Why is the volume on my right channel so low?!
  • Turkeybaster
    • Apr 2015
    • 3
    Hey guys, new poster and hobbyist.
    I have a Sony STR-k502p that I thought had a blown front right channel. After taking it in my shop and doing some problem solving steps I identified that it was not completely out, it was just running at about a quarter the level as all the others. I swapped sources, input channels, checked balance levels, yet it was always the front right at a much lower level than any of the other channels.
    What do you guys think is the issue? I popped open the case and cant visually identify any obvious flaws.
  • Uniballer
    • Jul 2013
    • 334
    Re: Why is the volume on my right channel so low?!
    Burnt resistor, bad capacitor, bad solder joint, half-blown semiconductor... Start troubleshooting.
    Have you seen this video? Good info (go find that online service manual). Sony STR-K502P A/V Control Amplifier
    Traditional audio methods:
    1. Inject a signal into the amplifier starting from the output stages back towards the input. Compare working and non-working channels as you go by the sound from the speakers. This allows you to spot the bad stage in the amplifier. Then you will need to test individual components to find the bad one(s).
    2. Check signal levels through successive stages with an oscilloscope, comparing working and bad channels as you go. Same as above: this identifies the bad amplifier stage.
    • Turkeybaster
      • Apr 2015
      • 3
      When I said "Hobbyist", what I should have said was fan on the sidelines with dreams of playing
      While I have a soldering iron, and passable skill with it, I have a cheap analog multimeter (which I will be replacing with a digital auto) and definitely no oscilloscope, not the skill to use one. My electronics experience comes from building and working on RC cars, so I'm a baby in your world.
      I would be able to replace a part if it was identified, but I dont have a background in electronics engineering, nor can I properly read a board diagram.
      I do have the repair manual though, and I am pretty good at learning from watching good Youtube vids as I am a visual learner.
      I did learn a decent work around for my problem, however, if I cannot fix it. As the receiver has a separate multichannel input, I am simply choosing two of the working channels, and wiring the speakers in accordingly, to create my own stereo front right/left as needed since it is just being used as a garage workshop stereo.
      • Agent24
        I see dead caps
        • Oct 2007
        • 4951
        • New Zealand
        You can also use another amplifier to trace the signal. Trace through alternating between both channels, find where the audio level drops in the faulty channel.
        -David VanHorn
        • CapLeaker
          Leaking Member
          • 8136
          or with an a sine wave on the amp input and poke around with the oscilloscope.
          • Uniballer
            • Jul 2013
            • 334
            Tracing an amplifier isn't that hard. I remember finding a bad transistor in my brother's stereo this way when I was 14-15 years old, and riding my bike to the nearest Radio Shack to get a replacement and putting it in. No schematic, but not too difficult.
            Try this video: Audio Troubleshooting
            • Agent24
              I see dead caps
              • Oct 2007
              • 4951
              • New Zealand
              Yes, that is a better way, but he already said he doesn't have an oscilloscope.
              -David VanHorn
                Use the computer sound card to generate 440 Hz tone to feed the amp inputs, then use True R.M.S DMM in AC mode to look at the signal level in each stages. If the meter just has simple one diode rectifier for Average AC when measure the circuit that has DC, the DC voltage will shows up in the reading, so you may have to use DC Blocking cap.
                http://www.electronics-lab.com/downloads/pc/005/
                • karthur
                  Vizio D65x-G4 Volume changes on its own
                  by karthur
                  On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
                  It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
                  06-05-2025, 08:13 AM
                • dicky96
                  American Audio VLP1500 Distorting on one channel
                  by dicky96
                  Hi guys I have a VLP1500 amplifier here - one channels works fine and the other channel distorts even at low volume settings
                  Protection and Clip LED are off
                  There is something wrong with the BIAS voltages around T16 and T18 (in particular) on the bad channel
                  I tested all diodes and transistors in this area in circuit with diode mode - both channels seem identical. Same in resistance mode across all the resistors here.
                  The output DC voltages on pin1 and pin8 of the 5532D dual op amp at the input of each amplifier module are the same, and the audio...
                  07-13-2022, 05:25 AM
                • Camarada78
                  Carvin PA620 shutting down
                  by Camarada78
                  I have a Carvin PA620 powered mixer with a weird problem: channel one shuts down the entire speaker output when plugged in. Its not a short because it still outputs sound through the line outs.
                  1. voltages are somewhat correct (-42/+42, -26, -17/+17, when it should be +-43, -24, +-18).
                  2. Channel 2 if plugged works normally, no issues, any volume.
                  3. Channel 1 if plugged very low volume, works normally. if goes a little louder, it shuts down everything (both speaker channels)
                  4. line out works normally in any situation, even after shutting down the speakers.
                  10-15-2024, 12:07 PM
                • rustinjust
                  Advice needed-Technika 32-207 works but sticks on channel,won’t change channels ok
                  by rustinjust
                  My tv will work for a while and change channels with the remote as it should but then it will stick on one channel only and work ok but it won't change channels. I have tried unplugging it for hours and whilst unplugged pressing the power button on the tv to reset it.
                  The volume button on the remote still works but it just won't change channels once it decides to stick on one channel
                  It has built in basic freeview tv here in the uk, I've tried doing an automatic search to reset the tv but nothing works.
                  I have to turn the tv off and then on again with...
                  09-28-2023, 12:23 PM
                  ALIENWARE Aurora R9 i7-9700 Specification for Upgrade or Repair
                  This specification for the ALIENWARE Aurora R9 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aurora R9 boardview and Aurora R9 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ALIENWARE Aurora...
                  09-12-2024, 03:28 PM
