Onkyo HT-R390 DSP dump
  • Tom_x
    • Aug 2018
    • 33
    • Hungary
    Hi
    I need DSP dump for Onkyo HT-R390.
    DSP board: BCHDM-0678
    DSP firmware corrupted, i need dump for Q282 spi chip (25q16) or dump from similar model with same dsp board
    thx
    Tom
  • dobrykamil
    • Jun 2013
    • 63
    File attached.
    • Tom_x
      • Aug 2018
      • 33
      • Hungary
      thanks for dump
      worked
      • Bassquake
        • Aug 2009
        • 19
        Originally posted by dobrykamil
        File attached.
        Hi. Any chance could reupload? I have a Onlyo HT-R390 and sound is gone and would like to try reflashing the firmware.
        Thanks.
        • lotas
          • Jan 2016
          • 4936
          • Russia
          Thanks.
          Try.
          • Bassquake
            • Aug 2009
            • 19
            Many thanks lotas. Is there a repository somewhere online where different versions can be found?
            • tsb3
              • Oct 2025
              Originally posted by Tom_x
              thanks for dump
              worked
              How do you update the DSP with this file using the digital coaxial input? I tried decompressing the zip to bin, then converting to wav using Audacity, also tried decoding from zip to wav (both PCM 16 or 24). Burning to CD and playing the file while the receiver was in update mode didn't work with any option. Please help, thank you.
              • lotas
                • Jan 2016
                • 4936
                • Russia
                This is not an update file, it is a dump, it programs the spi flash 25Q16 through a programmer.
                • tsb3
                  • Oct 2025
                  Is the programmer the only way to revive the chip? The DSP firmware version is showing as ???????, can I fix it with an update file?
