Alpine CDA-9833
  • Carm99
    • Jun 2014
    • 69
    • England
    Alpine CDA-9833
    Alpine CDA-9833
    Ive got this stereo open at the moment and the small 12v fan won’t run. I’ve tested it by itself with a Bench PS and it’s working ,just not when plugged into the board when the stereo is switched on.
    Any help is welcome.
    Cheers.! 🙂
    Here is the Service Manual.
    https://data2.manualslib.com/pdf5/11...52&take=binary
  • Carm99
    • Jun 2014
    • 69
    • England
    Here's part of the circuit.
    • R_J
      • Jun 2012
      • 9634
      The fan circuit is controlled from IC501 pin 44 so I suspect the fan won't run until it is required, if the fan is for cooling the outputs I suspect it only comes on when required, there is a HI-TEMP input on IC501 pin 87, controlled by TH501
      • Carm99
        • Jun 2014
        • 69
        • England
        Hi
        It never comes on at all.
        cherrs
        • R_J
          • Jun 2012
          • 9634
          What have you checked other than applying 12v to the fan? What are the voltages on Q813 pin 4 and pin2? maybe Q812 or Q813 are bad, ZD801 could be bad, maybe R826 is open?
          • redwire
            • Dec 2010
            • 3912
            Could also check the thermistor voltage at MCU pin 87 "HI-TEMP". It seems to be 100kΩ at 25°C with 5V power and R543 15kΩ so I would guess 4.35V at room temp and it drops as things heat up. If it's 5V then the thermistor is likely open-circuit. It's an 0603. Could heat it up a little with a soldering iron. My math:
            25°C gives 4.35V
            40°C gives 3.79V
            50°C gives 3.32V
            ERTJ1VV104J
            • Carm99
              • Jun 2014
              • 69
              • England
              Thanks for the interest and help guys. I’ll get back to this at some point. Too busy at the moment.
              There’s no diagram for the circuit board and some have no reference so it might be difficult to find components.
              Cheers
              • kodiac
                rx-750 pioneer stereo memory
                by kodiac
                I have rx-750 pioneer stereo and the stored radio stations in the memory does not stay in the memory very long.
                Does anyone know where the memory is located in this stereo and how it is powered up?
                It does not have a battery backup.
                Does the memory use a capacitor for its power supply?
                thank you
                11-22-2025, 05:49 PM
              • shamsudeen
                Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                by shamsudeen
                Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                i know that in linear power supply the noise will be very low comparing to SMPS supply....
                07-19-2025, 07:14 AM
              • Eniaro
                Bench test a series X
                by Eniaro
                How do you bench test a series X? I was planning to find a defective PSU to use its connector, but before I go about doing this, I was wondering if there's any bench PSU to the series X connector adapter available
                06-17-2025, 01:46 PM
              • rabsonnjala
                LENOVO IDEAPAD 100 works only on bench power supply
                by rabsonnjala
                Hie I have a Lenovo laptop
                Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
                it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
                below are my readings
                with the original charger only
                JBATT1
                PIN1 0.22V
                PIN2 0.22V
                PIN3 0.45V
                PIN4 0.45V
                PIN5 O.43V
                PIN6 0V
                PIN7 GND
                PIN8...
                11-20-2021, 08:32 AM
              • DrDos
                Kenwood KR-6030 vintage stereo ,Old Man Trying to Save a Buck
                by DrDos
                Hello all. I'll try to keep this short. I have no knowledge of electronics. I can use a multimeter and am familiar with caps to some extent. I bought a Kenwood KR-6030 vintage stereo. It need work and so I thought I would recap the thing since I get power to the on switch but nothing else is working. No lights, no sound and so forth. I went to Mouser to order caps and I find I am way over my head. I not only do not know the type of capacitors I need but Mouser and digikey do not accept Kenwood part numbers. I have the info such as 220uF 63v and such but no place to put it. I could buy a recap...
                08-08-2025, 03:16 AM
