Re: kenwood TK-40 Output problem - need help with circuit debug
The 1uF used in those receiver are the one that tends to have current leakage, easiest will be to recap. This is VERY OLD unit, the filter caps in power supply should be replaced, you need to have stable power supply first.
The circuit ground to the chassis is also done through the PCB mounting screws so the screws for the board should be tightened.
I have SENCORE LC77 cap/inductor tester to test cap current leakage at rated voltage.
yes 669 - I misread your answer. Great I can get one of those and radio shack might even have them or be able to order them in.
For the thermistor - I haven't actually handled the board in a while (days, if not weeks, it's been screwed back on the chassis for while) so I'm pretty sure it's been gone for a while and that falling cap reading might be contributed to something else, since that has been steadily happening over the past day or so. A day ago it was 14v and today 7, so something is failing (I would think) But I totally hear you on the need to replace it.
I can (fairly) easily check the diodes, certainly clean the pots (though would be concerned I don't know what they should be set back to when done cleaning) however a wholesale parts check on that amp board will challenging - to put it mildly! It's a solder farm unlike anything I've ever seen. So much solder you can't tell where the parts are from that side, it flows over most of the board number points as well and with no board layout diagram, well - a challenge for sure....
I do have a transistor tester, so if I can get them out (and back) I should be able to go through those.
For the caps, I did ESR meter check all the 10uf and larger at one time, but I'm sure I missed some because as I said, you really can't tell on the back what is what. But your "leakage test" I'm not sure how to perform exactly, assuming that is different.Leave a comment:
I thought the one in the unit is 669, not 669A.
Right channel: The missing thermistor causes Q6 (on the circuit board) to be bias on a lot which in turn bias on output transistor Q5 to be bias on a lot which makes VCE voltage to be low @7.5V instead of around 22V.
Do not keep running without the thermistor.
Bias Diode string D4, D5 should be check real well, they tend to go open circuit and that will cause damage to the driver and the output transistors.
Left channel: Q2, Q4 on the board are not being bias on, same for the output transistor Q2, Q3 (E and B has no potential different, 2.9V on both legs).
I think you will need to test a bunch of transistors (for leakage, shorts, or open circuit) in this unit and also look for leaky (current leakage, not block DC) caps.
Bias pot VR5, 6 should also be cleaned.Last edited by budm; 04-21-2015, 11:31 PM.Leave a comment:
What DCV are you getting at the Collector of Q3, Q4 output transistors?
669A has beta of 170~400 compare to 669 of 70, so the Collector voltage may not be right, you just have to try it. NTE373 is supposed to be the replacement.
My 1988 Japanese transistor sub manual shows 2SD361 as a sub.
So someone worked on this unit before you?
39.4/39.2 on collectors of Q3/Q2. I took all the output readings and reposted again. Note those output caps continue to fall. Left side now down to 2.9 and right side to 7.5. Don't know if that Q1 failure in the power supply section is affecting these - it seems to drive a different board.
So you are saying NTE373 and 2sd361 are both replacements for the 669A, correct?Leave a comment:
So someone worked on this unit before you?Last edited by budm; 04-21-2015, 09:42 PM.Leave a comment:
Those capacitance values are fine.
In post 3 you indicated the reading of only 12.6V which is not what you are getting now, 17.3V, as you can see, the left side (in diagram) of R8 is connected to pin 3-4 of the power amp board.
" not sure how those are affecting that terribly low reading on the output caps (and the zero volts on both sides on amp board R14" That means Q 4 is not BIASED which in turn no bias for Q2 output transistor either.
By the way, there is JACK A 4-pin jack (as shown in the diagram between Q3 and Q4), is it missing?
On an unrelated note - I found the TH2 (SDT35 thermistor is missing from the right channel amp board. Looks broken off. and the Left side one doesn't look great either. I can't find any specs or alternate replacement from google. Looks like I could get them from sears parts direct but the shipping brings it to $13 so I was hoping to find a alternative that I could either get cheaper or from some place I'm more likely to order other things from.
I started to recapture a variety of voltage points (attached and shown in red) but I pushed Q1 2SC669 too far over and the base lead came off (right from inside the base so there's no repairing it. Google also fails to shows any equivalent for this transistor. The 2SC669A has a substantially lower upper limit (30v instead of 100), the Ved max is slightly lower (5v vs 6) and the Ptot (something to do with temperature/power dissapations is 1WF vs 10WC) so although I could probably get by with the 30v upper, I'm unclear if the latter two spec items are adequate for replacement. Anyway - I'm dead in the water until I can replace this piece.Leave a comment:
By the way, there is JACK A 4-pin jack (as shown in the diagram between Q3 and Q4), is it missing?Last edited by budm; 04-21-2015, 01:01 PM.Leave a comment:
Though not 100% ideal, not sure how those are affecting that terribly low reading on the output caps (and the zero volts on both sides on amp board R14. Certainly seems something on that board is bringing everything downLeave a comment:
Per diagram, one side is 22V (C22 is input fiter cap), and another side is 21V (C21 is the output filter cap) whcih is fed to pin 3 & 4 of the power amp board.Last edited by budm; 04-21-2015, 12:08 PM.Leave a comment:
R28 is 0/0.86 but I assumed you also wanted R14 also which has the left side wacky filter cap reading. It's reading 0 on both sides.Leave a comment:
OK, your is probably TK-40U.
PIN 3/4 pins should also be around 20VDC per sch.
Check the DCV of R28 both legs against GND to see what you have.Attached FilesLast edited by budm; 04-21-2015, 09:43 AM.Leave a comment:
"C17/C18 output caps show 5.5 & 14.9 respectively" That is way off, you did measure the + terminal of the cap, right?
That Voltage should be 1/2 of the VCC (VCC is the Voltage of the main filter cap), so there is problem for sure if that is the case.
As you can see in the diagram of the TK-40U, the Collector Voltage of the Q2 output transistor is shown as 22VDC but the Voltage on pin12 is shown as 18V, so there are many error in the diagram.Last edited by budm; 04-21-2015, 09:41 AM.Leave a comment:
31VAC will give you about 31 x 1.414 = 43.8 - .6V = 43.2VDC on the filter cap C23 (1000uF 50VDC) no load.
What DCV do you get on C15 filter cap for pre-driver circuit Q1, Q8?
What is the DCV on post 3 & 4 of the power board?
What are the DCV on the + leg of the C17, C18 OUTPUT coupling caps.
Those old 1uf caps also known for current leakage (leakage can cause damage to the circuit) and lose its capacitance.
I would recap the board, clean all the controls and switches real well, especially the tape monitor switches.
C15 Filter Cap shows 12.7vdc (Interesting to note they actually have 50uf caps/30vdc on the board though the schematic shows 47uf/16vdc. They look original though, so it may be a slight variation on the schematic revision that I don't have.
Post 3&4 show 12.6vdc
Controls were already cleaned previously with Detoxit and I thought pretty well and as I mentioned audio is already coming to the amp board, but I can run more detoxit through them to be sure.Leave a comment:
I would recap the board, clean all the controls and switches real well, especially the tape monitor switches.Attached FilesLeave a comment:
Have a Vintage kenwood TK40 with no output on either channel (maybe a very minimal sound if volume turned 100% up). I found a number of caps in the power section to be bad on ESR meter, though surprisingly not the larger ones. Replaced all the bad ones but only seeing 40V dc on the left side of D2/D3 in the schematic (attached). Schematic says should be 46v so a bit of difference. Right side does measure 31v (ac) so I believe the transformer is good and something is pulling the voltages down.
Did an audio trace and I have audio coming to the power amp section (inputs 1 & 2 on the left hand side of the schematic. On the right channel, I traced audio on the other side of the Cap C7. On the left there was no signal there at C10 so I checked the cap and it was shorted open. Replaced it and now have audio on the other side of that cap but audio is now totally weak and distorted, so something else in the circuit is affecting it. While the right channel doesn't have the same issue, is also has no speaker out either, so the signal isn't making it's way out.
Basically all the voltages on that board are low - substantially lower then what they should be - so I'm not sure if that is because the power supply section has a problem, or something on the board is "leaking" voltage somewhere. I'm no expert in electronics - definitely still in learning mode. Suggestions on what to try next/where to look?Tags: None
by FrancescoVGood morning everyone,
I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
The firmware reported is the following:
M:1.00/11107BLP
D:?.??/????????
O:1.00/11107AL
The DSP firmware given the question marks seems corrupt.
On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...-
05-11-2025, 02:59 AM -
by flibidyI have here a Magnum IA.100 which belongs to my parents.
The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
What Ive done........8 Photos-
01-01-2025, 01:26 PM -
Then today it randomly sprung to life like a zombie but shortly died thereafter. I have no idea why it would have done that and its the first time I've seen it running. I discharged capacitors on the board last night, then it was sitting today.... -
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by bauto601Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
A "nice" YoungYear unit? - Badcaps
The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish.... - Loading...
