Corsair SP2500 parts information required
  • laggen
    • Sep 2014
    • Sweden
    Re: Corsair SP2500 parts information required
    Have the same problem, BIG shortcut somwhere, where was yours ?
    • lexwalker
      • Feb 2011
      • 307
      • Malaysia
      Originally posted by ouroboros
      Could you measure the resistance between positive and negative of connector CN101 for me? it's on the amplifier board...
      nevermind the above, found the short that caused the problem and got it working.
      Sorry for the late reply, little busy at the moment (more repairs coming in again). Have not gone back to the speaker yet (although all the parts ordered have arrived). Mind enlightening us on the shorted part/component found?
      • ouroboros
        • Aug 2014
        • 11
        • Finland
        It was on a side of smd cap near one of the amplifier chips (backside of the board).
        • admiralranga
          • Oct 2014
          Hey could any of you tell me the value of R293 mines completely blackened, also if any one has the part number for the unlabelled 8 pin IC on the SMD side that'd be awesome.
          • Smiffy
            • Feb 2006
            • 16
            Couldn't find R293 on board.
            R930 def 10K.Mine has taken out R921 and R922 and R930 if anyone has the values of R921 and R922.Also C934 has blown and R not sure what number but next to C967
            on the top side which is second one along from IC.
            Audio board looks fine.Last Corsair product I ever buy
            Smiffy
            • Nicolasdu28
              • Jan 2015
              • france
              #26
              Hi everyone.
              My Sp2500's PSU partially died.
              the small part that powers the pod is working.
              But the part tha powers the amps is dead. ( 3 blowed caps, 2 or 3 dead resistances.)
              Since i don't have the equipment required to repair it, i think that i'll buy another PSU in parallel. But I don't know the voltage of the 4 pin. there is 3 inscriprions next to it : VCC GND and CN904.
              Thanks a lot,
              Nicolas
              • Cyborg62
                • Jan 2012
                #27
                Originally posted by Nicolasdu28
                Hi everyone.
                Thanks a lot,
                Nicolas
                I can tell you that VCC is supposed to be +27V
                Cheers
                • Merlin_AmiBay
                  • Nov 2015
                  • 8
                  I've had the PSU board of a Corsair SP2500 handed to me for repair. The 3843GM-E1 has died with one of the legs (pin 3) having had the track lift from the heat of the failure, along with three resistors (two large, one small) that died on the other side of the board.
                  From looking at photos of other SP2500 boards in various stages of death, I have worked out that the possible values for the two large resistors are 0.22 Ohm and 56 Ohm, with the two smaller resistors being rated at 1k Ohm and 220k Ohm.
                  Can someone please confirm these values, along with providing possible sources for the 3843GM-E1?
                  This design of PSU by Corsair doesn't appear to be up to the job. I've seen lots of boards with exactly the same failures and the lack of an earth pin on the Euro socket worries me. it's either bad design or poor components (or both).
                    • 31187
                    uc3843 should be at farnell
                    not sure what the gm-e1 means
                    • Merlin_AmiBay
                      • Nov 2015
                      • 8
                      The chip has GM marked on it after the 3843. The -E1 was added by some Google searches. It's the right current mode PWM controller though.
                      On this board, it's the current sense line to pin 3 that has fried and taken the chip with it. What is bothering me now is what caused the current surge, that fried the track?
                        • 31187
                        maybe the chip shorted.
                        any time one of the 384x series dies btw, replace the related startup and smoothing caps.
                        a lot of the older controllers like 3842/3 and TOP series can blow if the startup fails from poor caps.
                        • Merlin_AmiBay
                          • Nov 2015
                          • 8
                          Thanks, will do.
                          • nagal
                            • Mar 2016
                            • 6
                            • indonesia
                            #33
                            Hi All.
                            I have problem with Corsair SP2500, some part burned, can someone help to indentity R919 ? and I need schematics for this model.
                            Thanks advance
                            • Sephir0th
                              DELL XPS 15 9560 - No VCore, Power Off after few seconds
                              by Sephir0th
                              Hello Community,
                              i'm troubleshooting this one since days and actually i'm really lost because i believe i'm Missing the required experience for an issue Like this...
                              It is a Dell XPS 15 9560, i7-7700HQ, GTX1050 Board Number LA-E331P Rev 1.0, Most similar to LA-C361P so i use this Schematics.
                              Issue: Starts and shuts Off after a few Seconds. Basic Troubleshooting (Adapter,RAM,BIOS/EC Flash from alisaler) of course already done, which didn't Changed anything.
                              I have another working Board with i5-7300HQ and GTX1050, with It's Help i can compare...
                              05-09-2021, 11:22 AM
                            • narf
                              Epson EB-U42 projector / Caps with 0.7 ohms ?!
                              by narf
                              hi all,
                              first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
                              i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
                              what i've found so far:
                              - the PSU does its job and supplies 12V to the mainboard via the connector.
                              - shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
                              - not far away, there's the first cap with a resistance of 0.7 ohms....
                              07-02-2024, 03:53 PM
                            • Mark D
                              Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
                              by Mark D
                              The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
                              10-29-2024, 03:15 PM
                            • h0m3w0rk
                              Random Shutdowns/Startup Failure with Corsair SFX 450
                              by h0m3w0rk
                              I'm encountering a frustrating issue with my Corsair SFX 450 power supply. After an undefined period of operation, my PC will either suddenly restart or, in some cases, it won't start at all until I disconnect the power cable and reconnect it. This erratic behavior occurs intermittently, making it difficult to pinpoint the exact conditions under which it happens.
                              For context, I have tested the PSU using an electronic load at 150W, and under those controlled conditions, it functions flawlessly. This leads me to...
                              02-09-2025, 03:19 AM
                            • karatzdi
                              Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                              by karatzdi
                              I know some might say... just buy another one. Sell it as parts..!
                              So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                              Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                              Spent some time downloading the Service...
                              06-11-2024, 08:38 AM
