Bose Acoustimass 15
  • kevinm34232
    • May 2012
    • 1884
    Bose Acoustimass 15
    Is anyone familiar with Bose systems, this is a subwoofer that is dead that I am trying to fix for a friend. I found two 20 ohm SMD resistors on the bottom of the board that were open. I replaced them with 2 from a scrap board and I heard it power up, but one resistor went open again. I'm not sure if it wattage was too small, or there is some other problem.
  • kevinm34232
    • May 2012
    • 1884
    Re: Bose Acoustimass 15
    Also this leg of C23 connects to pin 1 of connector J2, which goes to large secondary transformer. If I connect the transformer to J2, all pins of J2 short to same leg of C23.
    Does this mean the transformer is shorted??
    • kevinm34232
      • May 2012
      • 1884
      Replaced the two 20 ohm resistors with one larger 10 ohm resistor fixed this.
        master hoarder
        • May 2008
        • 12170
        • Bulgaria
        Interesting.
        Looks like those two 20 Ohm resistors in parallelI are in series with C23. I wonder if C23 going bad/shorted. Failure mode of metal film caps is not always a short circuit (and is rare), but it does happen. Most ofthe circuitry in the area appears to be connected to line voltage, so it is possible that C23 could have gone bad.
        It's a bit hard to understand what that circuit does, though. I can see line voltage going through the plug, then the switch, then the fuse, but after that it looses me. If C23 is used like a X2 safety-cap, it could fail due to a voltage spike on the line. And if C23 is used as a high impedance low-voltage signal source (read: cheap way to bring line voltage to IC supply voltage), then that could have caused it to fail as well. You might have to trace this on paper for us to get the fuller picture.
        But I guess if it works now, no point in doing that, right .
        • kevinm34232
          • May 2012
          • 1884
          Ya and it seems from what I could find, that this is a common issue, if it doesn't blow the fuse first.
            Do you mean C24 (1.5uF) and the 10 Ohms R100 as shown on page 4 of the SCH?
            That is the RC Snubber for the TRIAC which is used as A switch to turned on and supplies Voltage to the primary side of the transformer so it is powered up from STANDBY mode when audio signal is detected. That RC is large in capacitance because when the TRIAC is not on and the unit is in standby, the primary gets the current through the RC network just enough to run the standby/audio detection circuit.
            The audio detector and rectifier (U9, U12) that convert AC to DC for the timing RC circuit R92/C22.
            Seems to me that the power handling of the resistor is too small, the SCH is shown as 1/4 W, so when the resistor is open, there is no voltage applied to the primary side of the transformer to run the audio detector/Timer circuits to turn on the TRIAC.
              master hoarder
              • May 2008
              • 12170
              • Bulgaria
              Oh, I see now.... O/P provided schematics
              Yeah, looks like the primary side of the traffo is powered through that RC network (R100, C24) when in standby. Crappy design, IMO. I've seen a lot of double-insulated small kitchen appliances' logic boards use that RC kind of circuit with a Zener diode to bring AC voltage from the wall down to a lower voltage that the IC on the logic board can use. More often than not, the cap in the RC network either overheats and opens, or becomes shorted and then the Zener bites the dust.
              But hey, it's cheap and it works! (for a little bit - just enough to pass warranty period)
              • nobbnobb1
                Bose Acoustimass 10 IV Subwoofer No Sound. Help with burnt component identification?
                by nobbnobb1
                I picked up this used Bose Acoustimass 10 IV speaker system. Speakers seem to work fine, but the subwoofer does not make any noise. So I took apart the unit and found some obviously failed (burnt) components:
                - 1x 3.14 A @ 250V main circuit fuse
                - 1x bridge rectifier GBU601. there's actually two of these on the board, one is obviously burnt and the other does not seem to have any anomalies like shorts. However I figure may as well replace both.
                - 2x diode. This is tricky because the only markings I see on it are: "617 402". No current rating or anything else....
                11-16-2024, 09:56 PM
              • nobbnobb1
                Transformer Whine: Can it be rebuilt? Mirage S8 Subwoofer
                by nobbnobb1
                Hi guys,
                I'm trying to repair my Mirage S8 subwoofer (equivalent to the Energy S8.3) which is an excellent unit. It developed a light hum recently, which I thought was the capacitors. I replaced all the capacitors, and upon reassembly the buzz got louder. I thought I had messed something up electronically, but even when I swapped out the old capacitors it was still buzzing. So I inspected closer and discovered the noise is coming from the transformer. It's REALLY loud, which was surprising.
                There are no specs on the transformer and no relevant part numbers. I Googled...
                09-20-2022, 09:54 PM
              • eccerr0r
                Bose recall on several older Acoustimass, Liefstyle, Companion model subwoofers?
                by eccerr0r
                https://www.cpsc.gov/Recalls/2023/Bo...to-Fire-Hazard
                Anyone happen to know what the exact failure mode is? Is it a Rifa?
                07-05-2023, 07:36 AM
              • TinkerTron
                Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                by TinkerTron
                Hey everyone,
                I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                Instead, here's what's been bugging me so far:
                The schematic...
                03-06-2025, 02:03 PM
              • FALKLAN
                Mercedes-Benz W163 Bose Audio System
                by FALKLAN
                Howdy everyone!
                I have a SUV with a Bose audio system and I'm considering either a system upgrade, or purchasing a complete replacement system while bypassing the integrated Bose system.
                On the Bose side, I have not found any specifications yet. It's a decent system but I'm, at a minimum, replacing all the factory speakers, head unit and adding an amp and two 8" subs. The Bose is a 2ohm system and I'm not certain about this point. In order to use a 4ohm set of speakers (component/loud), I would need to install 2 sets of 4ohm speakers wired in parallel to match the...
                12-07-2023, 11:22 PM
