Yamaha P2250 protected and channel A clip solution
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8259
    There are some threads in the web about this issue, but nothing on how someone fixed this problem. So I document it, since it still is fresh in my mini brain.
    I got this Yamaha P2250 out of the bin yesterday. Air dried it until today, checked a few things inside while it was drying (rectifiers, caps, other diodes, finals, drivers etc). Couldn't find anything wrong, so I did the AC light bulb in series trick and fired her up. I am just kidding.
    The protected and the channel A clip LED were on and she didn't want to get out of it. Frigg me... so I checked all the output transistors and drivers again. Nothing wrong. Checked the DC offset and it was within spec. Downloaded the service manual and thought, maybe the temperature protection is on. That was not the case either. So I took the whole power module A out and tried to run the amp with the power module B only. That didn't work as the amp was is protect mode again, even so there was no DC on the test point or anything on module B. So I decided to let her warm up some (took 15mins for me until the idling current adjustment stabilized). Set the idling current on module B for 12mv. I tried to fool with the protection circuit and no dice. Then I put power module A back into amp and hooked everything up again, trying to compare voltages between both modules and do another test on the protection circuit. Fired her up and? She worked! No more clip A and protect mode. So I let her warm up again for the idling current to stabilize and set Power Module A and again on B for 12mv. Amp is working good so far!
    That thing does 170wpc
  • eccerr0r
    old X58 triple channel board... memtest86 memory speed?
    by eccerr0r
    Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
    Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
    Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
    06-28-2025, 09:06 AM
  • HelpMeRepair
    Yamaha RX-A3010 left channel no signal
    by HelpMeRepair
    Hi everyone , I have a rx-A3010 that all alllll the channel working except of Front left , if someone can lead me on what to begin wit it would be very helpful
    what I did so far ,
    factory reset
    test all other channel
    tone test
    dissasemble and look , visual inspection witout full dissasembly
    looked at all the mosfet for temperature to see if they eas operating
    scratch my head couple of time
    thanks in advance all help is appreciated , service manual are welcome too ! =)...
    11-14-2024, 02:48 PM
  • xfreakx
    Yamaha XP7000 Crackling in left channel
    by xfreakx
    Hi guys,
    I have a problem with the power amplifier Yamaha XP700, I hope someone can help or point me in a direction.
    The amp started occasionally to crackle in the left channel which in a short time period got more frequent and after a while the crackling occurred instantly on power on.
    While checking for loose connections the amp's protection kicked in and turned the amp off. From then the protection turned the amp off in between 1 - 5 seconds after power on.
    I switched the mono blocks for a test to make sure the error is in the block itself...
    06-29-2023, 05:30 AM
  • mikey5791
    Help on car amplifier only one channel works
    by mikey5791
    Hi all forum members,
    Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
    My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
    08-06-2025, 10:36 PM
  • dicky96
    Hitachi V19B01922 Channel Tune problem
    by dicky96
    Hi Guys
    I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
    He also has an LG TV, so three screens in the bar
    I installed three Satlink ST-6503 DVB-T Modulators
    This model https://www.aliexpress.com/item/32916553905.html
    These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
    02-09-2023, 09:20 AM
