Pioneer VSX-1122K won't turn on
  • tibimakai
    • Jan 2012
    • 3680
    I'm starting a new thread for this receiver.
    I don't have a service manual for this receiver, so I really need some help there.
    This receiver is completely dead. I don't know which key combination resets the receiver.
    I have tried the usual Pioneer button combinations, but it is still dead.
    The power supply is totally different then the 1022k model. It s a SMPS style power supply.
    It seems like the standby voltage of 5V is present, at the main capacitor, there is 161V which is present.
    I have applied 6V on the relay and it clicked, so this one most likely it's not the cause.
    There is a TOP258MG IC on the board.
    What seems weird to me, is that the double diode after the transformer shows AC voltage on all three pins. There is another glass diode, which shows only 0.088 on the diode testing setting. This seems to be installed at one of the output voltages.
    I have tested the TOP IC for short and I did not find any.
    Soon I will take some pictures.
    I have also turned on the receiver, with all the wire harnesses disconnected from the amp, still a no go.
    Any help would be appreciated. A schematic would be great.
    I'm wondering which other Pioneer receiver would have the same, or similar power supply?
  • tibimakai
    • Jan 2012
    • 3680
    Re: Pioneer VSX-1122K won't turn on
    I have found the service manual under VSX-60.
    It seems like this whole power supply, it's only for a 5.6V/3.2A power source.
    This would be the standby board?
    I have forgot to mention, that there is no relay clicking at all.
    • tibimakai
      • Jan 2012
      • 3680
      • tibimakai
        • Jan 2012
        • 3680
        Anybody has any ideas what to do with this receiver?
        Since it is a SMPS power supply, can I do the resistor forced start up, like on TVs?
        The 5.6V is there, but there is nothing at the Mainpower input. I'm thinking, that would be the start up command(power on) signal.
        This signal is coming from the HDMI board.
        The relay get's 5.6V. but I don't hear any click, that is weird.
        • tibimakai
          • Jan 2012
          • 3680
          The relay has a cover, so I have removed it and forced it to turn on.
          I had the click this way, but nothing else happened. Tried the reset also, it's still a no go.
          The voltages from the transformer, that go to the front panel are there 2 x 2.7Vac, the connector CP1 2 x 41.5Vac going to the main base board(I believe it's the D board) are there. At the connector CP2 there is a 10.3V. At the connector CP3 there are 2 x 13.5V.
          I have tried with or without the amp connectors connected, no difference.
          Power button is good.
          So it seems, that the SMPS and transformer are working OK. Something else causing the problem.
          Just in case, I will take out the amp section and measure the finals, to be sure that there are no shorts.
          Any ideas would be appreciated.
          • tibimakai
            • Jan 2012
            • 3680
            Amp section looks good, did not find shorted finals.
            • tibimakai
              • Jan 2012
              • 3680
              OK, I have noticed in the service manual, that there is a troubleshooting for no power condition.
              I have followed the steps, all the way to check the 15MHz at quartz X3001.
              I don't know how to check this. The scope shows a wave form(sinus), but I don't know how do I know if it is 15MHz or not?
              After this step, there is the last step, is to check the reset IC IC3005(J126077004210-IL). I can't find any info about this IC. It is a four pin tiny IC and is available to purchase from pacparts.
              What this reset IC should do and how could I check it?
              • tibimakai
                • Jan 2012
                • 3680
                The previous owner, mentioned that it's possible that a lightning caused this problem.
                • tibimakai
                  • Jan 2012
                  • 3680
                  I have managed to measure the 15MHz and it's OK.
                  The reset IC can be checked with a scope at pin #1 and #2.
                  These readings don't really look like what they are showing in the SM.
                  I'm not sure if I'm using the scope the right way though.
                  After this I thought to try another type of reset procedure, that I have read about on vs forum. I have held the power button for 10 seconds and the display turned on showing Power On. The problem, that it just sits there with that message. I'm trying other resets, or entering service mode and nothing else seems to work.
                  At least, it shows some "life". I'm not sure, what else can I do. Any input would be appreciated.
                  I'm thinking to replace that reset IC, but I don't know what it does in the fist place. I'm thinking if pacparts sells these parts, it could be a common issue with these receivers.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    So many views and nobody has any ideas what could cause this symptom?
                    Just to recap the current situation.
                    Receiver would turn on only, if I hold the On/stby button for 10 sec. and it shows Power on and it's stuck there. It could be corrupted firmware?
                    • tibimakai
                      • Jan 2012
                      • 3680
                      Nobody has ideas?
                      Why would stop powering up? The speaker relays do not click.
                      When this happens on TVs(like Vizoi logo on screen), usually is corrupt EEPROM right?
                      • tibimakai
                        • Jan 2012
                        • 3680
                        Nobody?
                        The 10 sec reset, is not even mentioned in the SM. I don't know what is doing the receiver, when I do that. It just turns on and shows Power On.
                        • tibimakai
                          • Jan 2012
                          • 3680
                          Anybody could explain how these receivers work?
                          What it takes to get a fully turned on receiver?
                          It doesn't turn on the speakers(no second relay click), it could have some issues with the amp? But then, why is not showing an error code?
                          It could be a corrupt firmware?
                          • tibimakai
                            • Jan 2012
                            • 3680
                            After I reset it and it shows the Power on on the display, I have measured all the DC voltages after the main transformer and the voltages are there. +/-56V, +/-12V, +/-5V, 5.6V stby, power on 4.2V(?!) for smps power supply. The last one I haven't really checked yet, what it suppose to be.
                            There is another voltage -30V FV, which shows only -23V. I don't know if that is enough or not.
                            I could really use some help with this receiver.
                            • R_J
                              • Jun 2012
                              • 9594
                              The -30 fv is for the florescent display, being a bit low may cause the display to be a bit darker that it should but if the display is working don't worry about it for now.
                              The speaker relays will not turn on if there is dc voltage at the output of the power amp.
                              This is to protect the speakers, check for dc voltage on the relay contacts (on the amp side not the side going to the speakers) it should be less than a volt. if its close to + or - 50 volts there is a problem with that channel of the amp. (you may need to monitor that point as the amp is turned on) check each channel (you could also check the voltage at the junction of the emiter resistors ie (r424 and r430) (r517 and r511) etc. they may be easier to access
                              • tibimakai
                                • Jan 2012
                                • 3680
                                I have already tested the final transistors and I did not find any shorted one.
                                I will look into the relays. It's very hard to measure in there.
                                If I remove the back plate, I'm getting some kind of error and it won't turn on.
                                I'm placing wires to some boards to the chassy, but it still shows an error(blinking led).
                                Which board/output has to be grounded?
                                Thank you, for replying, I was getting desperate with this receiver. It almost seems, like a software problem.
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  Each amp has a test connector, so I have measured those points at pin#3.
                                  They are all between 0.020-0.030V.
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    The voltages that I'm getting are right?
                                    They shouldn't be half the supplied power(58V : 2= 29V)?
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      Any more ideas?
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        I have checked the protection circuitry.
                                        On page #35, there is a Temp protection circuit, where are two pins at IC3004, one is #72 and the other is # 81.
                                        On pin #72(TR_Detect/Normal 5V and TR Thermal 0V) I'm measuring 4.22V and on pin #81(TEMPSD5/Normal 5V and RADI THERMAL 0V) I'm measuring 5.027V. This look good.
                                        Not sure about that 4.22V it's not 5V though.
                                        Another protection circuit is the Overload and DC protection circuit. It's on page #33.
                                        There are two pins, that I should measure, pin #71(XOLERR) and pin #80(XDCERR).
                                        At pin #71, I'm measuring 4.405V and at pin #80, I'm measuring 4.865V.
                                        I don't know, how much these should be, but since the V+5V_ST is 5V and these voltages are after two resistors, they seem right no?
                                        • RatherLoopy
                                          Pioneer VSX-44 receiver HDMI dropouts
                                          by RatherLoopy
                                          I have an older Pioneer receiver (VSX-44) that's been dropping the HDMI output (black screen) for a few seconds every few minutes. Setup is HTPC -> Pioneer DVD HCMI in -> Pioneer HDMI out -> Samsung TV HDMI in, all with cheap HDMI cables that have never caused trouble before..
                                          I initially found a lot of play in the receiver's HDMI inputs and output so I kind of squeezed them back into shape and they're making a tighter connection, but the problem persists.
                                          And also, often, the HDMI will drop out in exactly the same way (black screen) just as my central air...
                                          05-26-2023, 03:54 PM
                                        • matpod16
                                          Pioneer VSX-D1011 - turn on problem
                                          by matpod16
                                          Hi all! I have a problem with Pioneer VSX-D1011 – it don't turn on when the amplifier is disconnected from the socket for a few minutes. Standby LED doesn't light up. I'm a beginner in electronics, so I'm not very good at reading schematics. I tried to find the visual damages of components but I didn't see anything wrong. All of the fuses are ok, both of the switches the same. Have you any idea where should I start looking for? Once on every 100 tries I am able to turn it on, but what can it depend on?
                                          09-07-2023, 01:43 PM
                                        • pajdek
                                          Lenovo Y700-17ISK turn on and off
                                          by pajdek
                                          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                          09-20-2023, 02:49 AM
                                        • pulper111
                                          Pioneer VSX-1123 Receiver - weird voltage problem
                                          by pulper111
                                          Hello. My receiver "seems" to be working fine. It functions as it should. the receiver is the Pioneer vsx-1123. However, while doing some work in the house, I noticed that my HDMI cable from the receiver was registering as "hot" using my fluke non-contact voltage tester.
                                          I've done some troubleshooting to try to narrow down the problem, and all wires (speaker/hdmi/subwoofer) coming from the receiver, whether it's powered on or stand-by, register as "hot". none of my other receivers are experiencing this issue, so it doesn't seem to be an issue with...
                                          09-02-2020, 11:12 AM
                                        • ccbargains
                                          Pioneer SX-S30 need help identifying SMD semiconductors Also need service manual and/or schematic
                                          by ccbargains
                                          I have not been able to locate a service manual for this Pioneer SX-S30 receiver. The unit will not turn on. I am troubleshooting the switch mode power supply. I found three smd semiconductors that test open while in circuit. The first (Q904) is a transistor marked AZ43W. The second is a diode D905 marked L68 and the last is a diode D906 marked 66 CU1M. I have attached photos.
                                          Any help would be appreciated. Thank you....
                                          06-30-2024, 11:55 AM
