Pioneer VSX-1122K won't turn on
  • Packard93
    • Jul 2016
    • 81
    Re: Pioneer VSX-1122K won't turn on
    How are your fuses ? Disconnect all power and Do you have continuity check on fuses ? This looks like a red flag you said voltage was under a volt .5 at page 88 (BD9328CN) V+3V3_HHH. I think when I read your schematic you have more than one of these if u got another one u can read it too get some measurements off it ic 9521 is the same can take a look at it to see if it ends with 3volts at V+3R3_NW
    • tibimakai
      • Jan 2012
      • 3680
      All other voltages are there, only this 3.3V_HHH is .5V.
      I have to find out where exactly is used this HHH voltage. There are other 3.3V on the board, those are showing 3.3V.
      • tibimakai
        • Jan 2012
        • 3680
        Most likely, the protection is tripped, by this short and not from the amp section.
        • 88irocvert
          • Nov 2018
          • Puerto Rico
          #44
          Sorry for bringing this back from the dead but I have the EXACT same problem on the same model. Lightning strike, stuck on Power On message. Followed service manual until X3002 15MHz. I believe it's correct but not sure because the measurement fluctuates. Then I have no idea how to perform the final step of "Check Reset IC (IC3005)" which is part number J126077004210-IL. I'm just wondering if you ever fixed it.
          • tibimakai
            • Jan 2012
            • 3680
            I have found another receiver on CL, that had a blown amp and swapped the HDMI boards with that. I was only $40.
            • easy_mike
              • 4
              #46
              Originally posted by tibimakai
              I have removed the IC, but the short is still there. I have checked the nearby components and they all look good. My question is, how do I find the shorted component?
              This is a slightly destructive way to find a short:
              -you detach the affected board from connectors
              -you cut the supply paths that lead to 3,3V regulator if necessary
              -on the regulator output path you solder two wires that you connect to your power supply which will be set to 3,3V and current limit of 3A.
              -you let the current flow for two minutes and wait for the affected component to heat up!
              -apply isopropanol (alcohol) on the board. Where the shorted element is hot, isopropanol will evaporate! Check with finger... ouch -> there's the proof.
              Also check this:
              https://www.youtube.com/watch?v=t5fICjcaJ3E
              • tibimakai
                • Jan 2012
                • 3680
                Thanks Mike, I'm aware of that procedure(laptop repair, right?).
                This one is long gone.
                I have an 820, which is completely dead, only if I rest it, with the Adv. surr.and Power on turns on for a few seconds, and then shuts off.
                • 88irocvert
                  • Nov 2018
                  • Puerto Rico
                  #48
                  Thanks. Does that mean you fixed the VSX-1122 by changing the D-MAIN ASSY (HDMI board)?
                  • tibimakai
                    • Jan 2012
                    • 3680
                    Yes.
                    • kronos77
                      • Aug 2022
                      • malaysia
                      #50
                      Hello there.. I know this an old thread, does anyone have good vsx-1122-k dump bios file?
                      • RatherLoopy
                        Pioneer VSX-44 receiver HDMI dropouts
                        by RatherLoopy
                        I have an older Pioneer receiver (VSX-44) that's been dropping the HDMI output (black screen) for a few seconds every few minutes. Setup is HTPC -> Pioneer DVD HCMI in -> Pioneer HDMI out -> Samsung TV HDMI in, all with cheap HDMI cables that have never caused trouble before..
                        I initially found a lot of play in the receiver's HDMI inputs and output so I kind of squeezed them back into shape and they're making a tighter connection, but the problem persists.
                        And also, often, the HDMI will drop out in exactly the same way (black screen) just as my central air...
                        05-26-2023, 03:54 PM
                      • matpod16
                        Pioneer VSX-D1011 - turn on problem
                        by matpod16
                        Hi all! I have a problem with Pioneer VSX-D1011 – it don't turn on when the amplifier is disconnected from the socket for a few minutes. Standby LED doesn't light up. I'm a beginner in electronics, so I'm not very good at reading schematics. I tried to find the visual damages of components but I didn't see anything wrong. All of the fuses are ok, both of the switches the same. Have you any idea where should I start looking for? Once on every 100 tries I am able to turn it on, but what can it depend on?
                        09-07-2023, 01:43 PM
                      • pajdek
                        Lenovo Y700-17ISK turn on and off
                        by pajdek
                        Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                        09-20-2023, 02:49 AM
                      • pulper111
                        Pioneer VSX-1123 Receiver - weird voltage problem
                        by pulper111
                        Hello. My receiver "seems" to be working fine. It functions as it should. the receiver is the Pioneer vsx-1123. However, while doing some work in the house, I noticed that my HDMI cable from the receiver was registering as "hot" using my fluke non-contact voltage tester.
                        I've done some troubleshooting to try to narrow down the problem, and all wires (speaker/hdmi/subwoofer) coming from the receiver, whether it's powered on or stand-by, register as "hot". none of my other receivers are experiencing this issue, so it doesn't seem to be an issue with...
                        09-02-2020, 11:12 AM
                      • ccbargains
                        Pioneer SX-S30 need help identifying SMD semiconductors Also need service manual and/or schematic
                        by ccbargains
                        I have not been able to locate a service manual for this Pioneer SX-S30 receiver. The unit will not turn on. I am troubleshooting the switch mode power supply. I found three smd semiconductors that test open while in circuit. The first (Q904) is a transistor marked AZ43W. The second is a diode D905 marked L68 and the last is a diode D906 marked 66 CU1M. I have attached photos.
                        Any help would be appreciated. Thank you....
                        06-30-2024, 11:55 AM
