How I "fixed" the display on an Akai LT-3220AD TV
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    Good day folks. I thought I'd share with you something I did today, just for a laugh and for a bit of a discussion, since I'm still not entirely convinced what happened there.
    I found an Akai LT-3220AD TV in the dumpster - literally - so me and my colleague brought it back into the shop and dusted it off a bit to see if someone maybe gave up too soon.
    Long story short: backlight came on but had no picture. My colleague attempted to reprogram the SPI chip but it didn't change anything, so we concluded it must be the panel that's faulty, especially after reading about it online and finding videos of others showing this fault and how to patch it up, for example this video, which shows almost the exact panel, with the exception of the buffer board itself which in our case is a MT3151A05-3-XC-1, while his an MT3151A05-9-XC-1. The panel model itself is KM315e6-cs-12.
    I wasn't able to replicate his results though, because my buffer gave me no VGH and VGL at all. The VGL test point was actually reading around 9ohms resistance to GND, so that wasn't going to work. Not having anything to lose, I did what any skilled tech should do at this point and that is.............hook that test point up to my bench power supply and start pumping Ok, I wasn't that much of a doof - I at least had the courtesy to go slow and not go over -6v, since I hooked the positive of the supply to the chassis and the negative to the test point itself. There was no current draw at all, so nothing spectacular happened.
    After that, I decided to have one final go with the multimeter and check the resistance on VGL again, since it didn't make sense: I just had a low-ish resistance, there should've been at least some current flowing somewhere. Guess what: the resistance was now up in the kilo-ohms range....dafuq ? Ok, but surely I won't get any voltage there, right ?....wrong: I now got -7v on the VGL test point.....AND picture on screen ! The TV works now....the picture is just fine too ! I thought for sure it would be a mess of colors and "ghosts", but no - perfectly usable !
    Ok, so I guess this is how we fix things nowadays: hook them up to the power supply and blow up whatever's shorted
    Realistically, I think what happened is I blew up whatever "gate" (?) was shorted on the COF, but it happened too briefly to show up on the ammeter. The power IC on the board was not designed to deliver current until something popped, so it immediately shut down upon startup, whereas my bench supply knew no such thing...
    Wattevah...
  • cind12
    GTX 1080 TI Gigabyte Aorus low resistance on vmem
    by cind12
    Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
    Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
    The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
    Resistance on 12V 4K ohms (Power present when on)
    Resistance on 12V PEX 4K ohms...
    12-08-2023, 09:09 AM
    HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point EliteDesk 800 i7-7700T Specification for Upgrade or Repair
    This specification for the HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point boardview and EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
    09-12-2024, 02:00 PM
  • Nagy Daniel
    Lowest possible resistance on laptop motherboard rail - Guide Table request
    by Nagy Daniel
    Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
    I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
    I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
    So, I generated a table with AI so I can...
    03-04-2025, 08:24 AM
  • Mita99
    Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
    by Mita99
    Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
    Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
    Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
    04-27-2025, 07:20 PM
  • novice1
    Acer Aspire E5-574G - Not Powering On
    by novice1
    Laptop name Acer Aspire E5-574G. Processor = i7-6500u. GPU = NVIDIA GEFORCE 940M. Motherboard Model = DA0ZRWMB6G0
    This laptop was not powering on at all so I started investigating. The blue light would come on for a second, and then disappear. Fan would sometimes turn on for a second and then shut off immediately, and at other times would not turn on at all.
    To start with, about 3 months ago I had no clue about soldering, motherboard schematics, board view, and then I stumbled about this forum and other stuff online. I have never done any of those before. But to ask...
    11-03-2023, 05:53 PM
