Fender PD-250 Passport has low audio output Right Side
  • tfs2015
    • Feb 2015
    • 135
    Re: Fender PD-250 Passport has low audio output Right Side
    What does the BIAS and OFFSET adjustments control? The reason I am asking is it looks like they could have been moved from their original factory set positions.
    Computer and Small electronics troubleshooting and repair
      The BIAS pot is for setting the current flowing through the output transistor (with out input signal) in idling condition, the set point is set for Class A/B mode for this amplifier.
      The OFFSET adjustment pot is for setting the DCV at the out put to be at 0V so at no signal the speaker will be seeing 0VDC on the speaker coil.
      • tfs2015
        • Feb 2015
        • 135
        So assuming these are set right should I suspect a bad transistor or capictor. Need to test transistors without voltage applied?
          You do need to test the transistors and diodes (do the search on how to test transistors and Diodes), resistors (check the values and its condition) without power applied to the unit. Any suspect parts that tested bad should then be removed off the board and test again.
          This is not really for beginner that do not have enough knowledge yet on how the devices function. Do you know how to read the schematic and have proper tools?
          • tfs2015
            • Feb 2015
            • 135
            yes I can read the schematic and I have a solder iron and DMM. I will report back later on what I find. Thank you for the help if you can think of anything else please let me know.
            Tom S.
            • tfs2015
              • Feb 2015
              • 135
              As i increased the volume on the right right side output channel, I noticed that the sound became distorted and not clear. It sounded more like "thud" sounds then it did music. Which leads me to believe that when Q217 was replaced that the electrical characteristics of that one and original are not the same and therefore either the offset/bias or both needs to reset for this unit to function properly. Is that a good conclusion or is there more that I should be looking at.
              • tfs2015
                • Feb 2015
                • 135
                Looks like my problems went from bad to worse well checking things out today on the amp board. Looks like if the power amp to power supply is connected the protect light comes on. Otherwise if it is not plug in the unit is fine. Please help!!!!! Thank you
                Tom S.
                • tfs2015
                  • Feb 2015
                  • 135
                  After doing more component testing and checking, there seems to be extra components added to the board and some of the diodes are missing. I am playing with the idea of replacing the whole board or just all of the components which ever is cheaper. Once I get that done I am going to need help to set the OFFSET for the amp's left and right sides and also the BIAS adjustments without the help of an O'scope. Any help would be appreciated.
                  Tom S.
                  p.s. I want to use this in parades this summer hooked up to my truck to play music and make announcements.
                  • tfs2015
                    • Feb 2015
                    • 135
                    I have two blown output transistors. One one the left channel and one on the right channel also had some thermal damage to the emitter resisters on both channels. I have also found that the caps c212 and 213 that were supposed to be 10uF 63v had been replaced with 4 1200uF 63v caps. So I was wondering should I keep pulling the transistors and caps off of the board to check or just order the new output transistors?
                    Tom S.
                    • tfs2015
                      • Feb 2015
                      • 135
                      Need help to adjust BIAS and OFFSET on this amp now that I got it working.
                      Tom S.
                      • tfs2015
                        • Feb 2015
                        • 135
                        Everything is working good now, except a pop sound is heard when unit is shut off with speakers plugged in. Thanks everyone for the help.
                        • flibidy
                          Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                          by flibidy
                          I have here a Magnum IA.100 which belongs to my parents.
                          The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                          Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                          What Ive done........
                          01-01-2025, 01:26 PM
                        • bouny56
                          Lenovo E15 Nm-c421 usb-c work only in one side
                          by bouny56
                          ​Hello
                          Laptop E15 I5 10gen
                          Mb nm-c421
                          I have a problem with the usb-c power dc.
                          The motherboard start only in one side of the usb-c
                          Replace the usb-c port 2 times same problem
                          With the usb-c meter, one side 20v ok, other side the usb-c meter don't come on
                          Try to test the pin with the Mechanic Tail insertion tester and every pin are ok ?
                          Can the pd controler be the fault ? Or something else maybe ?
                          Thx
                          02-11-2025, 03:15 AM
                        • howardc64
                          by howardc64
                          Yesterday, 05:17 PM
                        • Stephen
                          A2442 MacBook Pro 14" Two Left SIDE USB C ports charge but no data
                          by Stephen
                          Right SIDE usb.c port charges and transfers data without issue, two left side uSB c ports charge but do not receive or see data. Was liquid damaged, and repaired significantly and thought we were in the clear but appears this is the last issue that is rearing its head. I am trying to locate the RETIMER chip that communicates the DATA TX/RX but I cannot seem to find it on the schematic or maybe I am just so tired my eyes wore out lol. Any help would be great.
                          05-29-2025, 10:35 AM
                        • dicky96
                          Xilence XP600 600w ATX PSU - No PWM Controller on primary side - how does it work?
                          by dicky96
                          Hi guys
                          I have a faulty Xilence ATX PSU here
                          The fault basically is I have two short circuit power transistors on the primary side of the large SMPS transformer - they are 2SC3320.
                          There is another smaller transistor on the primary side C3866 which tests ok
                          The PSU has three transformers - it looks like the 2SC3320's drive the big one and the C3866 drives one of the small ones. There is a separate PFC PCB with it's own controller and MoSFETS
                          There is also a short on the 3.3V output and a near short on 5V - I suspect this probably blew...
                          05-11-2021, 07:55 AM
