Severed audio plug on a pair of Razer Kraken headphones
  • withalligators
    • Jun 2013
    • 267
    Hey guys,
    Found a pair of Razer Kraken over the ear headphones in my e-waste bin.
    Luckily, they are of the hot pink variety.
    Anyway, the cable is severed up by the headphones, so I wanted to splice in another plug just to see if they worked or if that was why they were tossed. cutting off the sheath of the wire exposes something weird. There are two strands of shock absorbing string, and three twisted lengths of colored copper. There is a red length, a blue one, and a copper colored one. They do not appear to be insulated from each other!? Also, there is a fine clothing thread inside each one of these, also, I presume, for shock absorption. What the heck should i do?
    I've spliced audio cable before, and the little strands inside the cable have always been sheathed and sometimes surrounded by a steel grounding sheath. Or dipped in thin rubber or something. I'm confused.
    Anyway, anybody have any pointers?
    Cheers,
    Alex
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Severed audio plug on a pair of Razer Kraken headphones
    Ugh those super fine wires (the strands) give me the chills! (because they are very fragile)
    Those fine strands are enamel coated. It's basically a very thin type of "magnet wire".
    LOL @ hot pink ... the best color!
    -Ben
    Muh-soggy-knee
    • withalligators
      • Jun 2013
      • 267
      So, should I just solder them onto the corresponding wire of a plug, making sure the cut ends are in the solder? I think I'm going attach a female end to that plug so I can just run a male/male out of that.
        • 31015
        red and blue are the sides +
        copper is the common for both.
        read this:
        https://www.badcaps.net/forum/showpo...7&postcount=13
        • withalligators
          • Jun 2013
          • 267
          Amusing and helpful thread. Sounds like I should have a few drinks before getting into this. Why set my temp so low?
          Cheers
          Alex
            • 31015
            low?
            310 is good for lead-free and will pretty much destroy leaded solder!
            it's also high enough to melt plugs!
            • kaboom
              "Oh, Grouchy!"
              • Jan 2011
              • 2507
              60/40 or 63/37 solder is fine.
              Blue is left, red is right, clear is common.
              I've tinned that "solderon" just fine with multiple irons, including a Weller TCP and an American Beauty T-12, around/above 700 degrees Fahrenheit. From larger wire in transformers and inductors, down to the smaller sizes in headphone cords.
              Anything hot enough to melt solder will also melt the plug. Faster is better- leaded solder works in your favor.
              "pokemon go... to hell!"
              EOL it...
              All style and no substance.
              guilty,guilty,guilty,guilty!
              guilty of being cheap-made!
              • withalligators
                • Jun 2013
                • 267
                I usually keep my iron at like 700. In and out super quick on boards and such. I could use some new tips though. I bet I could work at much lower temps.
                  • 31015
                  we are mixing C & F i suspect!
                  • withalligators
                    • Jun 2013
                    • 267
                    Well, I finally got around to attempting this. It worked! Thanks for all the advice, especially the bit about cooking the enamel off with molten solder, I don't think it would have worked if I hadn't known that. These are actually some pretty decent cans! Thank goodness they are hot pink. Can't wait to wear em to the gym or to the next biker rally.
                    Cheers
                    Alex
                    • RyanHaris
                      • Aug 2021
                      • Pakistan
                      Razer no doubt has offering best gaming headphones though there are issues in a few versions therefore i do not go for experiments much rather i prefer using know Razor headsets. I've owned a set of Razer Carcharias for probably 13 years now (has to be somewhere around there I bought them when I worked at Best Buy during college.) They survived 6 years of heavy WoW raid use and they're currently laying on my desk for when I host webinars for work 3 times a week. I don't know what all the online regarding them is about.
                      I hear a lot of good things about the HyperX headsets but I've never used one. I just bought a set of Razor Blackshark V2 gaming headset for just $100 while looking for some good options. They're… good. I like the mic as much as the Razer's because it's detachable and it is not fixed in place so I easily flip it up when not in use. I also easily find the faux leather cups super comfortable, just like the microfiber ones on the Razers, they are as nice as the cups on the Bose QC15s.
                      If it's the wire being destroyed, maybe go for something with a replaceable line in? You can get replacement line ins for most Sennheisers (my previous set of headphones before the mic became necessary) and Bose QC15's. There's also a couple of mics out there that can piggy back on nicer headphones which weren't available a few years ago.
                      Thinking about it, I probably have way too many headphones laying around so I really should stop buying them. I'm counting 5 working pairs of circumoral aural headsets right now plus 4 sets of earbuds.
                        RCA WHP141 wireless headphones wired up
                        by momaka
                        OK, this one dates back to 2015! I thought I had posted this, but realized I didn’t when I posted a picture of something else. So here it goes…
                        Back in 2015, I bought a pair of RCA WHP141 wireless headphones at Micro Center for $2. I even mentioned it in the best cheap/free scores thread right here. Just forgot to follow up with that.
                        As mentioned back then, these are (were) 900 MHz FM wireless headphones. No modern day Blutooth or anything like that. I knew they wouldn’t be great headphones or even that good… but the price was right! So let’s take...
                        02-22-2023, 06:28 PM
                      • vinaypundith
                        Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                        by vinaypundith
                        I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                        So, I'm looking for a BIOS dump for this machine - a 16MB one....
                        08-03-2024, 12:32 PM
                      • theplop
                        Razer blade 2022, 14" PI480 wont boot to OS, freezes
                        by theplop
                        Razer blade 2022, 14" PI480, Ryzen 6900HX, 16gb ram
                        I picked up a Razer blade 14" (2022) from a friend who said it "overheated" and he replaced one of the fans. He gave up on it as windows wouldn't work/re-install. He gave it to me, and i've been working on getting linux on it. Installing Mint i was able to get about 1/4 through the installer before it froze. Now i can't even get the installer to boot. I am met with a kernel panic.... sometimes. Sometimes it just hangs on the boot sequence.
                        I've run memtest quite a few times, and more often then not...
                        03-20-2025, 06:42 PM
                      • shellybelly
                        Razer Blade 2016 6700k 1060 RZ09-01952 suspected backlight power rail issue.
                        by shellybelly
                        Back Story
                        I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
                        So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be...
                        08-27-2023, 10:40 PM
                      • dbuergi
                        Sony WH 1000XM4 Headphones always on because of corosion?
                        by dbuergi
                        i got these headphones which were not charging or powering on. I found some corosion around the charging port and power board. After cleaning the headphones took a charge but directly powered on.
                        The power button ist without any reaction. I suggest that there ist still some gunk under the button and i get an always power on. Do you have any suggestions what to do? Is it possible to desolder the button for a cleaning?
                        I could replace the board for 25 euros but maybe there is another way?
                        11-04-2024, 09:29 AM
