Resprom EMS1511 dead :(
  • DJduck
    • Dec 2012
    • 229
    • Estonia
    Haven't posted on this forum for a while, but here I am again, with another problem.
    So basically, I bought a Bulgarian made Resprom commercial amplifier (with the 100V line transformers removed) a while back to use it in my PA setup. But this thing ended up sounding so bloody brilliant, that I just couldn't resist using it in my main audio setup.
    Then I started fiddling around with it. Recapped it and changed output wires. Now I started making it into a fully featured home stereo amplifier, which included removing all the useless wiring and connectors. The stuff that I removed is all a part of the "control" circuitry. It is only used to control the amplifier from the preamplifier of this set. But I don't have any other pieces from the set, only the power amplifier.
    http://www.kn34pc.com/sch/sch_ampl/r...m_emc_1511.gif
    Above is the full schematic of this amplifier. Two modules on the left are the amplifier channels. There are two channels in this amplifier, therefore two blocks. The upper schematic is for the power supply. Circuit on the right is the "control/bridging" card, that has no use when this amplifier is not used as a set. This card has been removed from the amplifier, and the amplifier still continued working after removing the card.
    Well, what happened is that I basically removed all the wiring except for power supply wires and output wires. Added new input wires.
    So after all that had been done, I turn it on and the power light comes one, amplifier module relays click in and "working" LEDs light up. But just in case, I hooked up my multimeter to the outputs, and boy am I glad I did. Why? Because there is 13V of speaker roasting DC on the output!
    So what the hell?!
    I disconnect POWER GROUND from CHASSIS ground, and the DC is gone. Reconnect them, and 13V DC on the outputs! Two grounds disconnected from each other, my multimeter measures 13V DC between the two grounds. Power ground disconnected from chassis ground, input and output grounds connected to chassis, I get a very quiet, distorted signal on outputs. Input ground and output ground connected to power ground, or power ground connected to chassis, and 13V DC on the outputs.
    Remember, amplifier modules are fine, they were working just before I rewired!
    So I made a stupid mistake in the wiring or something and now I need the help of you guys to get this amplifier up and running again!
    Below you will find a picture of how my stuff is wired up. Marked with red is everything I removed, green marks the card that has been removed, yellow marks some points in the circuit, I labeled them because the schematic is in Bulgarian.
    So please, help me resurrect it, I NEED MUSIC! :P
    Cheers!
    http://www.upload.ee/image/4314044/s...m_emc_1511.gif
    I can put text here?!
    • 31015
    Re: Resprom EMS1511 dead
    i think when you pulled the transformers, you should have fitted DC blocking output caps.
    i'v not seen a power amp before that pretty much connects the speaker directly to the power via not much more than a transistor!
    remember, transformers cant pass DC, but without one - well good luck!
    • DJduck
      • Dec 2012
      • 229
      • Estonia
      It worked fine without a cap before
      Most good designs don't require output caps, some need inductors, but only cheap designs use output caps.
      • DJduck
        • Dec 2012
        • 229
        • Estonia
        Got it working!
        It was a grounding issue!
        • JimMc0
          Gigabyte GA-H61M-USB3-B3 dead short 3.3v rail to ground.
          by JimMc0
          Hi there,
          I discovered this forum through a youtuber who teaches electronic repair. I've been trying to troubleshoot my dad's old PC which is a Gigabyte GA-H61M-USB3-B3 and will not power on. I discovered a dead short on the 3.3v rail at the ATX connector so I used a bench power supply to feed 3.3v into the ATX connector and sunk about 400mA into the board (I hope that's not too much!). I used a FLIR camera to identify the problem area:
          The chip seems to be the following, an ITE IT8892E 1108-CXS which seems to be a PCI bridge?
          03-27-2024, 08:36 AM
        • roadrash
          Yamaha HTA-5630RDS Amplifier dead
          by roadrash
          Belongs to my son and he just says it stopped turning on. Any help greatly appreciated. Theres 240v in and fuse is ok but no power anywhere else.
          12-12-2024, 10:19 AM
        • double_DD
          How can I be sure that my EC chip is dead?
          by double_DD
          As the title suggests, how can I be sure that my EC chip is really dead?
          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
          03-12-2025, 07:47 AM
        • flibidy
          Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
          by flibidy
          I have here a Magnum IA.100 which belongs to my parents.
          The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
          Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
          What Ive done........
          01-01-2025, 01:26 PM
        • disorder
          ps5 edm-033 dead after hdmi/usb ports destroyed
          by disorder
          hello guys,
          i need help to repair a edm-033 ps2
          history : as always hdmi port and usb ports destroyed after unplugged
          after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
          so i changed it
          now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
          but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
          i don't see any projection of liquid metal on pcb.
          01-14-2025, 12:48 PM
