deoxit & Fisher ca 880 amp, Akai AP-D40 turntable, sony zs yn7 boombox
  • gb77
    curious
    • Aug 2011
    • 76
    i have some old components & a not so old boombox that hopefully are only suffering from crud/corrosion that can be cleaned & lubed to restore function.
    the amp & turntable both have declined in function over the years & were put on a closet shelf for 5+ yrs. amp right channel was weak & now dead. tested phone, tape, aux & tuner inputs & left channel output is good on those components (R channel works fine in L input). speakers work fine on L output. i'll do all the knobs, but give attention to volume, pullout mix, and balance & hope that solves it like it did for ntehicks in his thread
    https://www.badcaps.net/forum/showthread.php?t=27273
    the turntable works but the speed control knob no longer raises the rpm up to spec. it may need to be re-adjusted after cleaning (i have the manual & instructions for V1 & V2 pot adjustment). here are links where i found good info & manuals (must register to download)
    Code:
    www.hifiengine.com/manual_library/fisher/ca-880.shtml
    www.vinylengine.com/library/akai/ap-d40.shtml
    in the pic below you can see the boombox has a set of 4 push buttons on top the CD door - some intermittent, some not working - the round one next to them works fine. it was used in a workplace, so dust etc landed on it regularly. still have the remote which works fine.
    i've not used contact cleaner or lube before, so hoping those who have will offer more specifics than what i've already read here or watched on youtube - namely:
    1. product - i'm not in a hurry & willing to spend more for a better product, but if i can get something local that is pretty good, i'd at least like to be able to consider it. i found microcenter carries paired 0.5oz spray deoxit spray & gold (looks like i can get 10x as much for less than $10 more elsewhere), & lowes has 13.5oz spray IDEAL Contact Cleaner
    2. application - spray or needle or brush or plastic tube. which deoxit (5% or 100%) & application method works best for various things i'm hoping to clean. do i need the spray to wash out the contacts, or can i let them soak a bit (how long - i read one suggestion of repeating over 2-3 days? does the cleaner dry quickly?), work the knob ~25 times and use canned air to blow out the crud (air is cheap!)
    3. where & how to apply - the vids i watched showed pots that have a hole on the bottom side & said that if not accessible, trying to get some from the front past the knob post/stem (knobs just pull off or what?). for the turntable internal speed adjust pots with the screw slot on top - go thru the top or? how about the topside control knob, also pops off? for the boombox buttons, do they pop off, or shall i apply on the top edge & let gravity do the work? any worries about the little LCD screen below?
    any advice is appreciated - thanks
  • gb77
    curious
    • Aug 2011
    • 76
    Re: deoxit & Fisher ca 880 amp, Akai AP-D40 turntable, sony zs yn7 boombox
    here's the update after 60+ views & no comments - but thanks for checking even if you have nothing to say
    found that ratshack carries deoxit d5 cleaner spray & g5 gold spray so got them when i went grocery shopping nearby - $40+ total. put d5 to work on the amp & the turntable. no change in amp's dead right channel (will ask about amp later since i picked up a free flaky channel Technics SU-Z780 with an apparantly quite nice SVI3205 power ic, that got d5 & g5 treatment & seems to work just fine now).
    the turntable's fine pitch adjuster now works smoothly (not jumping around at any touch). adjusting speed from the V1 & V2 pots required turning them all the way & the 45 speed is still a bit slow (<5% i think) with the top pitch adjuster all the way up. happily @ 33 there is still about 20% more to go. i dont play 45s so no problem. i'm wondering if anyone can suggest where to borrow a test record to adjust wow/flutter (V3,4,5) - nothing in the catalogue of my big city library where i used to borrow LPs - they must have junked them all tho i guess i could call about it.
    the boombox was left at my sister's & remains there, so nothing to report.
    for those wondering as i did having no experience.. i watched a few youtube vids where they point out alot of the front knob POTs have an opening on the bottom which may be hard to access. the fisher amp bottom comes off & makes it easy to reach openings on the bottom or the side - the volume & balance POTs were open & could be sprayed from top & bottom. the technics treble knob cant be accessed without desoldering stuff as far as i can tell, so i sprayed the post under the knob & left it at that. the others were reachable with the spray's long tube. i also sprayed the various push buttons / speaker A/B sliders as best i could.
    • rhomanski
      nowhere man
      • 5157
      • U S of A
      The Caig products are the best I've found so far. Sounds like your doing pretty good so far. A test record may come up on e-bay keep checking.
      sigpicThe Sky Is Falling
        Sony CFD-E55 boombox blown line transformer & repair
        by momaka
        Is a mid-2000’s boombox worthless? - I’d say probably yes or at least certainly a candidate for this thread:
        https://www.badcaps.net/forum/showth...post+worthless
        Long story long , my dad picked up a Sony CFD-E55 boombox over a decade ago from the trash room in a condo where we used to live.
        (Note: picture below is of the boombox after the repair.)
        He then put it in a box when we moved places and it sat in the garage for a few years. Eventually, I tested the boombox and found that it worked on batteries, but not on...
        10-03-2020, 01:13 PM
      • Soma89
        Numark TT500 Turntable...weird power "freezing" issue
        by Soma89
        Hello there,
        I have a TT500 dj turntable that sometimes "freezes" upon powering on. This means that it lights up as normal, but does not react when pressing the play button (to turn the platter) or adjusting any settings through the push buttons or even move the slider/fader control; it just freezes in place with its default settings.
        To get the turntable working normally again, I simply power off and on the turntable again and it usually boots up normally the second or third time around.
        The manufacturer is unable to provide me with a service manual....
        05-31-2022, 10:47 PM
      • mojos911
        Fisher and Paykel 10 kg top-load washing machine LED identification
        by mojos911
        I'm looking for a replacement for the red LEDs used in a Fisher & Paykel 10 kg top-load washing machine. Each LED is about 6 mm long, mounts flush to the PCB with side tabs, and measures around 1.7 V forward voltage in diode-test mode. The marking on the body is “3A56,” but I can't find any matches for that in part searches. I've attached photos to show the shape and mounting style.
        If anyone has sourced an equivalent or knows a suitable replacement, I'd really appreciate your input. Thanks in advance for the help!...
        01-17-2025, 06:54 PM
      • Evets
        Fisher TAC-M47 schematic
        by Evets
        Can anyone help me with a schematic for a Fisher TAC-M47.
        05-17-2024, 04:35 AM
      • Dannyx
        How I "fixed" the display on an Akai LT-3220AD TV
        by Dannyx
        Good day folks. I thought I'd share with you something I did today, just for a laugh and for a bit of a discussion, since I'm still not entirely convinced what happened there.
        I found an Akai LT-3220AD TV in the dumpster - literally - so me and my colleague brought it back into the shop and dusted it off a bit to see if someone maybe gave up too soon.
        Long story short: backlight came on but had no picture. My colleague attempted to reprogram the SPI chip but it didn't change anything, so we concluded it must be the panel that's faulty, especially after reading about it...
        01-29-2024, 10:12 AM
