weak radio reception. trying to fix. SONY ICF-CD523
  • Go fish
    • Oct 2014
    • 7
    • CANADA
    Hey all,
    I've got this SONY Under Cabinet Radio. Model # ICF-CD523.
    Over the years the FM reception has really gone down hill. I would like to try and fix this. I opened up the radio and found the FM Chip CXA1960Q. From Pin #18 we go through a 26Ω resistor (R6) and then it goes out to a BPFI (GFWE2 SE). The input of this 3 pin device is fed from a cap (C953, 200pF).
    The other side of this cap goes to the secondary side of the step down transformer. So basically they are using the power cord as an antenna (as it is well known).
    I checked the resistor and the cap, and they are good.
    I can't check the BPFI unless I pull it and test it using a scope and oscilliscope... I'm sure there are other ways.. Anyways...
    Refer to the attched schematic I made up. I basically cut the antenna from going through the transformer. and then soldered in a new wire at the point shown. The wire is then fed through the enclosure and I tried running the wire at different lengths and directions.
    Because the outlet is right behind the radio, I cut 4 feet off the cord.
    Overall, this did improve things... but some stations still have some static.
    But a couple stations do not come in clear. 100.5 for example.
    Other radios in the home play 100.5 quite clear.
    I'm also surprised I can hear 100.5 in the back ground of a 97.5 station.
    Any thoughts... suggestions??
    Do I have my antenna wrong? Or is the chip CXA1960Q semi pooched?
  • R_J
    • Jun 2012
    • 9567
    Re: weak radio reception. trying to fix. SONY ICF-CD523
    Not sure if this will help....
      • 31100
      worth pointing out that using a power cord as an antenna is going to be worse and worse in the future as more people and company's start using the power line for digital transmission.
      and the ITU i think it is,the international standards group is talking about increasing the allowed power level by something like x30!!!!!
      • Go fish
        • Oct 2014
        • 7
        • CANADA
        For sure.... thats why I cut that feed, and ran my own wire.
        It impoved things.... but the odd station is wacky.
        • Go fish
          • Oct 2014
          • 7
          • CANADA
          Well,, I read through that tech manual. Thats great stuff. Lots of detail.
          I don't have the equipment to do the FM test...
          Is there anything else I cantest or try???
            • 31100
            do you know the antenna input impedance ?
            because the antenna is going to make a huge difference if it's impedance matched and properly calculated for quarter/half wavelength etc.
            you cant just throw a bit of scap wire around the room and expect good reception across the band.
              • 31100
              http://www.hamradio.in/circuits/moxon_fm.php
              • Go fish
                • Oct 2014
                • 7
                • CANADA
                I know I can't just run wire all over the place. I read a post on this forum where a guy ran 6.3 feet of wire for an antenna on a similar sony radio. I hooked up 8 feet of wire. Installed the radio where it belongs.... and then started cutting back on the wire until it sounded good. I'm at less than 2 feet. I'll look at that post... and do some research.
                • Go fish
                  • Oct 2014
                  • 7
                  • CANADA
                  in doing some research, is a dipole antenna worth trying?
                  I see some for 100.5MHz... which is the station I want to improve. But these antenna's have two wires. Would I ground one? Or is this antenna totally wrong. :O
                    • 31100
                    right idea, but you may need a balun transformer.
                    those used to come fitted to portable tv antenna for example.
                    this is why i asked if you know the input impedence.
                    • Go fish
                      • Oct 2014
                      • 7
                      • CANADA
                      I don't know the input impedance. My schematic above shows what I'm dealing with.
                      FM Chip, 26Ω resistor, a band pass filter, cap...and wire.
                      Is there a generic or safe value we can use for the average consumer radio?
                        • 31100
                        the word "safe" only applies to transmitters.
                        with a receiver it just means if you get it wrong, your reception goes to shit.
                        • mikey5791
                          Sony CFS-5000S radio cassette player no FM reception
                          by mikey5791
                          Hi forum members,
                          In the past i have had many helpful hints from generous forum members in diagnosing and solving issue related to most of my electrical things.
                          Fyi, i have been keeping this unit of Sony radio cassette player as the cassette belting has worn off but the radio has been working fine before. Recently, out of a sudden i found out i can't get any radio reception at all (no signal from FM,MW or SW band) except some buzzing warp noise from the speakers.
                          I opened the casing inside and checked for any dry solder, burned component or loose wires...
                          02-24-2023, 03:48 AM
                        • UserXP
                          Vintage SONY Digital Clock Radio ICF-C12W no audio
                          by UserXP
                          Dear all,
                          I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                          i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                          My question is, do you know of this brand of capacitors and how bad are...
                          07-21-2025, 08:35 AM
                        • shelby5041
                          clock radio / radio lifespan?
                          by shelby5041
                          hi
                          ive got a modern digital clock radio approx 15yrs old
                          my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                          since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                          the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                          it uses very little power just a few watts i would imagine that may have something...
                          09-14-2024, 03:30 AM
                        • praveenramavath
                          Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                          by praveenramavath
                          Hello All,
                          I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                          https://www.hifivision.com/threads/m...-screen.98243/
                          Troubleshooting Summary: Majority Internet Radio - Flash Chip
                          04-26-2025, 09:08 AM
                        • Carlos#2003%
                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                          by Carlos#2003%
                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                          02-15-2024, 07:52 PM
