use one IC per channel, so I SURLY replace BOTH!
                                • jansiu
                                  • Aug 2015
                                  • 14
                                  • Finland
                                  I changed IC11 and IC12. Now they all have same voltages. I connect my phone to the input and I get sound out. But if I stop the music, speakers starts keeping humming sound. I dont know if this is caused by bad power supply ( omron 12vdc / 4.2A) or bad rca cable. Or can those coupling capacitors cause this?
                                  • CapLeaker
                                    Leaking Member
                                    • Dec 2014
                                    • 8285
                                    I first would try it on a better power supply or battery.
                                      • 31137
                                      does it hum if you unplug the phono's?
                                      • jansiu
                                        • Aug 2015
                                        • 14
                                        • Finland
                                        Tested with better power supply, no difference. I have video that you can hear that sound.
                                        Sound does not change if there are phonos connected or not...
                                        https://youtu.be/k9cqQZpS6FI
                                        • Francesc V.
                                          Tele-master AS-20 amplifier. No output sound, just noise
                                          by Francesc V.
                                          Hi:
                                          I bought this amplifier from the 70s to try to repair it. So far it has no output sound, just noise. You can volume it up and down.
                                          I've checked fuses and all are ok.
                                          I've continued with capacitors:
                                          • The main black one should have 4700uF, but it has lost half of its capacity during these years.
                                          • The ones that I've numbered have still a really low ESR and the full capacity after ¿40 years?
                                          The 4 transitors are perfect. Desoldered and tested individually.
                                          There are also components which I don't know exactly what they are....
                                          02-16-2023, 07:55 AM
                                          MSI Gaming GS43VR 7RE(Phantom Pro)-058NE Notebook GS Specification for Upgrade or Repair
                                          This specification for the MSI Gaming GS43VR 7RE(Phantom Pro)-058NE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GS43VR 7RE(Phantom Pro)-058NE boardview and GS43VR 7RE(Phantom Pro)-058NE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-06-2024, 05:33 AM
                                        • tony359
                                          by tony359
                                          11-28-2023, 05:18 AM
                                        • MegaZAC
                                          Onkyo TX-SR805 noise in one channel
                                          by MegaZAC
                                          Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                                          Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                                          There's some logic behind it. As soon as I select an input I get only left...
                                          04-23-2025, 10:09 PM
                                        • courtcircuit
                                          Philips HTS8000 home cinema noise problem
                                          by courtcircuit
                                          Hello
                                          I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                                          Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                                          Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                                          I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                                          Removed each of tyhe boards
                                          02-08-2025, 08:22 AM
